Feedback destroyer? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-26-2013, 04:08 PM - Thread Starter
ozziedog's Avatar
Liked: 24
How well does the Behringer feedback destroyer work for eqing 2 subs? In comparison what do I gain by going with a minidsp instead?
ozziedog is offline
post #2 of 13 Old 03-26-2013, 04:35 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
The same as any other eq. If you want to eq two separate subs properly, you'd want 2 of them.
Mini DSP is a lot easier to work with, and gives you the ability to eq much lower in the frequency range. There's more than that, but that's 2 main things that stick out.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #3 of 13 Old 03-26-2013, 04:39 PM
ajones51's Avatar
Bfd has 2 channels. I believe you could eq each channel separately, 1 for each sub.
ajones51 is offline
post #4 of 13 Old 03-26-2013, 04:53 PM - Thread Starter
ozziedog's Avatar
Liked: 24
How low can the bfd 1124 EQ?
ozziedog is offline
post #5 of 13 Old 03-26-2013, 05:13 PM
Quoted: 360 Post(s)
Liked: 437
Hmmm, good point. It's been so long since I've had mine I don't even remember.
post #6 of 13 Old 03-26-2013, 05:22 PM - Thread Starter
ozziedog's Avatar
Liked: 24
I was looking andit looks like one of the bfd models does only 1 channel but the 1124 does 2 channels. However I can't find anything saying how low you can set filters.
ozziedog is offline
post #7 of 13 Old 03-26-2013, 05:38 PM
Quoted: 360 Post(s)
Liked: 437
I'm 99% sure it was 20hz.
post #8 of 13 Old 03-26-2013, 06:19 PM
ajones51's Avatar
It is 20hz. The q is adjustable, so it can extend lower. Usually it is best to cut peaks in the upper frequencies instead of boosting down low.
ajones51 is offline
post #9 of 13 Old 03-26-2013, 06:20 PM
Point Source
beastaudio's Avatar
Quoted: 3519 Post(s)
Liked: 2835
It is, and I am not sure how creative you can get with the filters to make them work below 20hz, but the Berry DCX2496 has ways around the 20hz cutoff for filtering that it also shares with the BFD. I am in the process of documenting this, but basically if you are wanting full EQ for subs, either look at the DCX2496 or the MiniDSP. Both are great and TBQH your EQing below 20hz can be done by both, as below 20hz, the most of what you would be doing is a L/T or HPF and the DCX can do that as well, it just takes a little creativity. I jumped for it as I don't want to plug my PC in everytime I want to do some eqing. The DCX has it right on the front panel biggrin.gif
beastaudio is online now
post #10 of 13 Old 03-27-2013, 10:59 AM
BassThatHz's Avatar
Quoted: 2035 Post(s)
Liked: 1566
Get the mini or DCX, forget the FBD. It's too limited in comparison to the prior two.
BassThatHz is online now
post #11 of 13 Old 03-27-2013, 11:09 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5318 Post(s)
Liked: 4203
I mostly agree with this.
Hey, late to the party. I have owned the BFD for some time and yes it is a very nice EQ device for the novice. It's nice that it is all digital, has many filters, stereo compatible and has a very nice voltage range. It is nice for EQ'ing but like BassThatHz mentioned, it's limited.
Here's the biggie for this one: it has no controls for delay or high/low pass and these are essential for a proper sealed multi-sub system or any resonate system that requires a high pass filter of sorts. If you're lucky and own an AVR with discrete stereo subwoofer outputs you can get by possibly with using the controls for distance/delay.
So if all you really need is some PEQ and nothing else, it's still a good buy but if you want some versatility or something more advanced, skip straight to the DCX.
Scott Simonian is offline
post #12 of 13 Old 03-27-2013, 11:47 AM
Quoted: 360 Post(s)
Liked: 437
There's no difference. Either way you are boosting. You make cuts up top, you have to bump the gains to calibrate, which boosts down low.
post #13 of 13 Old 03-27-2013, 01:17 PM - Thread Starter
ozziedog's Avatar
Liked: 24
I did end up going with a mini dsp. Thanks for the suggestions guys.
ozziedog is offline
