Triple Gjallarhorn + Othorn Build - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #151 of 183 Old 04-30-2013, 04:22 PM
N8DOGG's Avatar
Quoted: 891 Post(s)
Liked: 948
Originally Posted by Ricci View Post
What were you already running? If you are comparing one GH to multiple other subs with high powered 18's and 15's yeah it isn't going to blow them away with one driver no matter what enclosure it is in.
Don't get me wrong, it's pretty awesome lol. My first measurements are looking like the G-horn is about 2-3 of my 21's, which is what I expected. I think in my case it's going to have to be 4 at least.... tongue.gif
Though I did have the G-horns AND my 21's a rocking and I think If I can get them dialed in right, I'm gonna keep it that way biggrin.gif
N8DOGG is offline
post #152 of 183 Old 05-05-2013, 01:27 PM - Thread Starter
dsl1's Avatar
Question:
Audyssey XT32 on my Onkyo 818 is setting the distance to the Ghorns at the distance from the mouth. Tried different things with just one running, moving the mic to a foot in front of the mouth, etc. It always gave the correct distance to the mouth but it sounds like it should be including some delay for the horn path as well no?
Here is a graph:
Purple: Just one Ghorn
Yellow: Just Mains (SEOS12 with Deltalites)
Green: Both
dsl1 is offline
post #153 of 183 Old 07-19-2013, 12:19 PM
Mfusick's Avatar
Quoted: 604 Post(s)
Liked: 2606
Originally Posted by dsl1 View Post
Made some good progress today. Cut most of the inside panels to width. Gotta figure out the angles / length without the dado's. Drilled the pocket holes in all the outside pieces and attached a few on the first one.
Drilling pocket holes:
Track Saw Setup: Cutting all the 22.53inch widths
Horn path outline: Finishing these up on all of them tomorrow
Really nice saw.
How much does the track set up cost?
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is offline
post #154 of 183 Old 07-19-2013, 12:21 PM - Thread Starter
dsl1's Avatar
Originally Posted by Mfusick View Post
Really nice saw.
It's about 550$ for the saw / track from Festool. Festool is the very high end of these things, there are several other options as well that are a bit cheaper.
Really really like it though. Great tool to have!
dsl1 is offline
post #155 of 183 Old 09-14-2013, 04:00 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 232
Any updates guys?
My craving for a build is ramping up as the season starts to change. Late fall and winter is bass time!!
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #156 of 183 Old 09-14-2013, 05:58 PM
N8DOGG's Avatar
Quoted: 891 Post(s)
Liked: 948
I took one of the horns out of my room and am adding 4 more sealed 21's. They are just to big for my room at the moment.
N8DOGG is offline
post #157 of 183 Old 09-15-2013, 05:33 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 505
So four 21's is smaller? Just playing wink.gif ..... Do you have any pics to post? I would really like to see your 21's. I am having the same issue with my horn sub and am replacing it with 4 18's soon.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #158 of 183 Old 09-15-2013, 08:19 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 232
Nice!
Are you using the FTW-21s?
I can relate. The GJALLARHORNs are a little big for my room too. I may still build them. I am ready to move on from the DTS-10 realm and into something new.
I might inquire as to whether anyone might by willing to do a refold so that the cabs are longer but not as tall. Ugh, there just is no perfect size/diesign!
Joe = LFE Addict
jpmst3 is offline
post #159 of 183 Old 09-15-2013, 09:31 AM
N8DOGG's Avatar
Quoted: 891 Post(s)
Liked: 948
Well, I should have said the G-horns AS WELL as my 4 x 21's lol.
2 G-horns is very close to the same size of 8 x 21's stacked 4 on each side behind my couch. I do have pics but they are not current. My basement is currently under tarps and plastic as our upstairs is being renovated but the HT portion should be back to normal this week..... hopefully. I'll post some pics once it's cleaned up.
N8DOGG is offline
post #160 of 183 Old 09-15-2013, 09:33 AM
N8DOGG's Avatar
Quoted: 891 Post(s)
Liked: 948
Originally Posted by jpmst3 View Post
Nice!
Yup, The G-horns hammer under 30hz but give up too much to the sealed subs above that. I currently have one of the G-horns in storage and the other is still in the HT but pointed directly at the back of the couch for some tactile feel wink.gif
N8DOGG is offline
post #161 of 183 Old 09-18-2013, 03:33 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 232
I bet those 21s are bad ass to look at too.
I wish you lived closer. I would love to demo those babies.
Joe = LFE Addict
jpmst3 is offline
post #162 of 183 Old 03-11-2014, 04:52 PM
shello79's Avatar
Where did you guys purchase the 4x8 sheets of baltic birtch
shello79 is offline
post #163 of 183 Old 03-11-2014, 05:13 PM
baniels's Avatar
Quoted: 168 Post(s)
Liked: 193
Liberty Hardwoods in Des Moines and Hill Hardwood in Iowa City.
Giardo likes this.
baniels is online now
post #164 of 183 Old 07-02-2014, 05:06 PM
Mfusick's Avatar
Quoted: 604 Post(s)
Liked: 2606
Did you ever take final measurement on distortion or Response or SPL ?
Mfusick is offline
post #165 of 183 Old 07-02-2014, 06:27 PM
mjaudio's Avatar
Quoted: 37 Post(s)
Liked: 73
Since this thread is back from the dead I figured I would answer this question.
4X8 sheets of Baltic Birch are generally shop grade, at least that's what I can get here in S. Cali. It will generally have one good side and the other will have football shaped patches were there were knots or defects on the veneer side. Sometimes it has the patches on both sides but it is a void free 13 ply. Just ask around lumber yards for shop grade 4x8 BB and if they don't have it they should be able to point you to someone who does.
mjaudio is offline
post #166 of 183 Old 08-10-2014, 05:04 PM
Liked: 0
Where can i find plans for the othorn?
SonicSoundVW is offline
post #167 of 183 Old 08-11-2014, 08:53 AM
Mfusick's Avatar
Quoted: 604 Post(s)
Liked: 2606
Ricci
Mfusick is offline
post #168 of 183 Old 08-14-2014, 03:21 AM
blah450's Avatar
Quoted: 138 Post(s)
Liked: 169
Was there an Othorn refold being worked on?
blah450 is offline
post #169 of 183 Old 08-14-2014, 05:28 AM
chrapladm's Avatar
Quoted: 682 Post(s)
Liked: 247
I dont think there needed to be one. There was a refold on the Ghorn. I dont believe anyone has built the V2 refold yet.
chrapladm is offline
post #170 of 183 Old 09-20-2014, 01:10 PM
Mfusick's Avatar
Quoted: 604 Post(s)
Liked: 2606
I have the plan from Josh, but I have not built it. Someone must have built it by now.
Mfusick is offline
post #171 of 183 Old 09-20-2014, 05:17 PM
chrapladm's Avatar
Quoted: 682 Post(s)
Liked: 247
I think this will be the first person to build one AND have a thread. Ghorn seems to be slowing dying off only because of the size and available drivers.
post #172 of 183 Old 10-28-2014, 03:35 PM
Mfusick's Avatar
Quoted: 604 Post(s)
Liked: 2606
Can't you use a UXL instead of LMS? Or even a Sundown ? I think it's mostly the difficulty of the build. Most just settle for a marty.
Has anyone ever tested the second fold versus the original?
Mfusick is offline
post #173 of 183 Old 10-28-2014, 04:07 PM
chrapladm's Avatar
Quoted: 682 Post(s)
Liked: 247
UXL works just fine and I dont believe any Sundown products work in the GHorn.
post #174 of 183 Old 10-28-2014, 05:20 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 232
Great question!
I am curious myself to know if there are any real world differences between the folds.
Mfusick likes this.
Joe = LFE Addict
jpmst3 is offline
post #175 of 183 Old 10-28-2014, 06:33 PM
lukeamdman's Avatar
Quoted: 892 Post(s)
Liked: 961
Great question!
I have a hard time believing Josh would make a revision to an already crazy good design and it not be improved....
Mfusick likes this.
lukeamdman is offline
post #176 of 183 Old 10-28-2014, 06:38 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 232
This is true.
And it is definitely a better re-fold, however that may not necessarily translate to appreciable differences in FR or THD.
Mfusick likes this.
Joe = LFE Addict
jpmst3 is offline
post #177 of 183 Old 09-14-2016, 11:54 AM
Liked: 1
lukeamdman is there any option to get the plans to build Gjallarhorn and Othorn? I'm looking for a long time unique subs project ant this is it! I'll be extremely grateful for any help. Now I think to build a 3 x Othorn and 1 x Gjallarhorn. Please lukeamdman make my dreams come true. Please.
morebital is offline
post #178 of 183 Old 09-14-2016, 12:35 PM
lukeamdman's Avatar
Quoted: 892 Post(s)
Liked: 961
Send me a PM with your email address.
post #179 of 183 Old 09-14-2016, 01:08 PM - Thread Starter
dsl1's Avatar
Make his dreams come true!
baniels, lukeamdman and morebital like this.
dsl1 is offline
post #180 of 183 Old 09-14-2016, 02:38 PM
Liked: 1
Unfortunately I can't even send a message. I'm a beginner here at forum. Sad. Can I give you my address here?
