DIY Sub Upgrade - 4 x 18" SI - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 125 Old 07-24-2013, 08:04 AM
Point Source
beastaudio's Avatar
Quoted: 4021 Post(s)
Liked: 3332
Originally Posted by N8DOGG View Post
I don't see why guys won't use MDF anymore. Other than the dust, it's easy to get, cheap, works very well. Just use a plywood mounting panel and be done. I do use BB but for the most part, I still use mdf for most builds that aren't the size of a house tongue.gif
I used MDF for my entire uber mains and multiple DO sub enclosures. A thread for those will go up soon.
Yea yea yea.....
Can't stain MDF and get that Glawsy look mayne...
beastaudio is online now
post #122 of 125 Old 07-24-2013, 03:43 PM
N8DOGG's Avatar
Quoted: 1103 Post(s)
Liked: 1200
Originally Posted by beastaudio View Post
Yea yea yea.....
And lots of guys that DO stain their BB make it look like a pile of garbage since they have no idea what they are doing. Veneering is not very hard, they are lots of options, lots of the guys just roll on duratex anyways cool.gif
N8DOGG is offline
post #123 of 125 Old 08-22-2013, 03:36 PM - Thread Starter
bradthebold88's Avatar
Quoted: 18 Post(s)
Liked: 32
Finally had time to replace the sub and set everything back up in the living room.
Gold is no EQ, Green is Audyssey XT. All I've done so far is set them up and run Audyssey. It looks good to me. I could probably get it flat to 6Hz if I EQ'd before Audyssey, but I'm not too concerned.
I prefer the sound quality to my old Dayton HFs and the output and extension (since I had to run a HPF with the Daytons).
Living room: Definitive BP2000TL, CLR3000, BPVX, Quad SI 18" subs
Bedroom: Definitive BP30, CLR2000 Also have had: BP7000SC, BP8B, BP10B, BPX, Dayton 15" HF subs, Rythmik F15
bradthebold88 is online now
post #124 of 125 Old 08-22-2013, 03:45 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5926 Post(s)
Liked: 4961
Excellent! Pretty damn good FR using A-XT.
Scott Simonian is online now
post #125 of 125 Old 08-22-2013, 08:15 PM
Electrodynamic's Avatar
Quoted: 447 Post(s)
Liked: 670
Electrodynamic is offline
