Slot Port - different ratio's with same area ,,different length's ?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 03-30-2013, 10:22 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Im trying to replace a 2" round Port x 8" long by a slot port , the area of a 2"port is 3.14 .
Now i can make a 3.14" x 1" slot ...or a 6.28" x .5" slot port which are both = to a 2" round port(3.14)
....Why when I enter these diff ratio's in a slot port Calculator do i get diff total port lenghts to achieve desired tuning freq ??
Some ratio's like (1.77"x1.77") give me a length of 6.35"length... and (6.28"x .5") give me a 4.11" length
I would have thought they would all be identical length's ?????
randyc1 is offline
post #2 of 11 Old 03-30-2013, 11:15 PM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 783
Slot ports with a high aspect ratio tend to slow down the air due to the increase in friction from having more surface area inside the port which the same volume of air must pass over. I can't say for certain how close those calculations are, though it would sure be interesting to see the formula used to determine them.
mtg90 is online now
post #3 of 11 Old 03-30-2013, 11:54 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2574
"I would have thought they would all be identical length's ?????"
they should be. something is wrong or incomplete if the calculator is giving you materially different lengths.
Listen. It's All Good.
LTD02 is offline
post #4 of 11 Old 03-31-2013, 08:36 AM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
OK !! now i understand why the thinner slots create shorter Port lengths ,..because of the drag !!! ... I was only looking at the AREA and did'nt realize how much more Perimiter, square or even worse rectangular ports have , even if the Area was the same !!,
.....Now do you know if these shorter rectangular ports BEHAVE the same as the = round port ?
randyc1 is offline
post #5 of 11 Old 03-31-2013, 08:46 AM
LTD02's Avatar
Liked: 2574
i have not seen air drag as part of any calculator. that would require some fairly sophisticated fluid dynamics math and would even start to depend on variables such as the 'roughness' of the surface. which calculator are you using?
LTD02 is offline
post #6 of 11 Old 03-31-2013, 01:26 PM
Looneybomber's Avatar
Liked: 25
Sounds like my kind of calculator!
YID DIY
Looneybomber is offline
post #7 of 11 Old 03-31-2013, 03:14 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Have u tried a slot port calculator ? the more narrow the slot ,the shorter the length of port.?
Have u ever calculated the perimiter of a very narrow slot compared to it's = area round port ?
randyc1 is offline
post #8 of 11 Old 04-02-2013, 12:01 PM
MBentz's Avatar
Quoted: 24 Post(s)
Liked: 43
the two areas you proposed would have very similar " drag" effects, but the drag doesn't affect the frequency tuning anyway. sounds like your calculator is wrong, or something else is changing without you knowing.
-Mike Bentz
~It's all about compromise~
MBentz is offline
post #9 of 11 Old 04-02-2013, 03:21 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
...Found out that when, "Are you using a Slotted Port " is checked on the web calculator, it deducts 1/2 of the Width from the Un -checked calculation !!
Here's the calculator :http://www.mobileinformationlabs.com/HowTo-1Woofer-Box-CAL%20Port%20lenth%201.htm
randyc1 is offline
post #10 of 11 Old 04-04-2013, 10:35 AM
Mark Seaton's Avatar
Quoted: 495 Post(s)
Liked: 1288
Very high aspect ratio (non-square) ports do behave as though they have less effective area than a more square port. I've seen and measured some approximate rules of thumb, but there are multiple variables at play where a slot terminating along a side wall vs. blunt end can have a few inch difference on effective length depending on the design. In short, the further you get from a round port with both ends terminating on a large flat surface, the more adjustment and testing needs to be done. Of course the longer you make a port, the more tolerance you will have to these effects as the end effects and effective area reduction are smaller % changes.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is online now
post #11 of 11 Old 04-04-2013, 08:19 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
[IMG ALT=""][
The original design was rectangular box , with a 2" Round x 8" long port at the top of the enclosure. Since i have shortened the box a little and also added an angle, the original port no longer fits.
The Area of a 2" round port is 3.14, so im wondering if the Slot Port in the diagram of (1" x 3.14") x 7.5" long , that is using the top of the Tunnel would be close to original ??
....Air can circulate around tunnel , if not clear in diagram .
randyc1 is offline
