Upgrade from a Shiva-x... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-02-2013, 12:16 AM - Thread Starter
Favelle's Avatar
I cuurently have a Shiva-X, tuned to 18hz in a 200L enclosure, powered by a 500W HSPA plate amp. Looking for a possible driver upgrade, what are my options? Not really interested in a sideways move, looking for something that will be a noticeable difference.
In terms of LFE, size does matter!
Favelle is offline
post #2 of 3 Old 04-02-2013, 12:46 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5373 Post(s)
Liked: 4287
More drivers, more power and overall more subwoofer would be the 'movin on up' ticket for you then. smile.gif
Scott Simonian is online now
post #3 of 3 Old 04-02-2013, 05:44 AM
LTD02's Avatar
Quoted: 2352 Post(s)
Liked: 2594
i'm not sure there is a meaningful upgrade in the same diameter.
if you want to cut a new hole in the box, plop in an 18" driver, and put a more powerful amp on it, then you can get an upgrade.
gray is what you have.
red is 18" dayton ho with a 1000 watt amp; in the same box.
blue is mach5/ist audio uxl18" with a 2000 watt amp; in the same box.
otherwise, add to, rather than replace, like scott said.
Listen. It's All Good.
LTD02 is offline
