Dual Rythmik FV15Hp`s/upgrade to diy? - Page 14 - AVS Forum | Home Theater Discussions And Reviews
post #391 of 408 Old 11-10-2013, 12:26 AM
Deep Sea Sound
dgage's Avatar
Quoted: 1669 Post(s)
Liked: 1491
Well I originally ordered a 4x10 to use for distributed audio but was getting static so I sent the board back and upgraded to a 10x10. The 10x10 doesn't have any sound quality issues so that is good. Regarding how I like it, I think it is pretty easy to use. Then again, I'm really only using it as a sub crossover and haven't yet had a chance to setup my new HT and EQ everything. So what I've used I like but I really haven't put it through its paces enough yet.
David Gage
Deep Sea Sound
"You don't listen to our subs, you EXPERIENCE them!"
dgage is offline
post #392 of 408 Old 11-10-2013, 07:41 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 968
Adds to the "tactical feel."
It has been mentioned in my build thread I should be a Popalock copy cat.................................................
popalock likes this.
doublewing11 is offline
post #393 of 408 Old 11-10-2013, 08:59 PM
Deep Sea Sound
dgage's Avatar
Liked: 1491
I wouldn't consider it copying, more of...yeah, that's a great idea, maybe I should do that too. We all share here, yeah, that's it. smile.gif
David Gage
Deep Sea Sound
dgage is offline
post #394 of 408 Old 11-11-2013, 11:33 AM
popalock's Avatar
Quoted: 1317 Post(s)
Liked: 1814
That's not copying at all! Do it...
+1
popalock is offline
post #395 of 408 Old 11-11-2013, 12:51 PM
Quoted: 229 Post(s)
Liked: 968
+1
Just showed my wife the pic................................asked her, "What do you think?" Her response............................."Are you crazy?" My reply................."Maybe?"
Can't imagine 8 in my space..................but maybe four? I'm an old man......................with small cojones! biggrin.gif
steve nn likes this.
post #396 of 408 Old 11-22-2013, 11:28 AM - Thread Starter
mal01's Avatar
Quoted: 110 Post(s)
Hey guys, I think I see some time off from work in the near future and would like to work on EQ for my subs. Given the system and components I have and the fact that I have admitted I'm not very techie, does anyone have an opinion on which unit I should go with? I figure one of the minidsp units or something like a Berhinger unit. I think the more plug and play the better.
mal01 is offline
post #397 of 408 Old 11-22-2013, 11:49 AM
popalock's Avatar
Liked: 1814
Lee! What up man!
Where you been? Give me a holler.
popalock is offline
post #398 of 408 Old 12-22-2013, 07:13 PM - Thread Starter
mal01's Avatar
Quoted: 110 Post(s)
Toying with upgrading again:D Here`s what I`m thinking, replace my Dayton`s with UXL`s or build four dual opposed using four more Dayton`s?
mal01 is offline
post #399 of 408 Old 12-23-2013, 07:07 AM - Thread Starter
mal01's Avatar
Quoted: 110 Post(s)
mal01 is offline
post #400 of 408 Old 12-23-2013, 07:51 AM
popalock's Avatar
Liked: 1814
Awesome...
I'll try to give you a shout here later today!
popalock is offline
post #401 of 408 Old 12-23-2013, 07:54 AM - Thread Starter
mal01's Avatar
Quoted: 110 Post(s)
Thanks Austin!
mal01 is offline
post #402 of 408 Old 12-23-2013, 08:38 AM
steve nn's Avatar
Liked: 433
double Can't imagine 8 in my space..................but maybe four? I'm an old man......................with small cojones! biggrin.gif
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #403 of 408 Old 12-25-2013, 03:32 PM - Thread Starter
mal01's Avatar
Quoted: 110 Post(s)
Bump!
mal01 is offline
post #404 of 408 Old 11-22-2015, 12:04 PM - Thread Starter
mal01's Avatar
Quoted: 110 Post(s)
Just realized the fans on my amp have quit working, opened it up and everything looks good, even opened up the connections and they seemed ok, yes the connection that powers both fans is good, any ideas?
mal01 is offline
post #405 of 408 Old 01-13-2016, 03:50 PM - Thread Starter
mal01's Avatar
Quoted: 110 Post(s)
I posted this in the Martysub section but didn't get much response so I'm going to ask here in my old thread since it sort of continues with the theme. I built four full Marty's and put my Dayton's in them and like the results but have purchased four UXL-18's to replace the Dayton's, I then thought I would add the four original sealed with the Dayton's back into the mix but don't exactly know how to do it, which amp to get, how to eq/integrate them etc... Any help would be greatly appreciated
mal01 is offline
post #406 of 408 Old 01-14-2016, 12:33 PM - Thread Starter
mal01's Avatar
Quoted: 110 Post(s)
Anyone?
mal01 is offline
post #407 of 408 Old 01-14-2016, 06:19 PM
SBuger's Avatar
Quoted: 434 Post(s)
Liked: 639
^^^ Maybe this will help you somewhat.
Here's a couple of great threads talking about blending ported with sealed:
Blending ported and sealed - analog vs. digital HPF... and other ramblings....
Setting up a sealed and ported sub together, or multiple (different) ported subs
Sounds like it can be done successfully if you use the right HPF (Butterworth 12db/oct - gradual slope) on the ported OR maybe even a steep slope on the sealed starting a bout 5-10 Hz to get the phase of the two to line up better and not wreck havoc on your overall BASS frequency response.
You could do this with a MiniDSP or the DSP in an Inuke etc. Hopefully this will help you blend your ported Marty's with your sealed if you decide to add them.
I've have ported currently but want to add sealed 18's directly behind my three main seats in the next couple of months. I'm hoping this info will help me to integrate sealed with ported without to much problem. We shall see.
SBuger is online now
post #408 of 408 Old 01-15-2016, 03:19 AM - Thread Starter
mal01's Avatar
Quoted: 110 Post(s)
Thanks, I will go through these and hopefully I will learn something!
mal01 is offline
