Dual Rythmik FV15Hp`s/upgrade to diy? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 408 Old 04-29-2013, 03:07 PM
brian6751's Avatar
Quoted: 905 Post(s)
Liked: 695
Yes. Show us how you have your output wired as well.
Link error. Please fix.
works for me
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #182 of 408 Old 04-29-2013, 03:08 PM
brian6751's Avatar
Quoted: 905 Post(s)
Liked: 695
Originally Posted by mal01 View Post
Kind of expensive for one trigger, know of anything else?
not that can handle a 20 amp circuit.
there are home brewed ones for cheap, but i didnt want to mess wtth them.
Rivers Edge Theater
post #183 of 408 Old 04-29-2013, 03:08 PM - Thread Starter
mal01's Avatar
Quoted: 48 Post(s)
mal01 is offline
post #184 of 408 Old 04-29-2013, 03:09 PM - Thread Starter
mal01's Avatar
Quoted: 48 Post(s)
mal01 is offline
post #185 of 408 Old 04-29-2013, 03:12 PM
brian6751's Avatar
Quoted: 905 Post(s)
Liked: 695
in that first pic. it looks like you have them plugged into the speakon connection. are they speakon ends or xlr?
Rivers Edge Theater
post #186 of 408 Old 04-29-2013, 03:33 PM - Thread Starter
mal01's Avatar
Quoted: 48 Post(s)
Your right Brian, I have committed an noobie error, I know I tried to insert them there but they wouldn't fit so I thought well, I`ll just stick them in here:eek: I`m sure it make a difference, maybe I don't even need the CB. I`m doing some cable management right now and have them off, I`ll rewire and try again.
mal01 is offline
post #187 of 408 Old 04-29-2013, 03:35 PM
brian6751's Avatar
Quoted: 905 Post(s)
Liked: 695
folks have done the same thing with much worse results........... tongue.gif
Rivers Edge Theater
post #188 of 408 Old 04-29-2013, 03:46 PM - Thread Starter
mal01's Avatar
Quoted: 48 Post(s)
mal01 is offline
post #189 of 408 Old 04-29-2013, 04:03 PM - Thread Starter
mal01's Avatar
Quoted: 48 Post(s)
Gone back and tried to hook up again and see what happened, xlr female to 5508, the xlr connection on the amp is male, so I have two male ends, do i have the wrong xlr?
mal01 is offline
post #190 of 408 Old 04-29-2013, 04:18 PM - Thread Starter
mal01's Avatar
Quoted: 48 Post(s)
Oh, i'm not on a 20amp.
mal01 is offline
post #191 of 408 Old 04-29-2013, 04:37 PM
brian6751's Avatar
Quoted: 905 Post(s)
Liked: 695
Yep
Rivers Edge Theater
post #192 of 408 Old 04-29-2013, 05:06 PM
brian6751's Avatar
Quoted: 905 Post(s)
Liked: 695
You can go rca to the SMS and xlr from the SMS to the amp with that male to male cable
Rivers Edge Theater
post #193 of 408 Old 04-29-2013, 05:34 PM
popalock's Avatar
Quoted: 1235 Post(s)
Liked: 1720
Color me confused... How were you able to get a signal at all to the amp?
One thing at a time.
popalock is offline
post #194 of 408 Old 04-29-2013, 05:54 PM - Thread Starter
mal01's Avatar
Quoted: 48 Post(s)
Brian, I'm not using the SMS at this time, what other kind of XLR is there?
Austin, RCA out from avr to input of CB, Used XLR from CB output to the Input of the amp connections that aren't XLR, whatever the he'll they are called(link)?
mal01 is offline
post #195 of 408 Old 04-29-2013, 06:01 PM
brian6751's Avatar
Quoted: 905 Post(s)
Liked: 695
I was just saying the cable you have now would work with the SMS. You need a male/female cable to hook it up the way you have it. Monoprice.com will have them.
Rivers Edge Theater
post #196 of 408 Old 04-29-2013, 06:15 PM - Thread Starter
mal01's Avatar
Quoted: 48 Post(s)
My XLR is male/female. I got them from mono price .
mal01 is offline
post #197 of 408 Old 04-29-2013, 07:06 PM - Thread Starter
mal01's Avatar
Quoted: 48 Post(s)
mal01 is offline
post #198 of 408 Old 04-29-2013, 07:08 PM - Thread Starter
mal01's Avatar
Quoted: 48 Post(s)
mal01 is offline
post #199 of 408 Old 04-29-2013, 07:09 PM - Thread Starter
mal01's Avatar
Quoted: 48 Post(s)
mal01 is offline
post #200 of 408 Old 04-30-2013, 04:25 AM
brian6751's Avatar
Quoted: 905 Post(s)
Liked: 695
Ok. Looks like you need female/female
Rivers Edge Theater
post #201 of 408 Old 04-30-2013, 05:58 AM - Thread Starter
mal01's Avatar
Quoted: 48 Post(s)
Where do get that?
mal01 is offline
post #202 of 408 Old 04-30-2013, 06:29 AM - Thread Starter
mal01's Avatar
Quoted: 48 Post(s)
Looks like have to get a f/f coupler.
mal01 is offline
post #203 of 408 Old 04-30-2013, 08:38 AM
popalock's Avatar
Liked: 1720
No... Upon further investigation please reference page 8 § 2. of your owners manual here:
CV5000 Owners Manual
The CV5000 takes a Male XLR input connection.
popalock is offline
post #204 of 408 Old 04-30-2013, 09:01 AM - Thread Starter
mal01's Avatar
Quoted: 48 Post(s)
That's where I had them, but was having the issue with the CB.
mal01 is offline
post #205 of 408 Old 04-30-2013, 02:44 PM
brian6751's Avatar
Quoted: 905 Post(s)
Liked: 695
that sure looks like it takes a female connection to me Pop
Rivers Edge Theater
post #206 of 408 Old 05-01-2013, 05:38 AM
walke108's Avatar
Liked: 25
Mal, any updates??
walke108 is offline
post #207 of 408 Old 05-01-2013, 05:58 AM
brian6751's Avatar
Quoted: 905 Post(s)
Liked: 695
Originally Posted by walke108 View Post
Mal, any updates??
Not as much as we would like to.
We love to go up to Traverse City. My sister in law and her husband also have a place in Gaylord.
Rivers Edge Theater
post #208 of 408 Old 05-01-2013, 07:41 AM
popalock's Avatar
Liked: 1720
Originally Posted by brian6751 View Post
that sure looks like it takes a female connection to me Pop.
The XLR input on the CV5000 "is" female and it "takes" a male connector, which he currently has. No need for a female-to-female adapter like he was anticipating. I gave mal a call yesterday to clear it up.
popalock is offline
post #209 of 408 Old 05-01-2013, 07:59 AM - Thread Starter
mal01's Avatar
Quoted: 48 Post(s)
Everything is up and running fine, it was hooked up properly, but I am using two Cleanboxes right now but still have a weird issue with the gain knob, it doesn't appear to be affecting performance. I am going to get the subs as close to equal distance from the MLP as possible and run Audyssey Pro and start trying to hook the SMS back up, its been awhile since I`ve used it. I have a question about co-locating, what`s the difference in co-locating in order to get more output and just turning up the amp some if I have plenty of headroom left?
mal01 is offline
post #210 of 408 Old 05-01-2013, 09:38 AM
brian6751's Avatar
Quoted: 905 Post(s)
Liked: 695
Colocating generally gets you 3db of free output. No increase in power needed. If you have headroom to spare, it's best to spread them out.
Rivers Edge Theater
