New Sundown X Series drivers - Wow! - Page 2 - AVS Forum
 1Likes
post #31 of 56 Old 04-11-2013, 05:05 AM
sundownz's Avatar
Originally Posted by yelnatsch517 View Post
Can someone post the TS specs of the Z series V4 so we don't have to register on another site?
Thanks!!
All of the Z v.4 T/S specs aren't published yet as we did some tweaking for production compared to prototypes -- all of the complete specs will start to roll out some time in May as will the full production X T/S specs (they are a bit different from the prototypes specs posted).
- Jacob Fuller
sundownz is offline
post #32 of 56 Old 04-11-2013, 05:41 AM
carp's Avatar
Quoted: 168 Post(s)
Liked: 410
Originally Posted by sundownz View Post
We aren't ready to release any solid information but the SI HT line will grow to include some bigger drivers; Nick will be the one to come out with that information when it's available. When they are ready they will be more optimized for the HT realm than Sundown products.
I know you said Nick will have the details later, but do you know if "bigger drivers" means 21" drivers or does it mean heavier 18" drivers with a higher x-max?
carp is online now
post #33 of 56 Old 04-11-2013, 07:23 AM
sundownz's Avatar
We'll announce what is coming a bit down the line. As of right now there is no information ready to release.
- Jacob Fuller
sundownz is offline
post #34 of 56 Old 04-11-2013, 09:05 AM
carp's Avatar
Quoted: 168 Post(s)
Liked: 410
carp is online now
post #35 of 56 Old 04-11-2013, 09:28 AM
Looneybomber's Avatar
Depending on final TSP's these look to be good candidates for LLT's; good xmax, but an xlim nearly twice the xmax. The need for a subsonic filter becomes less of a requirement. I won't get any, because I'm one of those inductance snobs, but these could be good for some folks.
YID DIY
Looneybomber is offline
post #36 of 56 Old 04-11-2013, 10:04 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 131 Post(s)
Liked: 632
Sure. Although the current SI 18's are already well suited for LLT use. Whether or not one wants to use a HPF is up to them. I have never used one on mine.
My Dual 18" LLT subs 120dB down to 10hz
Plan9Reloaded Co-host
Listen to the Plan9Reloaded Gaming and Technology Podcast (may contain NSFW language)
https://soundcloud.com/plan9reloaded/sets/podcast - direct pod link
http://plan9reloaded.com/site/ - main website
Scott Simonian is offline
post #37 of 56 Old 04-11-2013, 01:15 PM
LTD02's Avatar
Quoted: 112 Post(s)
Liked: 835
nice bit on inductance by sundownz:
http://www.caraudio.com/forums/sundown-audio/534072-shorting-rings-why-do-we-use-them.html
i'd be interested to hear your thinking on what if any effects remain in the scenario where:
1. inductance is made linear with respect to coil position with shorting rings and pole sleeves, and
2. any frequency effects of energy storage in the bass are eq'd out
is there then any difference (other than the low pass filtering effects) between a driver with a low inductance and one with a high inductance?
Listen. It's All Good.
LTD02 is online now
post #38 of 56 Old 04-11-2013, 02:16 PM
noah katz's Avatar
Quoted: 81 Post(s)
Liked: 133
Very interesting and informative with nice graphs clearly showing the effects of different motor designs.
Picking a nit though:
".. the field can be absorbed by a conductive material in or around the coil -- so shorting rings come into play."
A magnetic field is not absorbed by a non-magnetic conductor.
I believe the way it works is that a conductive ring acts as a 1-turn electromagnet whose field opposes that induced by the coil current, canceling the inductance modulation it causes.
Noah
noah katz is online now
post #39 of 56 Old 04-11-2013, 02:29 PM
Bass Enabler
Quoted: 131 Post(s)
Liked: 632
is there then any different (other than the low pass filtering effects) between a driver with a low inductance and one with a high inductance?
Excellent write-up!
post #40 of 56 Old 04-11-2013, 02:53 PM
tuxedocivic's Avatar
Quoted: 154 Post(s)
Liked: 426
Zaph often tests Le(x) on the drivers he tests. But he only tests small drivers. I should give it a try on my sub and see if I can show any inductance change with x position.
A great write up that is actually useful on the subject.
tuxedocivic is online now
post #41 of 56 Old 04-11-2013, 02:54 PM - Thread Starter
zagnutty's Avatar
Jacob, I'm considering a 10 or 12 inch driver for my home setup. But here's the catch. This isn't mainly for HT use. I use my gear for about 95% music and 5% movies. I don't even currently have any surround speakers at the moment.
My mains are Infinity IL40's. Some big towers with 8in woofers that cleanly play down t0 the 30-35Hz range with ample output, sometimes too much to be honest (contrary to some reviews saying they lack in this area). How can I expect one of these to perform from 30Hz on down? I'm looking for clean and articulate. From what I'm reading, these are some stiff beasts, so my natural assumption is that they will be relatively articulate. Is this a fair assumption and can I expect them to perform as a SQ sub as opposed to a SPL sub? But I also want it to be able to deliver some "nice" output really down low where some HT material exists. My absolute limit on a driver is where the X 12in sits, that is $300. I actually would prefer a 10 due to size limitations I have for the enclosure.
Aaron
zagnutty is offline
post #42 of 56 Old 04-11-2013, 03:45 PM
noah katz's Avatar
Quoted: 81 Post(s)
Liked: 133
Originally Posted by zagnutty View Post
...these are some stiff beasts, so my natural assumption is that they will be relatively articulate. Is this a fair assumption...
IMO no.
Not that they wouldn't be, but I don't see how stiffness is relevant.
Noah
post #43 of 56 Old 04-11-2013, 06:43 PM
Not to put down these speakers, but, for musicality these would not be my first choice. I would instead go after something with a low Le and supple suspension, which is the opposite of what these drivers have to offer. Maybe 2, 12" dayton audio HF's?
YID DIY
post #44 of 56 Old 04-12-2013, 05:39 PM - Thread Starter
zagnutty's Avatar
Originally Posted by noah katz View Post
IMO no.
Thanks guys. My first choice was a Dayton HF actually. It's still at the top of the list. Curious how a TC Epic would compare to the HF.
zagnutty is offline
post #45 of 56 Old 03-02-2014, 01:19 AM
tritiumglo's Avatar
Liked: 32
Well, they are out now. They are $410 each for a 15.
Specs:
Product Description
X-15 D2:
1250 watts RMS
Re : 3.68 ohms
Fs : 20.51 Hz
Qes : 0.42
Qms : 4.81
Qts : 0.39
Le : 4.00 mH
Sd : 729 cm^2
Vas : 107 L
BL : 21.79 NA
Mms : 422 g
Cms : 142 uM/N
Sens : 85.17 dB 1w/1m
The sensitivity is low. The xmax isn't listed but I read 4" peak to peak. Designed for extension. I doubt it can beat an IDMAX for SQ but I am most curious.
NAD M15 /NAD M25 / PSB STRATUS GOLD / PSB STRATUS 6C /DENON AVR 3300/CARVER TFM 45/35 - ANTHEM MCA3/NAD T163
IDMAX 12INFINITY RS3 / POLK MONITOR 10/ALTEC 501 / INTEGRA 50.3/PARADIGM DSP 3400 / GOLDENEAR AON3
An Observer of many philosophies, a slave to none.
tritiumglo is offline
post #46 of 56 Old 03-02-2014, 03:17 AM
chrapladm's Avatar
Quoted: 44 Post(s)
Liked: 56
Xmax was listed as 30mm by 70% Bl and 50mm mechanical clearance. I would love to have a ZV4 with softer suspension but the X series are better value in my eyes. $409 for the X-15 and 585 for the 15" ZV4. These subs wont be the best SQ drivers but good enough for me and below 60hz. I would get a pro audio driver or other over a IDMax for SQ.
And Jacob or Sundown if your reading this I never got a response to my email I sent you. Is there a number I could call or another place to send an email?
chrapladm is online now
post #47 of 56 Old 03-02-2014, 03:48 AM
tritiumglo's Avatar
Liked: 32
Im looking for a 15 or 18 that plays 40hz and down. The advertised purpose of this sub is extension. I may try one. Maybe an 18. I am disappointed that there are no sealed/vented box recommendations on their web site.
post #48 of 56 Old 03-02-2014, 03:50 AM
notnyt's Avatar
Quoted: 73 Post(s)
Liked: 333
They post full specs, model your own.
EDIT: Oh, jesus, they have full sketchup drawings of boxes for you.
http://www.sundownaudio.com/index.php/products/subwoofers/item/x-series.html "Box Specs and Cut Sheets"
notnyt is online now
post #49 of 56 Old 03-02-2014, 05:47 AM
chrapladm's Avatar
Quoted: 44 Post(s)
Liked: 56
Just happen to be modelling the X15 and ZV4 15. Both like a 1.75cuft sealed cabinet.
Wow I have been to their site so many times and never clicked on the box designs. Pretty awesome find.
post #50 of 56 Old 03-02-2014, 05:50 AM
tritiumglo's Avatar
Liked: 32
That is a good find. The link that has enclosure recommendations is blank.
The box spec and cut sheet is where the goodies are. Missed that. thx.
post #51 of 56 Old 03-03-2014, 07:14 AM
MemX's Avatar
Liked: 45
Dammit, I was reading through this and thought that SI were releasing new HT drivers! Then I realised the posts were from this time last year... :facepalm: lol
MemX is offline
post #52 of 56 Old 07-04-2014, 05:22 AM
TimVG's Avatar
Lookie what I did
notnyt likes this.
TimVG is offline
post #53 of 56 Old 07-04-2014, 07:58 AM
d_c
d_c's Avatar
Liked: 55
Nice! That is a beefy surround. I'm guessing you are powering it with the clone?
d_c is offline
post #54 of 56 Old 07-04-2014, 09:51 AM
TimVG's Avatar
For now yes, I'll be getting a serviced Crown K2 next week on trial, if it does the job I'll use that one. The clone is normally used to power 4 dual opposed subs.
TimVG is offline
post #55 of 56 Old 07-04-2014, 11:08 AM
tritiumglo's Avatar
Liked: 32
Very nice.
How do you like the performance of the sub? Does it have good extension as SA claims?
post #56 of 56 Old 07-04-2014, 11:15 AM
TimVG's Avatar
Very nice.
This is a great driver, very well built and ditto performance. The stroke this thing can produce is incredible.
I've owned two ported 2012 captivators, currently own 4 dual opposed subs with eigth 12" drivers in total. And this thing still amazed me when I let it cut loose. Tuning is around ~14hz (actually 16hz, but I used enough dampening material to counter port and box resonances, this lowered the tuning and overall efficiency a bit).
TimVG is offline
User Tag List
