New Sundown X Series drivers - Wow! - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1 of 62 Old 04-09-2013, 03:33 PM - Thread Starter
zagnutty's Avatar
Has anyone seen these things!? Their monsters! Pretty freakin beefy at 45-51lbs (10in to 18in).
And I quote -
"Linear x-max is around ~30mm one-way by 70% BL with a total mechanical clearance of 50mm in the motor."
10 is $280 and 18in is $350. If these things perform as good as they look, there's a serious new player in the "bang for your buck" category! ETA on them is June 30th.
Found TS specs -
http://www.emfcaraudio.com/x-series/
Pics of them -
http://forum.realmofexcursion.com/sundown-audio/76701-sundown-x-10-x-15-x-18-prototypes-here.html
Haven't had a chance to model in Bass Box. I'm not good at telling how good a driver is just by looking at specs, so any input on how these specs look?
zagnutty is offline
post #2 of 62 Old 04-09-2013, 03:36 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5282 Post(s)
Liked: 4167
Sweet! Specs look decent enough to me. The d4 reminds me of my RLp18d4's specs. Inductance is a little high-ish but we've been spoiled by some fine fine low Le drivers recently but overall not too bad and close to a preferable 1:1 Re/Le ratio. Just looking at the specs it looks like they will model well in medium to large enclosures. I'll plug in the numbers to Unibox now.
Scott Simonian is online now
post #3 of 62 Old 04-09-2013, 03:40 PM - Thread Starter
zagnutty's Avatar
I'm doing some rough modelling on some drivers for another member right now (roughly 20 drivers...ugh). So I won't be able to play with these numbers until later. But these do look quite nice for the price. $300 for a 12in driver like that....I might have to find a way to increase my new sub budget.
zagnutty is offline
post #4 of 62 Old 04-09-2013, 03:40 PM
Bass Enabler
Liked: 4167
Looks very good in a 6cuft sealed! (18d4 I mean)
post #5 of 62 Old 04-09-2013, 04:25 PM
eXa
eXa's Avatar
eXa is offline
post #6 of 62 Old 04-09-2013, 04:54 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1038
Specs look pretty good, though they are hella ugly. That surround looks like an ass pillow for roids. I would not want that looking at me every time I fired up a movie! lol
N8DOGG is offline
post #7 of 62 Old 04-09-2013, 05:35 PM
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Rebel975 is online now
post #8 of 62 Old 04-09-2013, 06:48 PM
sundownz's Avatar
Quoted: 27 Post(s)
Liked: 38
Didn't notice this earlier; glad to see you guys taking note While they are designed primarily for car usage there is no reason they cannot be used in a home environment and with the much lower than typical Fs for a car woofer would likely excel for movies and whatnot. The trend in car audio these days is to "kill the lows" so we've designed our newer lines around that.
The surround is the most "controversial" part of the driver I suppose -- but they are there for a reason. Each surround is sized for the frame platform it mates to (they get larger as the cone diameter / frame clearance / spider diameter increases) and is designed to support 5mm more excursion than the frame can support so that we don't see surround failures from over-excursion even at full frame x-mech. It's also pretty linear -- I had the Z v.4 15" prototype Klippel tested (early prototype with a bit less x-max) :
http://www.diymobileaudio.com/forum/klippel-reviews-driver-specs/141047-sundown-z-v-4-15-klippel-test.html
Same suspension as the X line -- but stiffer for the higher power. The Klippel wasn't able to resolve the absolute suspension limits (typically defined as 50% shift) -- but you can imagine based on the graph as it's only shifted ~15-20% over about 60mm p-p (30mm one-way) stroke. The Z v.4 should also jump up to about 35mm by BL for production with the modifications we made; and the X should measure right around 30mm. The Z v.4 may be a bit too stiff for HT applications, though.
The suspension "platform" of cone and spider are designed with future designs in mind that will push 40-50mm of linear excursion.
I've had a few folks a little concerned over reduced SD figures; in reality it's only about 10% off on Sd from a standard roll so not a huge deal. We've been doing some pretty hard prototype testing in-car of the new drivers with a Z v.4 12" in a Volkswagen Golf -- that setup peaks at 25 Hz and achieves 145.5 dB at that frequency with a measured 1950 watts of power. So where displacement is key (low frequency) the driver excels -- we can see the trade-off of some Sd for incredibly high mechanical travel was well worth it.
In any event; I could answer any other questions that you guys may have if you like.
- Jacob Fuller
sundownz is offline
post #9 of 62 Old 04-09-2013, 06:52 PM
stormwind13's Avatar
Quoted: 60 Post(s)
Liked: 96
Already dreaming of big tapped horn designs, i'm sure lilmike will take a look and let us all know!
stormwind13 is offline
post #10 of 62 Old 04-09-2013, 06:59 PM
brian6751's Avatar
Quoted: 878 Post(s)
Liked: 673
they can handle 1250 watts rms? Dang! Scott can you post some models? how about this driver in a 18" up against two SI 18's.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
post #11 of 62 Old 04-09-2013, 07:08 PM
sundownz's Avatar
Quoted: 27 Post(s)
Liked: 38
We use very conservative power ratings due to how the car audio market works (everyone runs an amp 2x bigger than what we suggest and at 0.5 ohm) -- the coil is a 60mm long 3" CCAW round wire coil on aluminum former; so the 1250-watt rating is very conservative.
Also -- just to keep all the facts in line; those are pre-order prices -- the regular prices are ~15-16% higher.
You can still pick up 2x SI HT 18s for about the cost of 1x X-18 driver at regular price.
On that note -- the SI HT line will also be expanding to include some beefier drivers as well as time goes on -- so stay tuned on that smile.gif
- Jacob Fuller
sundownz is offline
post #12 of 62 Old 04-09-2013, 07:45 PM
mayhem13's Avatar
Quoted: 43 Post(s)
T/S specs for Sd are subject......the surround is nearly 1/4 the drivers total area.....should be more like 850 cm/2 or less for the 18's.
mayhem13 is offline
post #13 of 62 Old 04-09-2013, 07:53 PM
Bass Enabler
Liked: 4167
Sure. In a little bit. They model very similar to the SI HT 18's but with more rated travel.
Bombelman likes this.
post #14 of 62 Old 04-09-2013, 11:13 PM - Thread Starter
zagnutty's Avatar
Thanks for chiming in Mr. Sundown!
I come from a car audio background. I've always believed there is absolutely no reason a car sub can't be used in home. As long as it specs good at least.
I have a very good friend who used to work for TC a few years back. I remember him showing me some of their subs (before they hit the market...hehehe), and also stopping by with a W7 when they first came out. So a giant surround like this doesn't surprise me in the least and I don't care how it looks. Function over form! I came across these earlier today. Before I even saw the specs, I could tell they were built to be used...and used hard. And then I saw the price. I almost fell out of my chair! If you guys can truly deliver these at those prices, I have a feeling that the home audio DIY guys are going to love you!
These look awesome and I'm already stashing money away to grab one or two 10's or 12's. Just yesterday I was considering a TC Epic. Well, I think that idea has been tossed.
I am really interested in how these will compare to a similarly sized TC Ultra. Equal, or better performance, for a third of the price?
zagnutty is offline
post #15 of 62 Old 04-10-2013, 05:37 AM
sundownz's Avatar
Quoted: 27 Post(s)
Liked: 38
Nothing suspect about it ; it is calculated using 1/2 the surround as Sd :
"The effective radiation area SD is one of the most important loudspeaker parameters because it determines the
acoustical output (SPL, sound power) and efficiency of the transducer. This parameter is usually derived from the
geometrical size of the radiator considering the diameter of half the surround area. "
* SOURCE *
http://www.klippel.de/uploads/media/Dynamical_measurement_SD_Klippel_Schlechter.pdf
This paper is primarily about micro-speakers (where that definition doesn't apply) but does introduce itself with the standard definition of Sd =)
- Jacob Fuller
sundownz is offline
post #16 of 62 Old 04-10-2013, 06:28 AM
Ricci's Avatar
Quoted: 184 Post(s)
Liked: 472
You guys are slipping around here. These have been talked about in car audio forums for a few months already.
Ricci is offline
post #17 of 62 Old 04-10-2013, 07:54 AM
brian6751's Avatar
Quoted: 878 Post(s)
Liked: 673
So is it safe to model these at 2500 watts ?
Rivers Edge Theater
post #18 of 62 Old 04-10-2013, 08:22 AM
sundownz's Avatar
Quoted: 27 Post(s)
Liked: 38
We do rated them 1250 RMS so I don't typically go around telling folks to run 2x that to them for obvious reasons smile.gif
BUT you won't mechanically hurt anything until 4" p-p and there is really no way to "accidentally" thermal this unit with the coil size and motor ventilation present. Based on my experience in car audio I won't say it's impossible to damage them even on a 1250 watt amp used completely improperly / poor box configuration -- but anyone paying ANY attention whatsoever should be okay to utilize an amp rated for 2500-watts.
- Jacob Fuller
sundownz is offline
post #19 of 62 Old 04-10-2013, 11:37 AM
Point Source
beastaudio's Avatar
Quoted: 3495 Post(s)
Liked: 2826
Not me dude, I actually got to see one in action smile.gifsmile.gif meheheheh
beastaudio is offline
post #20 of 62 Old 04-10-2013, 12:30 PM
Ricci's Avatar
Quoted: 184 Post(s)
Liked: 472
Jake,
Do you have any further news on when these and the new ZV4's might be on hand?
i just thought it was odd there wasn't a thread on this here yet.
Ricci is offline
post #21 of 62 Old 04-10-2013, 01:23 PM
sundownz's Avatar
Quoted: 27 Post(s)
Liked: 38
The ETA is by the end of June on the X and Z v.4 drivers. They may come in a bit earlier in June but we are being conservative and saying end of June.
- Jacob Fuller
sundownz is offline
post #22 of 62 Old 04-10-2013, 01:32 PM
yelnatsch517's Avatar
Can someone post the TS specs of the Z series V4 so we don't have to register on another site?
Thanks!!
yelnatsch517 is offline
post #23 of 62 Old 04-10-2013, 01:59 PM
financethis's Avatar
bringin back the fat surrounds but with a twist of tall. "big and tall"
look bad ass. will they be a run at the SI 18s ??
epson 3010 projector
marantz 1402 avr
infinity beta mains, center and surrounds
110" dalite screen
tc sounds pro 5100 subwoofers
financethis is offline
post #24 of 62 Old 04-10-2013, 02:21 PM
BassThatHz's Avatar
Quoted: 2031 Post(s)
Liked: 1547
I'm looking forward to the X and Zv.4
After I finish my quad LMS-18 build, if it still isn't loud enough, I may just have to add 8 of these sundown's biggrin.gif
BassThatHz is offline
post #25 of 62 Old 04-10-2013, 06:42 PM
Quoted: 60 Post(s)
Liked: 96
Your neighbors will hate you!
post #26 of 62 Old 04-10-2013, 07:42 PM
realtight's Avatar
Quoted: 18 Post(s)
Liked: 49
The Sundown Audio X18 models almost exactly the same as the old AVA18 and Malestrom-X drivers except it needs more power and more excursion to achieve the same spl. Are these drivers rated to be pushed past their rated xmax? If they can be pushed to 40mm then they can squeeze out 2db of spl... that is great for the price! If not, why the Godzilla surrounds? Protection from abuse?
How do these drivers SOUND? Are they meant only for SPL or do they sound as good as maybe the above mentioned drivers?
realtight is offline
post #27 of 62 Old 04-10-2013, 10:47 PM
Bigus's Avatar
Quoted: 196 Post(s)
Liked: 222
More excursion to produce the same spl... because of slightly lower SD?
Bigus is online now
post #28 of 62 Old 04-10-2013, 11:27 PM
Looneybomber's Avatar
Liked: 25
Must be.
(x) surface area * (y) excursion * (w) frequency = (z)dB
Reduce x, y, or w and z also drops.
YID DIY
Looneybomber is offline
post #29 of 62 Old 04-11-2013, 06:01 AM
sundownz's Avatar
Quoted: 27 Post(s)
Liked: 38
As I mentioned above; there is no real thread of physical damage until about 50mm one-way (coil bottom)
Pushing to 40mm certainly won't hurt the driver.
As far as sound; they are a clean driver -- but they don't have any super fancy technology other than incredibly high capacity suspension. THD from BL and Suspension is low -- but they don't have any inductive treatments. I will get Klippel on production units as well.
The entire suspension system is designed for drivers with higher capacity than the X line (Z v.4 / upcoming NS v.3 / future designs) -- so there is more capacity than the X line needs in the parts.
- Jacob Fuller
sundownz is offline
post #30 of 62 Old 04-11-2013, 06:04 AM
sundownz's Avatar
Quoted: 27 Post(s)
Liked: 38
These are not designed to compete with the SI HT line (I am a part of that project). They are a part of the Sundown car audio line. If one is so inclined they could be put into an HT application, though.
We aren't ready to release any solid information but the SI HT line will grow to include some bigger drivers; Nick will be the one to come out with that information when it's available. When they are ready they will be more optimized for the HT realm than Sundown products.
Dollar to displacement I believe the SI HT units are a bit better bang to buck; naturally this is to be expected as Sundown is a dealer based line and SI is a direct to public line. The SI HT units are also designed specifically for HT rather than simply "also working" in HT.
- Jacob Fuller
sundownz is offline
