need advice for dual front fire 18" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 04-09-2013, 06:13 PM - Thread Starter
Seppelrator's Avatar
Hi currently I´m building my new home theatre and decided to go diy to get more performance for my money.
Thinking of a dual front fire design.
I never did this before so your help is much appreciated.
Use is only HT and my goal is about 15Hz.
After what I read 18" Dayton HO would be good way to go?!
Most likely 2 8ft³ cabinets so 4x18" daytons or is this way to much for my room? 14x11x7ft but open to one side. Does sombody know a simple design for this?
What amp would suit this project best? Was thinking of two EP4000 or Inuke or one of these china FP14000/10000q?
Thanks for your advice.
Seppelrator is offline
post #2 of 16 Old 04-09-2013, 06:22 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
8ft3 will not be suitable for a pair of 18s tuned to 15hz. That will work for a sealed pair... How big is the open area to your room?
Jay1 is offline
post #3 of 16 Old 04-09-2013, 06:36 PM - Thread Starter
Here is a quick drawing:
post #4 of 16 Old 04-09-2013, 07:29 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Your subs are going to attempt to pressurize that entire area. You might be better off with 4 subs, 2 front 2 rear, but of course you might not be able to place them in the rear (depending on your room setup).
8ft3 is a good size for a single driver ported sub tuned low, and there's a few drivers that will work well in such an alignment. You will need something like a miniDSP to act as a high pass filter. If you decide on sealed subs, you will also need something like a miniDSP to EQ the response flat.
Jay1 is offline
post #5 of 16 Old 04-09-2013, 08:15 PM - Thread Starter
Thanks for your help.
I think sealed would be better for my room as it is not that big or just 2 ported subs?
2 single subs in the rear could be a little difficult because of the limited space between my couch and the walls (about 22" each side). Not the best placement, is it?
post #6 of 16 Old 04-09-2013, 09:00 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
you could build 2 dual opposed boxes and place them up front, you still get 4 drivers that way and it may be easier for you to place them. Gorilla83 built 4 dual opposed but i heard them when he only had 2 running, his space is similar in size and shape and they had no issues filling the space
his thread - he used the Dayton 18s
http://www.avsforum.com/t/1435795/first-diy-project-for-a-guy-looking-to-upgrade-multiple-sealed-18s
Sibuna is offline
post #7 of 16 Old 04-10-2013, 09:07 AM - Thread Starter
Yes dual opposed would be possible too but I would prefer the look of 2 drivers in the front.
Would I loose performance if I go this way?
post #8 of 16 Old 04-10-2013, 09:21 AM
mastermaybe's Avatar
Quoted: 362 Post(s)
Liked: 306
This is what I did:
Loads of output to 15hz in a 3500^3 area.
James
Actual phone call (see pic to left):
Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
post #9 of 16 Old 04-10-2013, 05:53 PM - Thread Starter
Hi James,
this is exactly what I want to buid. Would you be so kind and give me more information of your subs?
post #10 of 16 Old 04-10-2013, 07:27 PM
Dank1209's Avatar
Sepp. Click on his name then profile then threads started. It's called 72 hrs $1000 bucks ....that's James build thread iirc
Seppelrator likes this.
Dank1209 is offline
post #11 of 16 Old 04-10-2013, 08:20 PM
Bill Fitzmaurice's Avatar
Liked: 4630
Originally Posted by Seppelrator View Post
Yes dual opposed would be possible too but I would prefer the look of 2 drivers in the front. Would I loose performance if I go this way?
You would. Dual 18s will create a lot of motive force, and what will move is the sub. Either go with four singles or if you must have duals make them dual opposed, which cancels that motive force. I'd do singles, the more subs you have and the wider you spread them apart the smoother the in room response.
Bill Fitzmaurice is offline
post #12 of 16 Old 04-11-2013, 09:19 AM
Quoted: 362 Post(s)
Liked: 306
^ Yes, I suppose all being equal front facing is not ideal, but I've yet to see mine move a centimeter on a hardwood floor with rubber feet- the cabinet itself feels pretty inert as well. I suppose a 160lb cabinet and sensible feet help in the movement dept.
James
post #13 of 16 Old 04-11-2013, 01:52 PM
Liked: 4630
Keeping the volume reasonable doesn't hurt either. But not everyone does so.
post #14 of 16 Old 04-11-2013, 03:05 PM
noah katz's Avatar
Quoted: 880 Post(s)
Liked: 304
re enough volume for ported, even if it's not enough to be optimal, you can still get more output capability if you have the power for it.
Noah
noah katz is offline
post #15 of 16 Old 04-11-2013, 06:14 PM - Thread Starter
I work in the states this week so I just picked up a Cerwin Vega CV5000 for 700$.
I think I can not to wrong with this amp. Still not sure if single or dual front or dual opp or even ported like Noah suggested.
The looks of a dual front sub would be awesome but only if the the performance loss is not too big.?
post #16 of 16 Old 04-12-2013, 12:47 PM
noah katz's Avatar
Quoted: 880 Post(s)
Liked: 304
Just to be clear, I was suggesting that it *might* be viable; use a modeling program to investigate.
Noah
