FTW 21" pre-orders - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #151 of 176 Old 09-28-2013, 07:54 AM
fredfish's Avatar
Quoted: 25 Post(s)
They model so close that it's almost a wash. These would drop-in just fine in an enclosure that was made for the first gen FTW-21.
Nothing's built yet, but I have already settled on the final design. Just wondered if I would have to model again.
fredfish is offline
post #152 of 176 Old 09-28-2013, 08:17 AM
vinodk's Avatar
Quoted: 87 Post(s)
Liked: 33
Looking for an amp to drive 2 of these soon. Whats the minimum power these will need in 6cuft sealed enclosure in approx 2600sqft room for good spl & performance? I am looking at Crown XLS2500 which is rated at 775 watts into 4 ohm load. Wondering if that's going to be enough.
Vinod
vinodk is offline
post #153 of 176 Old 09-28-2013, 09:39 AM
chrapladm's Avatar
Quoted: 944 Post(s)
Liked: 351
I would say a minimum of 1500watts rms is what you want. Minimum. More wattage the better.
chrapladm is offline
post #154 of 176 Old 09-28-2013, 11:13 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5972 Post(s)
Liked: 5036
That's what I was thinking. wink.gif Great ready for some bass!
Sho nuff.
While 1,500w is a good goal you could still get away with less if you have to.
Scott Simonian is offline
post #155 of 176 Old 09-28-2013, 06:03 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 356
That will not be enough power in my opinion. I would not use anything less than a inuke 6000 which was bench tested at 2000 watts @4ohms per channel. And my ftw 21s will send it into clipping during loud playback.
Swolephile is offline
post #156 of 176 Old 09-28-2013, 07:23 PM
vinodk's Avatar
Quoted: 87 Post(s)
Liked: 33
My only concern is fan noise from the amps because the amp will in the rack in theater room. Crown XLS amps are very quiet.
Vinod
vinodk is offline
post #157 of 176 Old 09-28-2013, 10:26 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 356
You can always do a fan mod on the inuke 6000. The ftw 21s can take alot of power oand mine even took a clone 14k amp with no problem.
post #158 of 176 Old 09-30-2013, 10:59 PM
audiovideoholic's Avatar
Quoted: 654 Post(s)
Liked: 216
You will need twice that for just a couple for sure. You're going to be clipping amps before the subs start moving half of what they are capable of moving! TRUST me I have a bunch of these!
audiovideoholic is offline
post #159 of 176 Old 10-01-2013, 06:56 AM
vinodk's Avatar
Quoted: 87 Post(s)
Liked: 33
Guess I will get couple of Crown XLS1500 amps & bridge them. They put out 1500watts at 4 ohm bridged.
Vinod
vinodk is offline
post #160 of 176 Old 10-01-2013, 07:47 AM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 356
i still dont think those amps wil be enough for the ftw 21s.
post #161 of 176 Old 10-02-2013, 06:54 PM
zora's Avatar
Quoted: 52 Post(s)
Liked: 57
I'm going to bridge a DCA3422 with mine, does everyone think I have enough amp?
zora is offline
post #162 of 176 Old 10-02-2013, 08:00 PM
chrapladm's Avatar
Quoted: 944 Post(s)
Liked: 351
I have only 1000watts going to each of mine right now. I keep switching out amps for other projects. When listening to music I feel they have plenty of power. I wont be pushing them much past 10mm excursion.. When watching movies the same thing occurs. There is plenty of spl for my smaller sized room. 13x18x9ft. I do enjoy these subs on more wattage such as 3-4000watts but they still sound great on less. YOU just wont reach their full potential on smaller amounts of wattage is all.
So with 3400watts available from your 3422 you should have plenty of power. What size enclosure was this going to be in? If 5cuft then your fine and if larger then that you might have the perfect amount.
post #163 of 176 Old 10-02-2013, 08:10 PM
dominguez1's Avatar
Quoted: 1112 Post(s)
Liked: 976
13x18x9 sealed? How many FTW21's do you have?
dominguez1 is offline
post #164 of 176 Old 10-02-2013, 08:19 PM
chrapladm's Avatar
Quoted: 944 Post(s)
Liked: 351
My room is not sealed and I have a pair of 21's. Also have a very large window that absorbs some of the bass in the room. Not the greatest room for bass but still the 21s work well. I would prefer to have four of them but that is for my wants in chasing down ULF.
post #165 of 176 Old 10-02-2013, 08:57 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
[IMG]
One of two I picked up today.
gpmbc is offline
post #166 of 176 Old 10-02-2013, 08:58 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
SXRDISBEST likes this.
gpmbc is offline
post #167 of 176 Old 10-02-2013, 09:21 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Next to Avalanche 18
gpmbc is offline
post #168 of 176 Old 10-02-2013, 09:31 PM - Thread Starter
N8DOGG's Avatar
Quoted: 1116 Post(s)
Liked: 1218
Looking good!!!!!!!!
N8DOGG is online now
post #169 of 176 Old 10-02-2013, 09:51 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
N8, what did you use to mount the driver since there is no gasket?
gpmbc is offline
post #170 of 176 Old 10-02-2013, 10:47 PM
zora's Avatar
Quoted: 52 Post(s)
Liked: 57
I
I have a dedicated HT room so box size is not an issue (I've had many - currently two CHT 18.2's). I'm thinking a 7-8 cu.ft. box.
zora is offline
post #171 of 176 Old 10-07-2013, 04:20 PM
fredfish's Avatar
Quoted: 25 Post(s)
fredfish is offline
post #172 of 176 Old 10-07-2013, 04:38 PM
Bass Enabler
Liked: 5036
Originally Posted by gpmbc View Post
[IMG]
post #173 of 176 Old 11-18-2013, 07:58 PM
Seppelrator's Avatar
Finally fished my Subs today! Take a look
Seppelrator is offline
post #174 of 176 Old 11-18-2013, 09:11 PM - Thread Starter
N8DOGG's Avatar
Liked: 1218
So what do you think so far????
post #175 of 176 Old 11-19-2013, 01:38 PM
Didn't habe much time to test but so far they are impressive. Want to break them in first and then I'll see what those monsters can do ;-)
post #176 of 176 Old 11-19-2013, 01:45 PM
filtor1's Avatar
Quoted: 213 Post(s)
Liked: 166
They look huge! I really like the color too!
filtor1 is offline
