HORRIBLE ground Loop problem with EP4000/Cap 2400 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 39 Old 04-16-2013, 04:08 PM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1550
Originally Posted by ratm View Post
just the sub.
Well that's good. So with an iPod connected to the sub amp, does it create a hum or not?
I assume you have an mini to rca cable and that the iPod can even drive an EP4000 (LOL).
Also, if your AVR has pre-outs, you could connect the EP4000 to the Left or Right pre-outs, and see if that hums too or if it is just the sub-out port.
BassThatHz is offline
post #32 of 39 Old 04-16-2013, 05:45 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2575
http://www.jensentransformers.com/
this is what bfm is talking about when he says use a transformer.
the device uses two windings of coil to pass the signal electro-magnetically from one device to another without actually making a physical contact, thus breaking the ground loop and eliminating the hum.
http://www.jensentransformers.com/datashts/sub1rr.pdf
http://www.jensentransformers.com/sub1rr.html
everything you ever want (or don't) to know about ground loops:
http://www.jensen-transformers.com/an/generic%20seminar.pdf
i'm not sure if there are less expensive options once you isolate the particular connection that is causing the problem.
Listen. It's All Good.
LTD02 is offline
post #33 of 39 Old 04-18-2013, 07:36 AM - Thread Starter
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
OK, so I narrowed down at least 75% of the hum to my DirecTv box. As soon as I unplugged that HDMI connection, I lost at least 75% of the hum. It is still there, but I have to get to within about a foot of the Cap to hear it. My next step is to buy one of these. A. Can I buy that from a typical electronics store? B. Someone on here posted that it doesnt work with DirecTV? C. If B isnt accurate and it does work with DirecTV, does it matter where I connect it in the line? It comes into my house and then is split to all the other rooms.
I am also going to buy another surge protector strip with a Coax ground connection like Mark S suggested.
ratm is offline
post #34 of 39 Old 04-18-2013, 08:34 AM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 674
do you get the same reduction when you disconnect the coax from the Direct TV box? how about when you unplug the power from the Direct TV box? I was getting a hum from my projector and used one of those Hum-X adapters. worked great.
i dont think that filter will work because its the wrong bandwidth. i would try this one instead: http://www.soontai.com/2G-isolator.htm
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #35 of 39 Old 04-18-2013, 08:45 AM - Thread Starter
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
So far all that I have done was Unplug the HDMI cable from the back of my AVR. I'll try unplugging and disconnecting the coax when I get home.
ratm is offline
post #36 of 39 Old 04-19-2013, 10:37 AM - Thread Starter
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
what bandwith should i be looking for?
ratm is offline
post #37 of 39 Old 04-19-2013, 11:06 AM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 674
i beleive Direct TV is 5 -2.3 GHz
Rivers Edge Theater
post #38 of 39 Old 04-19-2013, 12:02 PM - Thread Starter
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
ratm is offline
post #39 of 39 Old 04-19-2013, 12:09 PM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 674
http://www.mcmelectronics.com/product/DISTRIBUTED-BY-MCM-4170-/33-8700 this one is 5 - 2.4, would that work?
i would give it a shot. im actually going to order one as well. i have not tried one but from what i have read, that is the bandwidth needed for it to work. the other ones will knock out your signal. there is actually a comment on that page about using it successfully with Direct TV (DTV)
Rivers Edge Theater
