DIY sealed sub enclosure question.. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-17-2013, 06:52 AM - Thread Starter
NickThatStands's Avatar
Okay, its kind of dumb on part to wait till now to ask.. Do i need to screw together a flatpack from DIY soundgroup? Or is Just wood glue, followed by some PL premium to seal it going to be enough? I basically have the first box all glued together, and the second (not a flat pack from Eric, was lucky enough to have my CNC buddy make me one for basically free), about halfway glued together. Should I be putting some screws in this thing before i move on to sanding/painting?
If its not necessary, then i wont.. But if it is, now is the time for me to be doing it i would think rolleyes.gif
Ive went from looking for a better sub i could buy for my home theater in a box, to building dual 18" subs myself in my little one bedroom apartment, and i blame the people in these forums for it biggrin.gif
Thanks for the help!
NickThatStands is offline
post #2 of 3 Old 04-17-2013, 07:16 AM
Sibuna's Avatar
Quoted: 377 Post(s)
Liked: 432
you dont need to nail/screw. Glue & PL should be all you need
if the one your buddy made for you does not hae rabbit joints like the flatpack then a brad nailer can help keep things from moving around as you glue and clamp but its not needed
Sibuna is offline
post #3 of 3 Old 04-17-2013, 07:22 AM - Thread Starter
Alright, good to know. Then Im making progress. I basically have the first one glued all up and the second one about halfway there. Im hoping my duratex will be shipping out today or tomorrow.
Thanks for the help
