FTW 21 ported design questions - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By phasewolf
Old 04-23-2013, 08:33 PM - Thread Starter
fredfish's Avatar
Quoted: 25 Post(s)
I'm looking for advice on a ported design for this driver. I've searched and other than mention that it likes 25 to 30 cf I have not found anything.
Room: Small poured concrete bunker (aka apartment). main room, 20x20x8
Design considerations:
- flat down to 12 - 15 Hz at 115db
- No highpass filter required
Design style: sonotube (3rd story of a 3 floor walk-up, no 400 lb refrigerators allowed smile.gif)
I've been playing with WINISD and have looked at 3 sizes tuned to 12 or 15 Hz: 20cf 22cf and 25cf. Larger than that will not work.
Given the stupendous room gain I get in my 'bunker' flat to 12 Hz is probably a non issue even at 20cf and 15 Hz tune.
Port velocity and the first resonance is a concern.
First question. For a 10" port (lets assume flaired) what is the max velocity before turbulence occurs? I'm guessing max velocity will go up as port size increases. I've done some searching, but there does not seem to be any definitive answer on port size and velocity.
At 25cf and 12 Hz tuning a 10" port would be 28 meters/sec at max power, 20 m/sec at 600w. I'm guessing I'll never get near max power, but don't know. With a flared port, is 28 m/sec acceptable?
Anything smaller than 25cf it looks like I'm forced to go to a 15 Hz tuning to avoid port resonance and velocity issues.
Tuning:
Can I get away without a highpass filter with a 15Hz tune? That would make port length and the first resonance more manageable (between 170 and 220 Hz for the three volumes) What is the lowest acceptable 1st port resonance assuming an 80Hz crossover?
Driver and port clearance:
I understand I will need a minimum of 10" clearance for the port, what about the driver? With an 8' ceiling, I was guessing a max tube length of 6.5' to give proper port and driver clearance.
Anybody know the volume for this driver?
fredfish is offline
Old 04-23-2013, 10:49 PM
zora's Avatar
Quoted: 48 Post(s)
Liked: 51
Just out of curiosity, with amp power cheap these days and the stated massive room gain you have - why not go with a sealed box? It would be much smaller, easier to build, and (to some) sound better.
Jim
zora is online now
Old 04-23-2013, 11:20 PM - Thread Starter
fredfish's Avatar
Quoted: 25 Post(s)
a 10 cf sealed sub would be down 18 db at 12 Hz. I think that would be a little much for my room to overcome. With 1,200 w of power handling, I don't know how much room I have to apply EQ.
My current sub has an f3 of 27 Hz and should be down 12 db at 22 Hz. In fact it plays flat to about 21 Hz.
The idea of a sealed sub is appealing, though it would be fun to watch my landlords eyes bug out when I hauled 6.5' of 28" sonotube into my apartment biggrin.gif
fredfish is offline
Old 04-24-2013, 12:04 AM
zora's Avatar
Quoted: 48 Post(s)
Liked: 51
I don't think you have as much LFE lift as you think. The FTW-21 in a 10 cu.ft. box should have a gentle slope, which combined with room gain should be impressive. My CHT 18.2 subs are 3db down in the high 30's and get me flat to around 10hz with a little eq. The FTW-21 should be able to handle much more than 1,200 watts on a short term basis (in a sealed box).
Jim
zora is online now
Old 04-24-2013, 12:57 AM - Thread Starter
fredfish's Avatar
Quoted: 25 Post(s)
Why do you say that?
I don't understand driver power handling, but I thought that the number the manufacturers gave, in this case 1,200w, was the max safe power you could apply before coils started to burn.
fredfish is offline
Old 04-24-2013, 01:18 AM
Looneybomber's Avatar
Liked: 25
There's thermal and mechanical limits. Reach either of those and your speaker will not be happy and might even die. Now, thermal limits are a little enigmas. For example, and I am just making up numbers, but it might be something where the driver can handle 1.2kW for 10 seconds at 20hz, but maybe only 700W for 10 seconds at 300Hz due to a decrease in air moving over the coil from less excursion. That might also mean it can handle 3kW for 1 second at 50Hz or maybe 8kW for 50ms? It's all about keeping the voice coil under a certain temperature and it can only wick away heat so fast, but hard transients may mean sending 2-3kW peaks for a very short duration, around 40-50ms with maybe 10-20x of minimal power where that heat can be wicked away.
A voice coil's temp acts similar to a rectangle function (input signal) convolved with a decaying exponential (heat sinking ability). This results in the voice coil temp being the blue line.
YID DIY
Looneybomber is offline
Old 04-24-2013, 06:20 PM - Thread Starter
fredfish's Avatar
Quoted: 25 Post(s)
Thanks for the reply Bomber. If that peak is above what the driver can handle, bad things may happen, correct? That is what I thought the manufacturers power handling number was an indicator of.
fredfish is offline
Old 04-24-2013, 06:29 PM - Thread Starter
fredfish's Avatar
Quoted: 25 Post(s)
I thought I would post some graphs. Here is a 25 cf enclosure, 1,200w applied. You can see that with a 10" port, the first port resonance is awfully low.
Here's the port velocity:
Doing the image capture, I noticed that at 12Hz the port velocity is not that bad. How often do you suppose there is going to be 10Hz content? Is a peak velocity of 26 m/s going to cause audible chuffing with a 10" flared port?
fredfish is offline
Old 04-24-2013, 06:40 PM - Thread Starter
fredfish's Avatar
Quoted: 25 Post(s)
Here is 10 cd sealed.
Just how much extra power is this sub going to need in a sealed configuration to play flat to 12-15 Hz?
fredfish is offline
Old 04-26-2013, 09:40 PM
Liked: 25
Well, yes and no. Yes it's an indicator of how much power it can handle, as in a ball-park idea. If one woofer was rated for 100w and another 1000w, which one do you think will likely be able to handle more power? Ok, I realize that's a stupid question, but what I am getting at is a speaker can easily handle more than it's RMS or peak value, but the length of time it can handle that amount of power becomes very short, maybe tens of milliseconds! But, a hard kick drum beat is centered between 60-65Hz. A single cycle (think delta function at that frequency), is only 1/60Hz or 17ms. So it's possible for a speaker rated at 1000w peak to be able to handle a 2-3kW transient at 60Hz provided it stays within its mechanical limits. If a manufacture tested a speaker to 2-3kW in 10mS pulses and said it was rated at a peak of 2.5kW and a person played dub step at that level, it'd cook the speaker and there would be a warranty claim. If a manufacture says a speaker is then rated at 700W rms 1000w peak, but it can handle 3-4kW transients, then that company won't have very many cooked speakers for warranty.
YID DIY
Old 04-26-2013, 09:44 PM
Liked: 25
That box is either too small, or tuned too low. That transfer function does not look that great. Remember folks, an 18" in an LLT is going to need 16-25ft^3, a 21 is going to need 20-30ft of space, more if you want to tune below the teens! Don't be scared of a big box, that's why it's called LARGE low tuned.biggrin.gif
*edit*
Ok, I had to model this driver. 35ft tuned to 13Hz looks pretty good. Feed it 2kW and you will not run out of mechanical excursion. >120db from 13Hz on.
YID DIY
Old 04-26-2013, 10:12 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1038
N8DOGG is online now
Old 04-27-2013, 07:52 AM
Ricci's Avatar
Quoted: 184 Post(s)
Liked: 472
Nice visual...
Ricci is offline
Old 04-28-2013, 08:08 PM - Thread Starter
fredfish's Avatar
Quoted: 25 Post(s)
Well, I've booked the driver before I talk myself out of it again. I can't see a better opportunity than this coming along for a guy north of the 49th.
*edit*
Its not the not the box that scares me per se. It the three floors up in a narrow stairwell that scares me. smile.gif I would have to haul sonotube up over the balcony
I could get up close to 30cf with 30" diameter sonotube but that's starting to occupy a lot of space. Hmm... you know, with a few tapcon screws I could just strap that sucker to the ceiling. biggrin.gif
OTOH, I'm probably moving in a year, so a sealed sub would be a little more sensible.
It sounds like power handling is not going to be an issue.
On the ported option, I still have a number of questions:
1. How low a 1st port resonance is acceptable?
2. For a 10" port is a port velocity approaching 35 m/s acceptable? What is my practical limit here?
fredfish is offline
Old 04-28-2013, 09:06 PM
Liked: 25
Ooohhhh. Well, if mobility is at all a priority, you can build a sealed enclosure with sonotube to save weight.
1) Normally at least 1 octave above your tuning point, but I like to play it safe and say about 1.5 octaves. (Close to 3x the XO frequency)
2) I don't know. I know as the port gets bigger, the acceptable port velocity also increases. You could try it and see?
YID DIY
Old 04-30-2013, 08:05 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
I didn't know that! (but I am noob tongue.gif)
I thought one should aim for <25 m/s, generally speaking?
MemX is offline
Old 04-30-2013, 08:52 AM
Liked: 25
I'll have to find the website again, but a guy tested multiple port sizes and flares at different frequencies. It was found that flares help, but only so much - they couldn't make up for a well undersized port. It was also found that the largest port - 6" I think - was able to have a good bit higher port velocity before audibility compared to much smaller ports.
YID DIY
Old 05-01-2013, 07:14 PM - Thread Starter
fredfish's Avatar
Quoted: 25 Post(s)
Bomber. Is this the site?
He only went up to 6" ports so I don't know how that translates to larger ports.
I'm still pondering the advantages/disadvantages of a sealed build.
fredfish is offline
Old 12-13-2014, 11:45 AM
Quoted: 93 Post(s)
Liked: 30
Anyone ever build a ported ftw21? I have one sealed now and want another.
I have some old / extra plywood and could experiment with a slot ported box or just build another sealed.
Curious how it would perform compared to sealed. Or even how a sealed and a ported might blend together. I could go up to 40 cf or so.. I now have a umik-1 that I am learning how to measure with.
cellarnoise is online now
Old 12-13-2014, 10:46 PM
phasewolf's Avatar
Quoted: 14 Post(s)
I am going to be building a ported FTW21 soon when I get my driver in the mail. I am planing on going with 30cf box tuned to 12hz and build a second one when money hits my account someday (hoping soon) Not sure if that tune is the best idea I may need to play with that a lot more time will tell.
I want a port tuned low enough that I can skip a High pass filter but am still unsure how low that needs to be.
For some reason my wife thinks it will look fine in the front room even after I told her how large it will be so I need to do this fast before she really gets a grip of what she said yes too...
Fatshaft and popalock like this.
phasewolf is offline
Old 12-14-2014, 08:56 PM
Quoted: 109 Post(s)
Liked: 30
For some reason my wife thinks it will look fine in the front room even after I told her how large it will be so I need to do this fast before she really gets a grip of what she said yes too...[/QUOTE]
Get it built fast!
Mine was on board with 4 Johnny subs and her tune changed when I moved them inside.
The subs seemed pretty normal size in the garage with nothing to compare them with but bringing them inside for the first time the size of everything really hit me. Especially lining the four of the up against a wall for 102 inches of subs.
jake515 is online now
Old 12-14-2014, 09:21 PM
Samps's Avatar
Quoted: 787 Post(s)
Liked: 413
You need to get a movie on a-sap once the subs get moved in. Once they feel the couch vibrate they're hooked just like us.
Samps is online now
Old 12-14-2014, 09:38 PM
Quoted: 93 Post(s)
Liked: 30
I added 4 aura butt-shakers a year ago. 4 hooked up to 1 channel of an inuke 3000dsp with eq has been great. It equaled one sealed FTW-21 in impact believe it or not...
That said, I just ordered a second ftw-21. I do get some effect from the 21 below 12 hz, and I want more, but I have had ported subs in the past and also seem to want more impact from 20 hz to 40 hz. I am really thinking about building a crap ported ftw-21 to add to the one 6.3 cf sealed ftw-21 I have now. Just to see if I am missing in the area where the ported would be pumped up.
I just ripped out a wall in my basement to build a relatively dead recording room that can be connected to my compromised theater room and office space. I don't mind being on a long term upgrade path and will probably add more subs, amps, and upgrade my cheap mains over time. It is a lot of fun to learn and build new over time.
I am a bit upset with myself for not adding more power to the front of my theater room during construction. I am adding multiple dedicated 20 and 30 amp lines to the recording space, but wish I had added more to the small theater room. It is designed to be added to, which I may remove panels and add a few 30 amp lines or even 30 amp / 240 lines before I black out around my cheap do-board screen in triple black velvet this next year.
My wife does not care so much as long as I go way overboard trying to keep the shaking to the basement. That is not easy though as the single sub in the basement can start lifting the main floor rather easily...
I have a few already cut pieces of 4x4 3/4 inch plywood, so I may build a slot ported 32 cf total (30 cf after port?) cabinet to test the ported vs. sealed FTW-21 subs. If the sub gets here within a week, I can have either another sealed or a new ported sub completed by the New Year.
