For a 3-way surround speaker, are there issues in a W-T/M layout? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-24-2013, 07:24 AM - Thread Starter
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
I'm planning to upgrade my HT (and m-ch music) system from having coax 5.0 to 3-way speakers.
To do the surrounds in the same 3-way would result in a fairly tall rear speaker, which I'd like to avoid.
So two questions:
- are there any issues with a more horizontal layout (effectively removing one woofer from the centre)
- in the image the dark part is of course the slot port; with a couch against the back wall these will be placed to the side; what would be the best order for the layout (the image shows port next to wall, woofer next to port, T/M furthest)
rick240 is offline
post #2 of 5 Old 04-24-2013, 07:27 AM
tuxedocivic's Avatar
Quoted: 1915 Post(s)
Liked: 1738
You've got it right. The only issue I can imagine is if your mid is whimsy and needs to be crossed relatively high, like 800hz and up.
Ryan
tuxedocivic is offline
post #3 of 5 Old 04-24-2013, 07:32 AM - Thread Starter
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
I'm targeting somewhere in the 400 - 600 for woofer to mid xo; the CTC for the two woofers in the centre will dictate how high is possible.
rick240 is offline
post #4 of 5 Old 04-24-2013, 05:01 PM
Liked: 1738
Correct. You're using an 8" woofer so I think you'll be good with up to 600 no problem. Have the designer give it some thought though.
Ryan
post #5 of 5 Old 04-24-2013, 10:16 PM - Thread Starter
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
Actually may go smaller - considering the Seas L16...
...but still too early in the learning process to be committing to drivers yet.
I think i might try to find a 6-8" with higher sensitivity.
rick240 is offline
