Economics of DIY Subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 04-25-2013, 09:06 AM - Thread Starter
tampa frank's Avatar
I've been reading through all of the projects in this forum. I'm a big do-it-yourselfer and always eager to get the best bang for the buck. I'm interested in building a sub, but was wondering if the economics really work out. I've done a lot of projects that ended up costing almost the same as what I was trying to avoid in the first place:rolleyes:. I'm consdering a simple 15" sub to add some punch to my HT. I'm pretty competent with woodworking (enough to build a box, not furniture grade-though).
Could I build something better for less money than some of the mid priced subs (i.e. Hsu) out there? Going even cheaper, could you build a better sub for $300 than the Klipsch RW-12?
tampa frank is offline
post #2 of 17 Old 04-25-2013, 09:19 AM
lennon_68's Avatar
My personal opinion is that if price/performance is your only draw to DIY it will be difficult to justify on a budget below around $600. Once your budget is at/over this point DIY can really take off though. I suppose there are obvious exceptions with the horn designs floating around but as an oversimplified rule it works for me smile.gif
The reason for the ~$600 point is that it allows room for spending ~$300 on a beefy rack amp that could power several subwoofers and still leave room in the budget for a good driver (or drivers) and the enclosure. Once you have that beefy amp in the budget the equation isn't even fair.
As a specific example the sub in my avatar includes a Behringer EP2500 and 4 AE IB15 drivers in an infinite baffle setup - total invested ~$900 and nothing commercial will touch it for at least a couple thousand dollars.
lennon_68 is offline
post #3 of 17 Old 04-25-2013, 09:19 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
You can actually MURDER any of the subwoofers from Klipsch, but not in $300. But having said that, the cost won't pinch you once you hear a properly assmbled, powered, and tuned DIY sub. In fact, you'd love to make the hole bigger in your pocket from that point on.
Edit: I've used KSW-10, SUB-12, SW-112, SW-115, Def Tech SuperCube Reference. Still own SUB-12 and SW-115 and they both are collecting dust in the store room mad.gif
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #4 of 17 Old 04-25-2013, 09:48 AM
benunc's Avatar
I think the cheapest HSUs are around $500-600; I think you could build a 15" sub around that price range that could outperform those 10"-12" subs. You can't build anything for under $300 that would best the Klipsch though.
benunc is offline
post #5 of 17 Old 04-25-2013, 10:00 AM
Bill Fitzmaurice's Avatar
Liked: 4750
Originally Posted by braveheart123 View Post
You can actually MURDER any of the subwoofers from Klipsch, but not in $300. :
Both my THT and lilmikes F20 can come in at $300, including an amp, for subs that would send an RW-12 running home crying for his mama. Watch for sales on drivers and amps and you could build a reflex box for $300 that would beat the RW-12 too.
Bill Fitzmaurice is online now
post #6 of 17 Old 04-25-2013, 10:04 AM
benunc's Avatar
Ha, I stand corrected.
benunc is offline
post #7 of 17 Old 04-25-2013, 10:05 AM
brian6751's Avatar
Quoted: 908 Post(s)
Liked: 716
like Bill said. those folded horns are the output per dollar champs as long as you have room for them. not sure how many of those klipsch subs you would need to match their performance, but i bet you dont have room for them either biggrin.gif
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
post #8 of 17 Old 04-25-2013, 12:48 PM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 150
It all depends what you mean by "best" the Klipsch... I'll include form factor as well.
Per teh spec sheet:
ENCLOSURE TYPE Bass-reflex via front-firing CornerPort™
ACTIVE DRIVERS 12" (30.5cm) Cerametallic™ cone, front-firing woofer
AMPLIFIER TYPE BASH® Digital hybrid
AMPLIFIER POWER FTC Rated Power: 350 watts continuous @ <2% THD / Dynamic Power*: 825 watts
BANDWIDTH 24-120Hz ± –3dB
MAXIMUM OUTPUT 116dB @ 30Hz 1/8 space, 1m
CONTROLS DCS control and feature set w/ 3 system presets
INPUTS L/R Line-level RCA jacks, L/R High-level speaker binding posts
Focusing on bolded specs, 24Hz -3dB point (aka F3) and 116dB @ 30Hz, but in 1/8 space, i.e. corner loaded. I'll work with an infinite baffle sensitivity, and so predict a 1/2 space SPL. Given that 1/8 is 1/2 cubed (8 = 2 x 2 x 2), and each doubling in free air is worth 6 dB, the 1/2 space equivalent SPL is 104dB@30Hz, 1m. Klipsch box size comes out about 2.5 cu ft...
Option 1
BASH 300 with Umax 12. $119 + $158 leaves some money for a box... a 2.5 cu ft sealed box.
30Hz output is 105dB (louder)
F3 is 33Hz (higher) but...
F10 is 19Hz and the Klipsch is also 19Hz
and a sealed box can take more power, and extend deeper.
Option 2
BASH 300 with Umax 10. $119 + $144 in a 2.5 cu ft ported box
30Hz output is 106dB (louder)
F3 is 18Hz (lower than Klipsch F10)
... and you can tune even lower, trading 30Hz output for greater extension.
Of course, in DIY the biggest savings is your labor, which is where you can't beat the $300 mark... but if labor is free, it's not hard.
HAve fun,
Frank
fbov is offline
post #9 of 17 Old 04-25-2013, 12:59 PM - Thread Starter
Oh boy- That Tuba HT looks amazing!eek.gif It looks like it doesn't take much of an amp to run it which helps on cost. I could use an end table...
Once I move, I think that I am building one of these. I have plenty of time (probably 2-3 months) to research drivers and amps. Can you give me suggestions of drivers and amps to look out for in case of a good sale?
post #10 of 17 Old 04-25-2013, 01:05 PM
benunc's Avatar
Originally Posted by fbov View Post
Option 1
Option 2
HAve fun,
Frank
Of course there's also the wood, glue, screws, polyfill, paint, woodfiller, speaker wire, sandpaper, and any tools needed that you don't have (i.e. clamps, power tools). I lost track of how much I spent on all that little stuff but it adds up..... certainly more than enough to bring your $277 and $263 builds well over the $300 mark.
benunc is offline
post #11 of 17 Old 04-25-2013, 01:38 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Bash 300 + Infinity 1260 + 4" PVC + sheet of MDF/glue/bondo/paint in 4ft3 20hz tuned box = $250, with more output and a true 20hz response. Now you can compare with the $600 ID subs, for less then the price of the Klipsch.
Jay1 is offline
post #12 of 17 Old 04-25-2013, 01:42 PM
mtg90's Avatar
Quoted: 417 Post(s)
Liked: 793
Some other options below the $300 mark:
This driver: http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-190
This amp: http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-750
Leaves you $60 to build a 6-7cuft box tuned to 18-22hz.
Option 2:
This driver: http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-185
Same amp as above.
Build a 3-3.5 cuft box tuned to 20-24hz, can use one of these at full length for that: http://www.parts-express.com/pe/showdetl.cfm?partnumber=268-352
Drivers and amp are on sale so now is a good time to save some $$
mtg90 is online now
post #13 of 17 Old 04-25-2013, 02:01 PM
benunc's Avatar
Yeah, I guess that works. I didn't realize you could get a decent driver for $60.
benunc is offline
post #14 of 17 Old 04-25-2013, 03:02 PM
BeerParty's Avatar
The recommended driver for the THT should be listed on Bill's THT page. I believe the plans list alternative drivers for the THT (edit - just checked Bill's site, he states that the plans include a list of alternate drivers appropriate for the plans). He also has a forum that will have several build threads that used different drivers in his designs. For the amp, read a couple of build threads and see what other people are using. Horns don't need a lot of power so you will not have to spend a lot on an amp if you don't want to.
If you are serious about building Bill's THT, I suggest you purchase the plans and review them. I also recommend you make a cardboard mock-up of the box and put it in your final location: for some reason dimensions doesn't seem 'big' until you see the final result in person (I learned that one the hard way with another project). Then start reading his forums and the build threads here for the THT, there is LOTS of useful info out there.
Chris
--Despair, Inc. "Regret"
My AviaTrix TM Build
BeerParty is offline
post #15 of 17 Old 04-25-2013, 03:51 PM
LTD02's Avatar
Quoted: 2350 Post(s)
Liked: 2587
the f20 is tuned a little lower, which is a little better for home theater.
there are also some tapped horns with about a 20hz or so corner that might be worth taking a look at.
horns are big, but they increase sensitivity and spl per amount of driver excursion.
most bass for the buck. the tradeoff is their size and in some sense extension below their tuning frequency.
Listen. It's All Good.
LTD02 is offline
post #16 of 17 Old 04-26-2013, 06:43 AM - Thread Starter
Great- thanks. I've been reading up on Bill's sight. I plan to order plans, but need to decide which version to get first. The Tuba HT seems awesome, and I think that I could use it as an end table or maybe a TV stand. Then again, the Table Tuba might work out better. Since I don't know what my HT space will be yet (haven't picked a new house), it is impossible to know what will work and what won't at this time. I might just buy the Bash 300W amp while it is on sale and hold off on everything else.
post #17 of 17 Old 04-26-2013, 11:45 AM
brian6751's Avatar
Quoted: 908 Post(s)
Liked: 716
you might be better off waiting till youre in the new space. no sense in building one of those beasts, having to move it to a new house, then finding it doesnt fit.
i made 2 of them and discovered they wouldnt fit ...............
Rivers Edge Theater
