Alpha-12 vs Fusion-15? - AVS Forum | Home Theater Discussions And Reviews
Old 04-27-2013, 12:39 AM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Sorry if this has been posted before. I did a couple searches and didn't really find anything.
I currently have an Eton S7 kit. I had Madisound create a crossover/cabinet design for a MTM version, thinking that I would build these to fill out my HT. However, it makes me nervous that I'd be the only one to have ever built them.
Given how easy it is to assemble the flat packs I'm seriously considering replacing the S7's with some SEOS kits and filling out the HT with them instead. Plus, there are actual build threads/reviews on these, which makes me feel better about it.
If it matters, I currently have one of EricH's flat packs assembled and waiting for a UXL-18 to arrive. I plan on having 2-3 more of them in the future (powered by 1-2 CV5000's).
Anyways- Any thoughts on the Alpha-12 vs the Fusion-15? They've very similar in price.
Rebel975 is offline
Old 04-27-2013, 08:44 AM
tuxedocivic's Avatar
Quoted: 1912 Post(s)
Liked: 1735
Well, one is larger than the other, if that matters. They both have a different look because of the driver sizes. I personally prefer the look of the smaller woofer, but others like the massiveness of the larger woofer. In general I think the fusion 15 will have an edge on output.
Otherwise I'm not sure they're very different.
Ryan
tuxedocivic is offline
Old 04-27-2013, 09:04 AM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
if you are running with subs the difference will be minimal. i have the Fusion 12 and have heard the 15s if you are running fill range the 15s will have more output but not by a lot
Sibuna is offline
Old 04-27-2013, 10:52 AM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
I definitely will be running with at least one sub, and up to as many as 4. With that in mind, I guess the Alpha-12 is the way to go?
The only question I have now is- would it be a downgrade, upgrade, or side step from the SQ of the S7 kit? I know that's an impossible question, as there probably isn't anyone who has heard both.
Rebel975 is offline
Old 04-27-2013, 12:24 PM
brian6751's Avatar
Quoted: 908 Post(s)
Liked: 704
if using a sub, also keep the Fusion Tempest in mind
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
Old 04-27-2013, 12:34 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
I looked at it, but gravitated towards the Alpha-12 and Fusion-15 for the more expensive woofers.
Rebel975 is offline
