TD15M - SEOS12 - BMS4550 / theater progress / Dual TD6M - SEOS12 - BMS4550 build. :D - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 315 Old 05-22-2013, 02:34 PM
tuxedocivic's Avatar
Quoted: 1907 Post(s)
Liked: 1728
Maybe passive components in the active position then. Tiny little parts will cost you less, and you can relax knowing there's no digital manipulation going on.
Ryan
tuxedocivic is online now
post #182 of 315 Old 05-22-2013, 02:53 PM
yelnatsch517's Avatar
Originally Posted by hometheaterdoc View Post
Active has real benefits..... and every active crossover/EQ device I've ever used imparts it's own sonic signature on things....... and usually not in a good way.... I've yet to hear one that was sonically transparent.... you end up making different compromises compared to passive... mostly it comes down to whether there is enough positive with the active device to outweigh its negative sonic attributes...
as with anything, it's about the system synergy and what else is in the complete audio chain from start to finish.... running a $20 Aiwa DVD player as source into a $99 receiver with with certain compromised speaker designs is likely not a candidate for a $400 single cap in the speakers' crossover network....
Were the active crossover/EQ devices you used using an analog input?
I'd imagine that doing all EQ in the digital domain first before going through a DAC would have improvements over the conventional: source->dac->amp->crossover->speaker design.
Essentially it should be: source->EQ->dac->amp->speaker
NOT
source->dac->adc->EQ->dac->amp->speaker
This is where HTPC and JRiver + Audiolense,Acourate, etc comes into play.
I would think this kind of setup would be more accurate than the conventional crossover just like SS amps are more accurate than tube amps.
It's only a matter of time before it catches on. I mean, this is how recording studios work to begin with. If there is any "sonic signature" from this setup, every single digital source would have a "sonic signature."
yelnatsch517 is offline
post #183 of 315 Old 05-22-2013, 05:41 PM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Yelnatsch517- how would it be possible to do something like that? I believe that NAD offers a music streamer or some sort of devise that keeps everything digital through the entire signal chain. Any suggestions on components and specific brands and models to do this the optimal way that you suggest? Is there a way to do this without spending tons of cash?
Martycool007 is offline
post #184 of 315 Old 05-22-2013, 07:41 PM
Desertdome would be the member to ask about all this. I just recently started looking into this from something he mentioned and it just made sense to me.
The most versatile option that I know of would be to go through an HTPC + JRiver combination.
I really like this method because it is a one time setup cost. Any changes in speakers later one wouldn't require entire new component costs, just tweaking the EQ parameters in the digital domain.
This is a HUGE plus for people who often change speakers, I would imagine. So even something like a few thousand dollars would be less as compared to purchasing parts for many crossovers.
post #185 of 315 Old 05-22-2013, 07:44 PM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 785
All the info for both of these designs including the TD15M-4 + DNA-360/SEOS-12 design can now be found in the DIY Sound Group forums under the SEOS Speaker Designs category.
mtg90 is online now
post #186 of 315 Old 05-22-2013, 07:46 PM
Quoted: 280 Post(s)
Liked: 176
What is a HTPC? Home theater personal computer? How would that make this possible? I need to do some more research on this, but from what I currently understand, you can get music from a computer through something like the JRiver or NAD, and keep it in the digital domain all the way until it gets to the speakers, but I don't believe that this is possible with movies as the technology is not there yet.
post #187 of 315 Old 05-22-2013, 09:26 PM
You can use JRiver to play any media including movies. If I were building a setup, I would have JRiver set to duplicate each channel 3 times, ie. 3x left channel, 3x right channel, etc. I would then EQ each channel individually and send those to a dac, which would go to an amp and then to corresponding speaker drivers.
Using this method, you literally have an infinite number of possibilities and you can essentially create a custom crossover personalized for YOUR room. This will be better than any generalized crossover design for a passive speaker since the active crossover is tailored specifically.
Not to mention, you can achieve 48dB/ octave crossover. Try designing one of those using passive components.
post #188 of 315 Old 05-22-2013, 10:16 PM - Thread Starter
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
I really debated going active seeing as I have a 7 channel amp that I could have used. Maybe down the road I will. At this point I felt more comfortable going active. It was my decision to upgrade the parts, and decision I feel would be worth the investment. After how much more this build cost than originally anticipated; I would have regretted cheaping out on the xover.
I was supposed to be off today, but got called into work; so I was running around like crazy trying to get things finished up before the weekend. I have company coming into town for the holiday and I am bond and determined to have this thing up and running. Even if it kills me. biggrin.gif
My height cabs are pretty much done other than paint. They aren't perfect, but they are functional and will be hidden behind the screen wall so I doubt I'll lose too much sleep over it. The part that really screws with my OCD is the fact I glued my baffle on a hair bit crooked. I'm off over a 1/16" of an inch which really drives me crazy. cool.gif
I also got the equipment rack pretty much completely wired up. When I build the rack I didn't plan on putting 2 EP4000's in there. I had to remove the rubber feet to get them to fit, and even then it was really, really freaking close.
The main cabs are pretty much finished up. I just barely had enough Duratex to put two layers on them. The Duratex container is almost clean enough to eat out of after scraping everything out of it I could. biggrin.gif All that's left is to wire them up, add some fluffy stuff, and install the xover.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #189 of 315 Old 05-23-2013, 09:57 AM
brian6751's Avatar
Quoted: 885 Post(s)
Liked: 679
looking great!! i always have projects im wrapping up minutes before company comes over as well. wife hates that! dont underestimate how long it takes to get the cabs insulated and wired up. you know that though!! cool.gif
you going to have room to tow those mains in? might have to remove some bass trapping or whatever that is
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
post #190 of 315 Old 05-23-2013, 10:11 AM
Liked: 1728
Looking fantastic. Still excited to hear about your broken jaw.
Ryan
post #191 of 315 Old 05-23-2013, 10:37 AM - Thread Starter
Quoted: 360 Post(s)
Liked: 437
I should. It's a close fit between these and my corner traps. It's tough to tell from the pics, but they are towed in quite a bit right now. I probably won't go crazy extreme (towed to intersect in front of listener) due to running two rows, but it should be plenty sufficient.
I'll be sure to include my current medical report with my listening impressions. biggrin.gif
post #192 of 315 Old 05-24-2013, 12:00 AM - Thread Starter
Quoted: 360 Post(s)
Liked: 437
Not much to report tonight. I did manage to get my TD6 enclosures painted. Just slapped on some flat black paint and called it a day. The cabs still have a couple of minor flaws that could have been sanded out, but once again, they are going behind my screen wall. That being said, they will still pass most peoples inspection. smile.gif
post #193 of 315 Old 05-24-2013, 09:26 AM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 785
I think they look great!
mtg90 is online now
post #194 of 315 Old 05-24-2013, 10:26 AM - Thread Starter
Quoted: 360 Post(s)
Liked: 437
post #195 of 315 Old 05-24-2013, 11:43 AM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
Sibuna is offline
post #196 of 315 Old 05-24-2013, 11:54 AM - Thread Starter
Quoted: 360 Post(s)
Liked: 437
Originally Posted by Sibuna View Post
agree those do look nice
Thanks. I'm stoked. Matt's gift basket biggrin.gif just showed up so I'll be wiring, and soldering tonight. With any luck I'll have them up and running by tomorrow evening.
post #197 of 315 Old 05-24-2013, 12:01 PM
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
Looking stellar. Great build. Thanks to Matt for posting the Xover as well and making another option available.
We should listen to see if we can hear (or feel) each other's build testing this weekend.
bhazard is offline
post #198 of 315 Old 05-24-2013, 01:20 PM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
Got to love this point in a project - so close to listening! Another in agreement here that they're turning out fantastic!
Gorilla83 is online now
post #199 of 315 Old 05-24-2013, 01:34 PM
Liked: 1728
Ryan
post #200 of 315 Old 05-24-2013, 02:06 PM
robotbunny's Avatar
Man, BA, this build reeks awesomeness! Now, mount those beautiful TD6's in there and let'em rip!
robotbunny is offline
post #201 of 315 Old 05-24-2013, 06:40 PM
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
If my build testing I'm doing right now is any indication of what you will be hearing with your AE woofers and 4550, you're going to be blown away. I'm loving it right now.
bhazard is offline
post #202 of 315 Old 05-24-2013, 09:44 PM - Thread Starter
Quoted: 360 Post(s)
Liked: 437
I'll have to take your word for it. I for the life of me can't find my terminal plugs. mad.gif I don't know where the heck I put them. That's about the only thing left and I can get these things mounted up.
post #203 of 315 Old 05-24-2013, 09:50 PM
Liked: 1728
Ryan
post #204 of 315 Old 05-24-2013, 10:05 PM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 785
Or drill a small hole in the back where you are going to mount them just large enough to fish the wire through then apply just enough hot glue to seal the hole. You could even use masking tape to seal it up by using two pieces applied from opposite sides and pressed together around the wire.
mtg90 is online now
post #205 of 315 Old 05-24-2013, 11:28 PM - Thread Starter
Quoted: 360 Post(s)
Liked: 437
Thanks, I found them. Only thing worse than losing them, is spending 1-1/2 hours looking, only to find them 5' from where I thought they were. cool.gif
In the meantime I decided to tear down (literally), my old height mounts and try and stuff these giants into place. Well after a whole lot of fiberglass cutting (I'm itching like a mofo now), I think I can rig up a system to make them work perfectly. They just happen to squeeze in between the beam where my screen will go and the ceiling. I'll just mount a board on top of the screen brace and anchor these to it at the appropriate angle. Tight squeeze but she'll make it. Weather stripping installed and cabs are stuffed and ready to go. Tomorrow night I'll let my wife entertain company while I get them wired up and dropped into place. biggrin.gif
post #206 of 315 Old 05-25-2013, 06:14 AM
Quoted: 280 Post(s)
Liked: 176
With regards to the JRiver that you mentioned, I don't believe that you can get Bluray quality sound out of this JRiver component. If you could, then I would be all over it.
post #207 of 315 Old 05-25-2013, 08:15 AM
pnw
pnw's Avatar
Quoted: 47 Post(s)
Liked: 76
JRiver is capable of really excellent SQ with BR. I recently switched to JR + a good DAC straight to the power amps & found that my "old" player + pre-pro based system was actually limiting SQ. JR has come a long way in the past few years.
pnw is online now
post #208 of 315 Old 05-25-2013, 08:29 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Seems as if I'm seeing JRiver implementation mentioned everywhere these days.
Interesting ...
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #209 of 315 Old 05-25-2013, 11:51 AM
Any reason why you would think this? It is straight lossless LPCM to the external DAC through USB.
JRiver is just software. How you use it in conjunction with hardware is up to the individual.
The key being that JRiver has parametric EQ and 64 bit native convolution engine, or you can use plugins like Audiolense for FIR filter room correction.
This is something impossible with passive crossovers.
Trust me, I'd consider myself a perfectionist when it comes to these things. If JRiver wasn't capable of the highest quality sound, I wouldn't even bother mentioning it.
The DAC that you use will determine the SQ of your system. Before that, everything is pure digital so nothing, absolutely nothing, is lost.
And, like I said, if someone is going to spend a few hundred or thousand dollars on crossover components, I'd personally recommend investing in a high quality DAC instead, like the Mytek 8X192.
You could even build DIY DAC, ie. Twisted Pear Audio Buffalo III.
For active crossover duty, you'd need more channels so something like the Orion 32 channel DAC could work, but the THD being only -98dB is a little troubling for me, again only because I'm a perfectionist.
I would prefer something in the -110dB range, which I have yet to find.
Sorry bassaddict for being offtopic.
post #210 of 315 Old 05-25-2013, 12:31 PM - Thread Starter
Quoted: 360 Post(s)
Liked: 437
LOL. No worries. I would probably be disappointed if a thread didn't get off topic. cool.gif
