just another seos 24 build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 55 Old 05-02-2013, 06:58 PM - Thread Starter
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
seos 24 with bms 4594
distortion
high
mid
summed
no xo no eq
on axis 6 feet away
sadly i have to prep my house to be sold and move on the 10th of next month so i probably wont do anything further then this till then since i would be moving to a much larger space. probably post some pics of the boxs as i a build them for 4 td15m im also modifying 4 td18h boxs to be ported hopefully before the move so i can just move in and set it all up.
cookieattk is offline
post #2 of 55 Old 05-02-2013, 07:18 PM
ChopShop1's Avatar
Quoted: 293 Post(s)
Liked: 289
Originally Posted by cookieattk View Post
seos 24 with bms 4954
distortion
high
mid
summed
no xo no eq
on axis 6 feet away
Sweeeeet!! Those results look really promising..like the SEOS24 were a solid choice! I have to be honest, I was concerned not really knowing how they would measure, so thanks for posting these!
Looking forward to seeing your projects. Good luck in the house move
ChopShop1 is offline
post #3 of 55 Old 05-02-2013, 09:10 PM
tuxedocivic's Avatar
Quoted: 1907 Post(s)
Liked: 1725
Omnimic plots are so hard to read (sorry Bill). Why does it go all jaggy below 1khz? Are these smoothed?
Surprised the HF unit doesn't dig a little deeper. Looks like a natural XO though. Except for tweeter protection, you could almost run those wide open!
Look forward to seeing more.
Ryan
tuxedocivic is offline
post #4 of 55 Old 05-03-2013, 10:07 AM - Thread Starter
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
they are not smoothed 1/48th
post #5 of 55 Old 05-03-2013, 02:06 PM
bwaslo's Avatar
Quoted: 66 Post(s)
Liked: 182
It gets jaggly down low because the software has to allow reflections in at lower frequencies to get anything. you can't measure a 250hz response without looking for at least 1/250 of a second (the period of 1cycle)... and really about 3x that for a decent measurement. So some reflections are going to get in over that time unless you are outside or doing some other setup tricks. Omnimic can window out reflections at higher frequencies but physics wont let you at lower frequencies if the reflection comes in too soon. So Omnimic normally blends in unwindowed response at lower frequencies depending on where the user sets the window edge. Or it can be told to show only the quasianechoic part ( but then lower frequencies show nothing).
___________________________________________
DIY Synergy horn spreadsheet Synergy horn spreadsheet and pdf
XSim -free crossover designer and simulator XSim install file
Easy and cheap sound diffusers (the "Depot Diffusers") making easy DIY depot sound diffuser-panels-step by step.html
SmallSyns - point source controlled directivity in a manageable size SmallSyns
bwaslo is offline
post #6 of 55 Old 05-03-2013, 02:21 PM
Liked: 1725
Oh cool. I didn't know that about omni mic. That's actually a nice feature. Holm and others just taper the windowed portion into nothingness.
These plots make a lot more sense now. Can you adjust the gate down a little lower cokkie? So that it changes at maybe 500hz? Looks like a 500hz XO will be a piece of cake. Now that I understand these FR measurements, this looks really great. I'm looking forward to polars.
I'm jealous of you guys. I make $200 speakers. You make speakers using $200 waveguides tongue.gif
Ryan
post #7 of 55 Old 05-03-2013, 02:36 PM
yelnatsch517's Avatar
BMS 4954? You sure that's the correct model number?
I can't find info on it.
yelnatsch517 is offline
post #8 of 55 Old 05-03-2013, 02:46 PM
ChopShop1's Avatar
Quoted: 293 Post(s)
Liked: 289
It seems like the blind purchase that many of us made is going to work out pretty well. I remember a couple folks stating that one of the guys from Poland said it would be below like 600 or 650 that performance would start to suffer, but it looks like we will be in good shape plenty lower. Mark should have one of mine in the next day or so, if not already. I am anxious to see what he thinks in use too.
post #9 of 55 Old 05-03-2013, 02:46 PM
ChopShop1's Avatar
Quoted: 293 Post(s)
Liked: 289
I think it's a typo...should be 4594
post #10 of 55 Old 05-03-2013, 03:10 PM - Thread Starter
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
its got a low shelf eq to fix the 1.6k area and one other correction at 13k hz no xo and 1/48th
post #11 of 55 Old 05-03-2013, 03:16 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
Very nice!
Face2 is offline
post #12 of 55 Old 05-03-2013, 03:19 PM
Liked: 1725
Wow!
Add an BW2 at 600hz and do what ever is needed to protect the HF, blend in the woofer around a 550hz XO and BAM! Very nice. Hopefully the polars are just as impressive.
Ryan
post #13 of 55 Old 05-03-2013, 07:00 PM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 783
That combo looks very nice indeed.
mtg90 is offline
post #14 of 55 Old 05-03-2013, 07:01 PM
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
I love the topic. Its mentioning it as if so many of these exist. Lol
Any speaker built off this monster waveguide will be a thing of beauty. God bless those that have the space for it.
bhazard is offline
post #15 of 55 Old 05-03-2013, 07:10 PM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
My cornscalas crossed over at 500Hz. It always seemed as though most of the sound was coming from the horn. I'm not sure why. Does getting the woofer and cd to blend become more difficult when crossing the cd over this low?
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
post #16 of 55 Old 05-03-2013, 07:29 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
Erich mentioned in Chop's mega build thread about the SEOS 24 with two 12s under it . Is there gonna be another run of the SEOS 24s, another bms group buy, a passive crossover designed? Just curious about some things lol
gpmbc is online now
post #17 of 55 Old 05-04-2013, 12:57 PM - Thread Starter
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
uhhh ohh all measurements are wrong, besides distortion had my headphones eq in foobar and forgot about them =/ that shelf @ 1.8k hz is made by me : P heres a new graph no eq no xo no smoothing
Gorilla83 likes this.
post #18 of 55 Old 05-04-2013, 01:14 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
Sibuna is offline
post #19 of 55 Old 05-04-2013, 01:38 PM
That is nice!!
post #20 of 55 Old 05-04-2013, 02:08 PM
Liked: 1725
Wow!!! That is nuts.
I was wondering what would be causing that dramatic shelf. Unreal.
Ryan
post #21 of 55 Old 05-04-2013, 06:09 PM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
Holy crap!
Rivers Edge Theater
post #22 of 55 Old 05-04-2013, 07:23 PM
Can you set the lower frequency to 400Hz and reduce the vertical window to show 2dB per division?
post #23 of 55 Old 05-22-2013, 06:14 PM - Thread Starter
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
so i have all weekend to mess with these any measurements u guys want done for these im planning on doing off axis to see how they fair down low anything else anyone wants ?
post #24 of 55 Old 05-22-2013, 06:26 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
take a picture of someone standing next to it or holding it for the lols
Sibuna is offline
post #25 of 55 Old 05-22-2013, 06:29 PM
Liked: 1725
Is there a xo on the MF and HF?
Ryan
post #26 of 55 Old 05-22-2013, 08:36 PM - Thread Starter
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
im using mini dsp 10x10 so yes there is just haven't messed with it much
post #27 of 55 Old 06-04-2013, 07:03 AM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
Cookie - Still using (4) TD15M's with this horn?
Gorilla83 is online now
post #28 of 55 Old 06-04-2013, 09:47 AM - Thread Starter
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
yes still 4 td15m + 4 td18h for mains then 8 fi ib18 in the front wall then 2 uxl 18s behind seating :P
post #29 of 55 Old 06-04-2013, 09:52 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5283 Post(s)
Liked: 4167
Scott Simonian is offline
post #30 of 55 Old 06-04-2013, 11:27 AM
ChopShop1's Avatar
Quoted: 293 Post(s)
Liked: 289
Yeeeeeesssssss
