Lab Gruppen FP14000 gets spanked...by plate amp? - AVS Forum | Home Theater Discussions And Reviews
Old 05-04-2013, 03:06 PM - Thread Starter
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2571
http://www.speakerpower.net/comparative-performance.html
SP1-4000: 4000W into 2 ohms for 6.0 seconds.
FP14000: 1500W into 4 ohms for 0.5 seconds.
Review of SP1-4k: http://www.diyaudio.com/forums/subwoofers/187472-speakerpower-torpedo-sp1-4000-plate-amp-review.html
Listen. It's All Good.
LTD02 is online now
Old 05-04-2013, 03:08 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
cookieattk is offline
Old 05-04-2013, 03:15 PM
yelnatsch517's Avatar
I want to know what the SP1-6000 long term power is at 4ohms.
Those look nice, but the data looks cherry picked. They need to provide information at 2, 4, and 8 ohms for each model.
yelnatsch517 is offline
Old 05-04-2013, 05:33 PM
Dank1209's Avatar
Dank1209 is offline
Old 05-04-2013, 07:55 PM
audiovideoholic's Avatar
Quoted: 588 Post(s)
Liked: 185
Man I've been eyeballing them over the rack mounted amps just because of the price difference.
Biggie for me is what happens below 12hz.
audiovideoholic is offline
Old 05-04-2013, 08:13 PM
lukeamdman's Avatar
Quoted: 1071 Post(s)
Liked: 1187
lukeamdman is offline
Old 05-04-2013, 08:24 PM
Dezmond's Avatar
From the comments from testing the qsc tells me that the fp more then likely did not have enough ac power to put out more. Maybe there is a 1500watt limit when not enough a/c power is available.
"CUTS BACK, BUT NEVERTHERMALS OFF. 2 &4 OHMPOWER WOULD HAVE BEENHIGHER BUT AC SERVICEWAS LOW B/C HOT DAY"
Dezmond is offline
Old 05-04-2013, 09:04 PM - Thread Starter
LTD02's Avatar
Liked: 2571
"fp14k was 1500w at 2, 4, and 8ohm? When's the last time you've seen an amp behave that way?"
that was the medium term power test. the short term power test has the results that will be more familiar, as power goes up as resistance goes down. the problem he obviously ran into is that the 4800 watts into 2 ohm run only held up for...0.08 seconds. that is only 4 cycles of the 50hz test signal, so at that power, there is no "medium term".
LTD02 is online now
Old 05-04-2013, 10:53 PM
More info can be found in this thread:
http://www.avsforum.com/t/1449918/new-speakerpower-rack-mounted-subwoofer-amps
These look really promising and Brian used to design for QSC, I believe.
I would just like more info and measurement confirmed by a third party.
Old 05-05-2013, 04:18 PM
BassThatHz's Avatar
Quoted: 2029 Post(s)
Liked: 1546
I like how he couldn't measure the iTech because it exceeded his rig. LOL
"COULD NOT TEST 2OHMS, DRAWS TOO MUCHPOWER!"
Note: I just reconfigured mine to run at 240v with a dual 20amp breaker (one for each hot wire).
"2 FANS EACH DRAWS 100W! A REAL SCREAMER"
Yes, I've said this at least once before.
Cherry picked to some degree perhaps. Still good results, but I want to see an independent test done by Crown or Gruppen. wink.gif
How many seconds is long-term? We need enough power to get through a 5 minute song.
BassThatHz is offline
Old 05-05-2013, 07:42 PM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 667
FP10000Q Clone was tested 3 years ago and produced 2000W/ch, 2 channels driven @ 40 Hz into 4 ohms continuous (per the tester: "Continuous" means 5 seconds or greater )
bossobass is offline
Old 05-05-2013, 07:45 PM
lukeamdman's Avatar
Liked: 1187
Jeff from JTR, I think, has a real FP7k, and since he uses the Speakerpower amps as well, maybe he can chime in?
I don't think there's any doubt that the Speakerpower amps are the real deal, but the tests on the itech, lab, and pl380 don't look right at all.
Old 05-07-2013, 03:12 PM
MKtheater's Avatar
Quoted: 1588 Post(s)
Liked: 1116
My clone puts out much more power than that.
Marantz 7702 Atmos
MKtheater is online now
Old 05-08-2013, 08:05 PM
notnyt's Avatar
Quoted: 2151 Post(s)
Liked: 1980
notnyt is offline
Old 05-09-2013, 08:22 AM
lukeamdman's Avatar
Liked: 1187
Old 05-09-2013, 09:40 AM
notnyt's Avatar
Liked: 1980
Originally Posted by lukeamdman View Post
lol, 4ohm STEREO can burst over 8kw...that's a far cry from 1,500w...
I believe they were testing 500ms (1/2 second) on 500ms off.
notnyt is offline
Old 05-09-2013, 09:58 AM
Mark Seaton's Avatar
Quoted: 495 Post(s)
Liked: 1288
In the details at the top, a 50A 120/208V line was listed. I believe most of the amps were run at 120V. The SP1-3200 & SP1-6000 were definitely run at 208V, as they need >180-200V to reach the maximum power indicated. You can see that the 3200 & 6000 models converge to match the long term power of the 2400 & 4000 as they are similar designs with different power supplies. Of course in listening no one uses maximum continuous power for 60sec unless the signal is hard clipped the entire time.
Jeff had confirmed to me that the SP1-4k was clearly louder/stronger than one channel of the FP7k as a sub amp.
For the record, Brian from SpeakerPower is an engineer, and a rather poor marketer. The tests posted represent what he feels is the important metrics for a subwoofer amplifier, especially class D type designs where duration of power delivery varies greatly. We saw the efficiency come into play at Gorilla's sub meet where his 5kW Crown popped the breaker while the 3 SubMersive HPs plugged in up front did not.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is offline
Old 05-09-2013, 10:08 AM
Quoted: 495 Post(s)
Liked: 1288
More likely that the properly working protection circuits limit the duration, where the Clones don't, thus allowing more sustained power at 4 Ohms and possible death at 2 Ohms. I know they copied the internal layout pretty exactly. Is the circuit design of the amplifiers similar (with exception of the limiting/protection circuits)?
Mark Seaton
Seaton Sound, Inc.
Old 05-09-2013, 10:18 AM
Jason kiDD's Avatar
Quoted: 23 Post(s)
Liked: 25
ha
Jason kiDD is offline
Old 05-09-2013, 10:37 AM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 667
Of course the circuit design and layout is very similar in the 1/2 dozen or so Asian Class D amps I've messed with. Protection circuits are irrelevant with flat response to 2 Hz running stereo into 2 ohms playing WOTW at 0dBRL. Have you tried it with your SM amp?
Most likely the problem is in stereo operation with a 2 ohm load, which I wouldn't recommend for L/T'd HT subwoofer systems with any amplifier. Problems such as pumping can occur using a single side X2 that are eliminated by bridging, for one example. This is one reason I've never experienced problems running bridged 4 ohm vs stereo 2 ohm with the various iterations of Class D or so-called TD amps from Asia.
Most importantly, when the average driver is handed the keys to a NASCAR vehicle with no prior instruction, a crash is most likely to occur.
Who cares what a single channel does vs a monoblock? Why not run the 2 Ch amp as a monoblock as well if there's a comparison being made for SW duty?
The amp looks interesting, but there's no chance it hangs with the FP14000 bridged, cloned in any of its variations or actual LG.
Old 05-09-2013, 10:50 AM
wth718's Avatar
Quoted: 194 Post(s)
Liked: 311
Which clone have you had the most success with, Bosso? I'm intrigued by the performance, but scared off by the QC issues I've read about. I don't have enough disposable income to risk on something that may or may not work. You can PM me if you prefer.
wth718 is offline
Old 05-09-2013, 10:58 AM
Quoted: 495 Post(s)
Liked: 1288
My question was how close the circuitry of these clones are to the actual LabGruppens beyond the cosmetic likeness. My understanding was they are rather close and was simply asking if anyone could confirm.
Yes protection is irrelevant if you always stay within the amps limits. Real program material into a real driver impedance is very different than a dummy load bench test.
Sounds like a design quirk/flaw important to know about with a work around. Hopefully most know that.
Brian's comparisons make a lot of sense in the pro world where most of his amps are sold and used. Most companies would have the amps running 1-4 subs per channel, where the comparison for internal power is one plate amp per 1-2 boxes. SpeakerPower does offer a 2RU version with 2 amplifier channels (not bridgeable) for more direct comparison.
Depending on the load, a pair of 4kW or more appropriately a pair of the 6kW amps powered at 220V should make a very good comparison, of course these 2 SpeakerPower amps are optimized for 2 Ohm operation and should be considered in that light.
Unlike the clone amps, the SpeakerPower amps can be purchased directly from the english speaking designer and manufacturer, with the amplifiers being manufactured here in the US all the way back to the circuit boards. Any failures that might be encountered are resolved by shipping of an 8-20 lb amplifier back to southern CA. Some will find value in that, others won't.
Mark Seaton
Seaton Sound, Inc.
Old 05-09-2013, 12:40 PM
I recently realized there are a lot more AVS members in SoCal than I had previously thought.
Old 05-09-2013, 01:06 PM
Jason kiDD's Avatar
Quoted: 23 Post(s)
Liked: 25
I would just caution if you cant afford to play then leave the clone alone. Find another option thats more stable with less power and be at peace.. cool.gif
Old 05-09-2013, 01:53 PM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 667
I dislike wading through threads with hundreds of pages myself, but this has been discussed in the clone thread. Judge for yourself. You can see the similarity in layout, but no way are the boards interchangeable:
I have "clones" that are much more substantially different in circuitry, but they are laid out the same as most any amp (transformer, rectifier, cap reservoir, amp boards, output devices and I/O), they just have a SMPS, some have PFC, some don't, they have varying amounts of cap reservoir, all sorts of 'protection circuitry', etc.
We've always agreed on this point, but some people have the wrong way around.
It is not a design flaw. For pro sounders, it's not relevant, so it never comes up.
Value is more likely to be found in 4xFP14000 clones vs 2-SP1-6000 at the same price. IMO, failures come mostly from user-error, as with most any product of any kind.
Old 05-09-2013, 02:02 PM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 667
To those who have asked in threads and/or pinged me about what supplier for what amp, I'm not going to recommend any product or source from Asia or otherwise. Learned my lesson with amps and other products over the years. Sorry.smile.gif
Old 05-09-2013, 03:31 PM
notnyt's Avatar
Liked: 1980
It would be interesting if people took a chance on some of the other clone amps and reported their findings. The CVR PS4180 seems to be similar as well, but they're super shady as a company. I'm sure the speakerpower amps are great, but the pricing is 3x as high.
notnyt is offline
Old 05-11-2013, 04:33 AM - Thread Starter
LTD02's Avatar
Liked: 2571
saw this in another thread. apparently, he too observed that the lg's drop power after a few ms with sine waves. big difference between the burst ratings and the sustained reports, it seems.
http://forum.behringer.com/showthread.php?654-iNUKE-NU-6000DSP-power-load-test
LTD02 is online now
Old 08-07-2015, 08:02 PM
Stereodude's Avatar
Quoted: 3084 Post(s)
Liked: 2236
I realize this is a two year old thread, but that's not correct. They use what we now call a CEA-2010 6.5 cycle tone "burst".
Stereodude is offline
Old 08-07-2015, 08:05 PM
notnyt's Avatar
Liked: 1980
Correct, which is just over 300ms at 20hz. I'm not sure what a "few" is being defined as in the previous discussion, but I'll eventually get back to testing amps (hopefully soon ) and get one of these on the bench.
notnyt is offline
