Would like to build a sub using an empty eD A7-450 cabinet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 05-04-2013, 05:11 PM - Thread Starter
LF911's Avatar
All,
I am currently running an eD A7-450 and a A7-350.
Additionally, I have an, empty A7-450 cabinet...l would really like to build a sub using the cabinet but not sure where to start. Could use some suggestions as I have been out of the sub loop for a past couple of years...
LF911 is offline
post #2 of 12 Old 05-04-2013, 05:32 PM
LTD02's Avatar
Quoted: 2530 Post(s)
Liked: 2872
scroll down: http://stereointegrity.com/index.php?id=60
Listen. It's All Good.
LTD02 is offline
post #3 of 12 Old 05-04-2013, 06:08 PM
ozziedog's Avatar
Liked: 24
Originally Posted by LF911 View Post
All,
What is your budget
ozziedog is offline
post #4 of 12 Old 05-07-2013, 04:36 AM - Thread Starter
LF911's Avatar
Maybe $500 - $600 for the sub (or less if decent sub) then maybe an external amp. Would have to do something with the plate amp opening though...
LF911 is offline
post #5 of 12 Old 05-08-2013, 06:20 PM
dominguez1's Avatar
Quoted: 1112 Post(s)
Liked: 975
LF911,
The Mach 5 UXL-18 would be perfect for that cabinet (assuming fit is not a problem). It's likely a better performer than the eD a7-450 driver, so you'll likely get better performance than the a7-450.  Good luck.
dominguez1 is offline
post #6 of 12 Old 05-08-2013, 07:50 PM
ozziedog's Avatar
Liked: 24
Originally Posted by dominguez1 View Post
LF911,
That would be my pick also. It should be back out anytime now.
ozziedog is offline
post #7 of 12 Old 05-09-2013, 05:30 AM - Thread Starter
LF911's Avatar
Thanks! And To power it....what would my options be???
LF911 is offline
post #8 of 12 Old 05-10-2013, 12:12 PM
ozziedog's Avatar
Liked: 24
I believe the UXL-18 can handle up to 5000 Watts so there are a lot of options available.
ozziedog is offline
post #9 of 12 Old 05-10-2013, 12:53 PM
ozziedog's Avatar
Liked: 24
I guess it really depends on how much you want to spend on the amp. There are many options from Behringer (inuke 3000, inuke 6000, ep 4000) the CV 5000 is becoming popular and of course there is the Lt.1300 wink.gif. It really depends on how much you are wanting to spend.
ozziedog is offline
post #10 of 12 Old 05-10-2013, 07:36 PM
dominguez1's Avatar
Liked: 975
For your ported cab, I'd got with an inuke DSP amp. You'll need a HPF to protect the driver.
FYI, I do have a LT1300 laying around powering my transducers...I might be able to be convinced to sell it if interested...
post #11 of 12 Old 05-12-2013, 04:49 AM - Thread Starter
LF911's Avatar
Thanks...
I'm actually a little concerned about the Lt1300s. . I've got two, powering the 450 and 350...not that I've had ANY problems with them...but. well you know....
LF911 is offline
post #12 of 12 Old 05-12-2013, 08:45 AM
Face2's Avatar
Quoted: 346 Post(s)
Liked: 208
Thanks...
I used a 500w Yung amp to replace a LT550 and have no complaints. What are the dimensions of the LT1300? Although, with the drivers you're looking at, I would leave the amp in place to fill the cabinet void, and use an external amp from Crown, etc...
Face2 is offline
