Two 18" sealed and one 18" dual opposed? - AVS Forum | Home Theater Discussions And Reviews
Old 05-05-2013, 04:16 PM - Thread Starter
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
I am going to build two or three sealed subs with Dayton 18" HO's. I can put two up front and one in back. Would it be a bad idea to make the back sub a dual opposed?
sslv2pwned is offline
Old 05-05-2013, 07:06 PM
brian6751's Avatar
Quoted: 894 Post(s)
Liked: 689
Not at all if thats what you can fit. Level matching will take care of output differences.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
Old 05-05-2013, 10:51 PM
BassThatHz's Avatar
Quoted: 2036 Post(s)
Liked: 1568
It is not a "bad" idea. However, bass is highly dependant on room acoustics. It's nearly impossible to say unless you've had 4 sub points in your room in the past vs just 3.
Chances are there wouldn't be a huge difference in response (if any), but no one knows for sure 100%
BassThatHz is offline
Old 05-06-2013, 11:36 AM - Thread Starter
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
Hmmmm... So do I risk it? Maybe I should just go with three single sealed boxes.
Old 05-06-2013, 11:50 AM
skeeter99's Avatar
If you can do dual opposed in the back why no just build 4 cabinets? You can then stack two in the back to start and if you're getting nasty nulls you can then have more flexibility to relocate and move them around. Do you have a layout of the room?
skeeter99 is offline
Old 05-06-2013, 12:55 PM - Thread Starter
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
I have attached a layout of the room. The subs pictures represent proposed / future sub locations. I currently only have one sub in the front right corner, which recently died.
I'm really after that deep chest pounding bass. I was initially going to only do two sealed 18" boxes. But after reading a bunch of the threads here (particularly Gorill83's thread), I'm wondering if two 18's will give me what I'm after.
living room layout.pdf 257k .pdf file
WP_001117.jpg 94k .jpg file
Edit: I added a current picture of the front stage.
Old 05-06-2013, 01:04 PM
skeeter99's Avatar
Is the room on concrete or above grade?
Old 05-06-2013, 01:06 PM - Thread Starter
sslv2pwned's Avatar
Quoted: 127 Post(s)
Liked: 33
Above grade on concrete slab.
Old 05-06-2013, 01:17 PM
brian6751's Avatar
Quoted: 894 Post(s)
Liked: 689
how about one or two right behind that loveseat? that will help with you being on a slab.
two singles maybe? im adding two single 18's that will only be 12.75" deep. low profile to hug the wall under my screen. you could do the same thing for behind the loveseat if space is limited. firing into the back of the loveseat.
Rivers Edge Theater
