Thoughts/help on a AMP? - AVS Forum | Home Theater Discussions And Reviews
Old 05-06-2013, 12:11 PM - Thread Starter
imagez's Avatar
Hello AVSers!
I am a long long time lurker on this site,and i've been doing some research for a while and would like some intput from the pros.I have 2 12 inch alpine type Rs 1222D DVC2ohm in separate builds tuned to 23 hz, i only have 1 connected to my YUNG 500RMS 6db boost@25hz,and was thinking of getting a second yung amp,BUT, after reading and reading,everyone seems to praise pro amps,so i am looking at the iNUKE 3000DSP because of all the good reviews based on home subs.Do you guys think i should hang the 2 yung amp ideas and go for the iNUKE? Please keep in mind i love really deep low bass if that helps.Thanks in advance!
IMG_20130506_110306.jpg 1269k .jpg file
ignore the BiC,only for decor lol
imagez is offline
Old 05-06-2013, 01:15 PM
Louquid's Avatar
Liked: 38
I would go with the iNuke 3000DSP. The DSP alone on the iNuke would be reason enough to choose it over the Yung amp.
Louquid is offline
Old 05-06-2013, 01:35 PM - Thread Starter
imagez's Avatar
Thanks for the reply,i`m guessing when i connect them to 4ohm load each(my Yammy has 2 sub outs) L+R ,i will still be able to set HPF? They dont need to be bridged right? Sorry for the ??s , im new to the pro sound world, Thanks again
imagez is offline
Old 05-06-2013, 02:27 PM
Louquid's Avatar
Liked: 38
You're wanting to filter out frequencies below your tuning point with the HPF?
It does appear that you can use the low pass and high pass filter in both stereo and bridged modes. Whether you can use both at the same time, I'm not fully sure. I believe you can.
Louquid is offline
Old 05-06-2013, 02:38 PM - Thread Starter
imagez's Avatar
Thanks again bro,i will be looking forward to buying the pro amp soon,
imagez is offline
