Tiny desktop, single driver speaker ideas - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 44 Old 05-06-2013, 08:06 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Crap I didnt even notice that... This Vifa is great, dont let the price full you
http://www.parts-express.com/pe/showdetl.cfm?partnumber=264-1062
I could work up something for that, or go on the more expensive side with this Seas
http://www.madisoundspeakerstore.com/approx-4-fullrange/seas-prestige-fu10rb-h1600-04-4-full-range/
And yes plain old speaker wire is all that is needed.
Jay1 is offline
post #32 of 44 Old 05-06-2013, 08:33 PM - Thread Starter
edlittle's Avatar
Quoted: 22 Post(s)
Liked: 39
Could you try and make something from the Vifa? Much gratitude.
edlittle is offline
post #33 of 44 Old 05-06-2013, 08:34 PM
tuxedocivic's Avatar
Quoted: 2177 Post(s)
Liked: 2046
If get a bunch of resistors. They're cheap and sitting on a desk you probably won't like full BSC.
My youtube channel: Impulse Audio
tuxedocivic is offline
post #34 of 44 Old 05-06-2013, 08:49 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Only issue is going to be even less bass, starts to roll off about 20-30hz higher in frequency.
Jay1 is offline
post #35 of 44 Old 05-06-2013, 09:04 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
(Dont mind the name at the top of the chart, its for the Vifa TC9). Same box as before
All you change for the TC9 is a 1 mh inductor instead of the 0.6 mh one from the circuit above
http://www.parts-express.com/pe/showdetl.cfm?partnumber=255-048
The gray line shows using a 5 ohm resistor, black is 10 ohm resistor, blue is no filter. The 5 ohm resistor would probably be best.
Jay1 is offline
post #36 of 44 Old 05-06-2013, 10:04 PM
skeeter99's Avatar
Also, since the TB's are out of stock, any other recommended drivers? Thanks.
Yes, look at the Mark Audio CHR and CHP speakers on Madisound I pointed you to earlier. Similar price, extremely popular and well reviewed. Probably wouldn't need a filter and cold be put in a pretty small box from what I understand. They're extremely well built and sounding speakers.
Scott
skeeter99 is offline
post #37 of 44 Old 05-06-2013, 10:10 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Any driver not designed with a 6 db downward slope to the high frequency response, based on the enclosure's width will require a filter for flat response.
Now if these speakers are sitting on a desk, backed up against a wall, then you can get away without a filter.
Jay1 is offline
post #38 of 44 Old 05-06-2013, 10:24 PM - Thread Starter
edlittle's Avatar
Quoted: 22 Post(s)
Liked: 39
I think I'll stick with the Vifa to see what kind of response I get versus my Logitechs that I got at a used electronics store.
edlittle is offline
post #39 of 44 Old 05-07-2013, 09:23 AM
alphaiii's Avatar
Quoted: 43 Post(s)
Liked: 56
What about the Aura NS3?
http://www.madisoundspeakerstore.com/approx-3-fullrange/aurasound-ns3-193-8a1-3-black-cone-wide-range/
Can be put in a really small box, sealed.
http://techtalk.parts-express.com/showthread.php?228497-PC-Speakers
Not sure how the top end measures though...
alphaiii is offline
post #40 of 44 Old 05-07-2013, 09:41 AM
Liked: 2046
I've got a pair here in a very small box I could measure if the OP was interested.
post #41 of 44 Old 05-08-2013, 10:33 AM - Thread Starter
edlittle's Avatar
Quoted: 22 Post(s)
Liked: 39
If I leave the volume the same, can I make it decorative? Like with some nice curves or whatever else?
edlittle is offline
post #42 of 44 Old 05-08-2013, 10:48 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Changing the 5" wide 8" high dimensions will alter the response curve. Other then that you can do whatever you want to the cabinet shape.
Jay1 is offline
post #43 of 44 Old 05-09-2013, 01:34 PM - Thread Starter
edlittle's Avatar
Quoted: 22 Post(s)
Liked: 39
Could I do something like this:
with a 5" width and 8" height, but with a tilt in front so that it will point up on my desk? Or would it be better to make so mini stands to go with them, but with that same curve in the back? Thanks.
edlittle is offline
post #44 of 44 Old 05-09-2013, 02:16 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
You'll be good with that. Cool looking design.
Jay1 is offline
