DIY PA / Party Subwoofer - AVS Forum | Home Theater Discussions And Reviews
Old 05-07-2013, 12:36 PM - Thread Starter
Quicktime_GT's Avatar
Hello,
A friend of mine runs a small mobile DJ business and supports small events such as Weddings, Proms etc. Him and I were kicking around at the idea of building a DIY subwoofer for DJ purposes.
A few goals / constraints
  • Most output for the money
  • Size is only limited to an enclosure (or pair of) that can fit through a normal door.
  • Budget is flexible, but would likely like to keep things around or less than $1000 (excluding amplifier)
  • Open to attempting a ported / vented enclosure
  • Will be used for music only so design should allow for optimum output in the corresponding frequency range
  • Probably not interested in attempting a horn / folded horn design
  • Have experience building car audio enclosures, but nothing to this extent.
I had considered something with 4 DCS450-4 18" woofers, but am completely open to any suggestions. An overly large enclosure is not a problem at all and had considered putting this on Casters anyway.
How does everyone feel about the "keystone" design:
http://www.diyaudio.com/forums/subwoofers/185588-keystone-sub-using-18-15-12-inch-speakers.html
We'd like to get started on this very soon!
Any input?
Neil
Quicktime_GT is offline
Old 05-07-2013, 02:04 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I would look into 15-18" pro woofers and use them in a ported enclosure tuned to around 35hz. The DCS450 doesn't model too well in a ported enclosure.
Mrkazador is offline
Old 05-07-2013, 02:05 PM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
http://www.billfitzmaurice.info/
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
Old 05-07-2013, 02:51 PM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Originally Posted by Quicktime_GT View Post
Hello,
Any input?
Neil
Art did a great job designing and documenting the Keystone.
Follow those plans, use the right driver, brace the cabinet properly, and your results should match his.
lilmike is offline
Old 05-07-2013, 02:54 PM
Manic1!'s Avatar
Quoted: 172 Post(s)
Liked: 73
Remember at weddings the way it looks is also very important, better if you can hide it completely. Also it should be easy to move for a single person. I use a single Yorkville LS720P. It's a 15inch 730 watt powered sub and I have know problems with events with 200 people. How many people will be at the event he is doing and what speakers is he using?
Manic1! is offline
Old 05-07-2013, 03:49 PM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1555
Quad 460-8's powered with a nu6000DSP and ported to 40hz should work well.
You'll need 2 channels of ~1000w @ 4-ohm.
BassThatHz is offline
Old 05-07-2013, 05:30 PM
Manic1!'s Avatar
Quoted: 172 Post(s)
Liked: 73
For around $1300 shipped you can get a single Yorkville LS801P. Max SPL 140dB Peak (134dB Continuous). http://yorkville.com/loudspeakers/elite/product/ls801p/ No need for anything more for sub 400 people events.
Manic1! is offline
Old 05-08-2013, 08:48 AM
chrapladm's Avatar
Quoted: 826 Post(s)
Liked: 286
BC21SW152-4 131.6 dB, 92 volts, 3.4 ohms, 2489 watts
BC18SW115-4 130.1 dB, 76v, 3.43 ohms, 1683 watts
BC18TBW100-4 127.8 dB, 59v, 3.32 ohms, 1048 watts
Eminence 2xLab12 126.3 dB, 36.5v, 2.22 ohms, 600 watts (300w.p.d.) 128.4 dB at 40 Hz.
Eminence 4015LF 121.9 dB, 38v, 5.17 ohms, 279 watts
Sounds like a winner to me.
chrapladm is offline
Old 05-08-2013, 04:46 PM
Ivan Beaver's Avatar
Liked: 57
You must not be doing the type events/shows that I used to and currently do.
For 400 people I would suggest 4 per side.
For jazz you could possibly get by with less
Danley Sound Labs
Physics-not fads
Ivan Beaver is offline
Old 05-08-2013, 09:13 PM
Manic1!'s Avatar
Quoted: 172 Post(s)
Liked: 73
I AM. You have 300 people at a wedding but you will have maybe 1/2 dancing at a time. 4 per side would be ridiculous unless you are doing a rave or something. Remember Your average wedding DJ is getting paid $400 to $1000 per vent and spending over 10K on subs a long would make no financial sense and would be a pain in the ass to move.
Manic1! is offline
Old 05-08-2013, 11:04 PM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 783
I agree with this, two enclosures each 10cuft internal housing dual PA460-8's, four 4" PVC ports 6" long, and use a protective high pass at 35hz. With 1000 watts per enclosure they should give you some crazy output and come in well under budget.
mtg90 is offline
Old 05-08-2013, 11:34 PM
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
No reason not to go with a horn.
http://www.diyaudio.com/forums/subwoofers/202797-ss15-build-x8.html
The ss15 is a light weight tapped horn designed to be easily build out of a single 4x8 sheet of ply.
Edit: I should read entire posts before recommending a speaker, totally skipped the "no horn" part. But I still think you should give the ss15 a try smile.gif
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
And a bunch of DIY speakers and subs.
Coming soon: Dirac Room Correction
Stumbo is offline
Old 05-08-2013, 11:55 PM
Manic1!'s Avatar
Quoted: 172 Post(s)
Liked: 73
Now how are you going to move that every time and what type of vehicle are you going to use. Remember his buddy is a mobile DJ.
Manic1! is offline
Old 05-09-2013, 12:08 AM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 783
mtg90 is offline
Old 05-09-2013, 04:51 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
"Budget is flexible, but would likely like to keep things around or less than $1000 (excluding amplifier)"
peavey low rider would be worth having a look at. ~$215 delivered ea.
pretty good xmax for a p.a. woofer and decent inductance.
8 cubic feet tuned to 30hz should cover most music types without getting to be too big.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=294-301
as for form factor, simple slot ported would be fine:
Listen. It's All Good.
LTD02 is offline
Old 05-09-2013, 07:30 AM
zhillsguy's Avatar
My experience was less than positive with the one 15" Low Rider I purchased. There has been positive discussion about the 18", however. See post #11 in this thread, YMMV:
http://techtalk.parts-express.com/showthread.php?232833-Dual-Pro-Sub-Placement&highlight=zhillsguy
zhillsguy is offline
Old 05-09-2013, 02:37 PM
LTD02's Avatar
Liked: 2576
hhmmm...those specs don't look so great. i wonder what was going on...
LTD02 is offline
