JL W3 BOX ALIGNMENT. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-08-2013, 01:30 AM - Thread Starter
tritiumglo's Avatar
Quoted: 366 Post(s)
Liked: 165
My JL W3 came in a 1.5 slot ported box. It sounded good but extension seemed lax. I plan to build a size no object cylinder to get the most out of the driver. I am wondering if port noise will be a risk with a 20hz tune?. WinIsd defaults with a 4" port. Will a larger diameter port help reduce huffing or noise?. The alignments I am considering are attached below. Any thoughts are appreciated.
NAD M15 /NAD M25 / PSB STRATUS GOLD / PSB STRATUS 6C /DENON AVR 3300/CARVER TFM 45/35 - ANTHEM MCA3 / NAD T163
IMAGE DYNAMICS / INFINITY RS3 / POLK MONITOR 10/ALTEC 501 / INTEGRA 50.3/PARADIGM DSP 3400 / GOLDENEAR AON3 / HK AVI 200
An Observer of many philosophies, a slave to none.
tritiumglo is offline
post #2 of 4 Old 05-10-2013, 01:58 AM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
input the power that you intend to use, then check air velocity.
increase the port diameter until air velocity is in the ballpark of 17 m/s.
that should be a good starting point.
Listen. It's All Good.
LTD02 is offline
post #3 of 4 Old 05-10-2013, 04:56 PM
Kimeran's Avatar
Quoted: 14 Post(s)
Liked: 123
From what I understand, those JL drivers are supposed to be really good.
I often have wondered how they hold up to the TC Sounds offerings....in fact, I wouldnt be suprised if the JL could beat the TC in some areas.
Trying to enjoy the simple things in life.
Steam: madbrayniak
Kimeran is offline
post #4 of 4 Old 01-15-2014, 11:11 PM - Thread Starter
tritiumglo's Avatar
Quoted: 366 Post(s)
Liked: 165
Indeed the JL is very good. I recently picked up Image Dynamics IDMAX 12s and put them in sealed enclosures. They are unbelievable. They are superior to the JL. They play deeper and play at high SPL with modest power. Excellent driver.
