Fried a driver, 3rd time, now what... - AVS Forum | Home Theater Discussions And Reviews
Old 05-13-2013, 02:44 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 824 Post(s)
Liked: 879
I have fried both of my CSS SDX15 once each, now I fried another one watching Django a couple of days ago with the help of Sam Adams Seasonal Collection (movies and too much beer is bad for HT equipment). I need to make a change. I have an EP4000 bridged to each, use a Reckhorn HPF set at 19hz, each sub has a 6.6 cu ft enclosure tuned to 19hz.
I'm looking for some advise, and here are a few options I am throwing around:
Turn it down
Stop buying such delicious beer
rebuild the driver, about $200
buy 2 new 15" drivers, switch brands
buy 2 new 18" SI
buy 4 new 18 SI and build sealed
buy 2 new LMSU 18s
A couple of these options just aren't realistic. I admit that I abuse them, but I love to feel the bass, I know I don't have to justify that part to you guys. I listen to music 24-7, loudly quite often, and watch movies at close to reference 4 nights a week. I'd love to modify and reuse the enclosures, but I'd enjoy building more. They will have to occupy the same footprint. 2x2x7'
Here is a pic of the current drivers in the current cabs.
d_c is offline
Old 05-13-2013, 02:49 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
So you're giving each driver 2k watts. First thing is you need to pick a driver that can handle that kind of power since this had become a regular occurrence for you... what are the enclosure specs? Are you willing to sacrifice the 19hz extension?
Jay1 is offline
Old 05-13-2013, 03:48 PM
Bill Fitzmaurice's Avatar
Liked: 4639
That would explain it. Bridging isn't about power, it's about doubling voltage swing into a high impedance load that the amp would not otherwise be able to drive to its thermal or displacement limit, whichever is lower. I'd say you don't have that problem. The only safe way to bridge is if you have a limiter to prevent excess voltage swing.
You're also probably trying to get way too much out of two fifteens, and they'd probably work better placed on opposite ends of the room.
Bill Fitzmaurice is offline
Old 05-13-2013, 04:16 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 824 Post(s)
Liked: 879
I would hate to lose the low extension Jay, which I think would happen if I dropped an 18 in to each cab - unless I sealed the port which would be easy. One part of me wants to get 4 lower cost 18" drivers, build new enclosures, and seal them. That way I have enough power on hand already, ie the Daytons or the SI. The other part of me hates to have all that space to utilize and not have two vented enclosures. I enjoy watching the build threads of the 8+ sealed driver configurations, but it is not realizstic for the space I have to use. I love the performance of the CSS drivers, but I keep killing them due to my own negligence. I need something that will accomplish the same or more and be safer from my urge to keep turning it up.
enclosure specs:
36x24x17
Two 4" x 25.5" ports
6.6 liters Total volume
19hz tune
d_c is offline
Old 05-13-2013, 04:21 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 824 Post(s)
Liked: 879
That is the sum of it. I always want more. My pair of THTLP in the same place wouldn't pass wife approval, or fit in the space!
See? This petite T48 barely fits
d_c is offline
Old 05-13-2013, 05:31 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
"Bridging isn't about power..."
sure it is.
it is a way to get the maximum power out of an amp from both channels into a single load.
"I have an EP4000 bridged to each..."
then you need drivers that can take that kind of power.
FOUR alpine swr 12d4's should be able to work in that cabinet and take that power.
Listen. It's All Good.
LTD02 is offline
Old 05-13-2013, 08:37 PM
Liked: 4639
sure it is.
It would be with parallel bridging, which doubles the current capacity into a low impedance load. But very few amps use parallel bridging. They series bridge, which doubles the voltage output, not the current output. That's why in most cases the minimum impedance load for a bridged amp is twice that of each channel separately. With the EP 4000, for instance, it's rated 2x 2,000 into 2 ohms, 1x 4,000 into 4 ohms. If it was me I'd be running only one EP 4000 channel per driver, if 1400w into 4 ohms isn't loud enough you don't need more volts, current or power, you need more speakers.
Old 05-13-2013, 08:40 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 824 Post(s)
Liked: 879
I have them gained down by 50% to aim for around 2k per driver, as they are rated at 1800w. The blown driver is making a scraping noise, so would that be from mechanical failure? I smelled the coils cooking when I roasted the last ones, resulting in no sound. I dialed gains way back since then.
Has anyone completed a vented build with the SI18 yet? Looks like that driver would work in my same enclosures as they recommend 5-6 cubes tuned at 20hz. That would be cost effective.
I noticed on Data-Bass that the sealed SI beats the SDX15 by at least 3db all the way across the board. Would the same be true for vented?
d_c is offline
Old 05-14-2013, 01:54 AM
BassThatHz's Avatar
Quoted: 2033 Post(s)
Liked: 1555
Here's a clip of me blowing an LMS Ultra.
The SDX-15 is rated for 1200watts RMS.
The LMS-U is rated for 2000watts RMS and 8kW peak. It's 10db louder than each SI below 20hz, according to data-bass.
I migrated away from dual SDX-15's to quad LMS-U's and 2 21's. It's much-much better and louder too biggrin.gif
The LMS can take a lot of punishment (but it's still not invincible. I learned that the hard way! tongue.gif)
Your EP4000's will likely go into melt-down before it will stress the LMS-U's much biggrin.gif
BassThatHz is offline
Old 05-14-2013, 06:35 AM
Liked: 4639
Gain controls do not limit the amp output, they merely attenuate the source signal. If that signal is hot enough the amp will still deliver full output, even clip. Read the last page of your T48 plans on preventing driver damage.
Old 05-14-2013, 08:51 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 824 Post(s)
Liked: 879
d_c is offline
Old 05-14-2013, 09:52 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
Would trying to push an lmsu with an ep4000 be pointless, or would the results be better to push two si 18s?
Pointless, no. Optimal, no.
2 Si 18's would be in the sweet spot with a bridged EP4000. It would cost less too. Keep in mind, the SI's are far from bullet proof though. An LMS-U on an EP4000 would be pretty indestructible. smile.gif
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
Old 05-15-2013, 06:04 AM - Thread Starter
d_c
d_c's Avatar
Quoted: 824 Post(s)
Liked: 879
Anyone have a minute to post a model of 4 sealed si 18d2 with 750w each vs. 2 sealed lmsu at 1900w (4000 peak) or whatever it is that the ep4000 actual outputs bridged at 4 ohm
d_c is offline
Old 05-15-2013, 01:20 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Two LMSU in 8 cuft and 1900w.
Four SI 18 in 16cu ft with 3000w.
Mrkazador is offline
Old 05-15-2013, 01:28 PM
lukeamdman's Avatar
Quoted: 1080 Post(s)
Liked: 1200
lukeamdman is offline
Old 05-15-2013, 01:42 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Alright so now its 3800w for the two LMSU.
Old 05-15-2013, 03:06 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 824 Post(s)
Liked: 879
Thank you!! I appreciate you guys. I realize this subject has been beaten to death the last few months.
Using only two instead of the four SI would be 3 or 6 db less?
I could spend another grand on the fp14000 and double the power to the LMSU to add 3db. Are there other benefits beyond?
d_c is offline
Old 05-15-2013, 04:39 PM
lukeamdman's Avatar
Liked: 1200
Two less SI drivers would be 3db less, but you'd have to be careful not the blow the drivers with dual ep4k amps.
Doubling the power of the LMSU with the lg clone would be a 3db increase.
Also take into account that the measurements above are with the SI drivers taking up twice the space with 16 cu.ft compared to 8 cu.ft. If you have the space this is obviously a non-issue.
Old 05-15-2013, 06:59 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 824 Post(s)
Liked: 879
I may have a solution:
I downloaded winISD and am stumbling through it. I may have it effed up, but 2x LMS-U with my current ported enclosure is 4+ db from 5-50 hz above the 4x SI sealed in 16 cubes using my two EP4000. Does this sound right?
the enclosure is:
hz
36x24x17
19hz tune
d_c is offline
Old 05-15-2013, 10:21 PM
Looneybomber's Avatar
Liked: 25
It probably sounds right but anything below 15hz is a moot point since you're using a subsonic filter.
LMS-U's don't like big ported boxes, so to get deep enough tuning folks usually use passive radiators. Check your port speed to see what it says given your input signal. An SDX-15 should push the limits of those 4" ports and an LMS-U should easily push those limits. If you've not heard any port noise before, then you might be safe.
YID DIY
Looneybomber is offline
Old 05-16-2013, 12:59 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 824 Post(s)
Liked: 879
d_c is offline
Old 05-16-2013, 01:16 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Is a hpf necessary with 1800w to the LMS if vented?
Yes, play something with content below your tuning point and you have a very high chance the driver will bottom out damaging the driver.
Old 05-16-2013, 02:53 PM
lukeamdman's Avatar
Liked: 1200
Any driver in any vented enclosure needs a HPF.
Even as indestructible as the 18" RE XXX is, didn't Ricci blow one up going below the tuning frequency?
