What should I put on the bottom of my DIY speaker stands? - AVS Forum | Home Theater Discussions And Reviews
Old 05-15-2013, 08:33 PM - Thread Starter
lexlynx's Avatar
Quoted: 18 Post(s)
I'm making 4 speakers stands, each is 2 12"x9" pine boards separated by a length of 4" PVC. Tomorrow I'm going to Home Depot to pick up some closet flanges to attach the PVC to the wood, and I figured I might as well get the parts for the bottom. Half the stands will be over carpet, but the other 2 will be over a hardwood floor. I'm guessing I should get some kind of rubber carpet spike for the 2 over the carpet, but can someone recommend what to get for the hardwood stands? Perhaps some felt pads?
lexlynx is offline
Old 05-15-2013, 09:13 PM
Looneybomber's Avatar
Liked: 25
Soft pads of rubber or silicon. Or, you could add some of that rubbery/foamy anti-slip mat they sell for kitchen and workshop counters.
YID DIY
Looneybomber is offline
Old 05-16-2013, 01:27 AM
Face2's Avatar
Quoted: 337 Post(s)
Liked: 203
I would use spikes from parts express for use on carpet, they will help with stability.
Face2 is offline
Old 05-16-2013, 06:43 AM - Thread Starter
lexlynx's Avatar
Quoted: 18 Post(s)
Thanks for the help. Yeah, I just checked home depot's website, and they don't seem to have carpet spikes after all...
Is there a particular model from part express that you can recommend?
lexlynx is offline
