Dual LMS Ultra vented build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 51 Old 05-30-2013, 01:30 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 886 Post(s)
Liked: 1016
Some guys on another forum mention that 1st port resonance needs to be at least 120hz at minimum, or double the LPF. So I'm back to the drawing board again. I'm beginning to wonder if these subs can be vented under 15hz.
I put the drivers together today to make sure everything is good after shipping, which it is. Thanks for taking care of these Luke, they are in great shape. I also dropped one into the enclosure made for my SDX15 to see what would have to be done if I wanted to use that enclosure for now and seal it. It sticks out a little as you can see in the pics. So I decided to hook it up and run some sound to it, and it actually sounded pretty awesome. Side by side, the Ultra sounded better ghetto rigged than the other one.
Big guy, little guy
I'd have to remove these ports and block the exits to use the Ultras sealed:
d_c is offline
post #32 of 51 Old 05-30-2013, 01:41 PM
armystud0911's Avatar
Sorry, there are a lot of reasons why the LMS really isn't the driver for doing a large ported build like this. You can either do PR's or seal it, but don't even try a port. BTW, double the LPF filter is still stretching it a bit for first port resonance, you may be able to get by with it, but I pretty much always went for a vent that is 34" or shorter.
armystud0911 is offline
post #33 of 51 Old 05-30-2013, 08:53 PM
LTD02's Avatar
Quoted: 2501 Post(s)
Liked: 2835
"Sorry, there are a lot of reasons why the LMS really isn't the driver for doing a large ported build like this. You can either do PR's or seal it, but don't even try a port."
crazy talk. why wouldn't an lms work in a large ported enclosure?
Listen. It's All Good.
LTD02 is online now
post #34 of 51 Old 05-30-2013, 11:18 PM
Elill's Avatar
Quoted: 108 Post(s)
Liked: 91
I thought TC actually recommend it in a vented enclosure as being "optimal", it just so happens that lots of people do it sealed
Go to the recommended enclosures:
http://tcsounds.com/product/drivers/lms-ultra-5400/
Peter the Greek
Downunder Theatre MkII
List of Pro Designers
Elill is offline
post #35 of 51 Old 05-31-2013, 10:36 AM - Thread Starter
d_c
d_c's Avatar
Quoted: 886 Post(s)
Liked: 1016
It's DIY baby, it can be done - we just gotta figure out how. I am getting close with everyones help. TC Sounds recommendations are sketchy since the air speed is out of control with what they mention in the specs. Somebody modeled me a perfect one at 14hz, but way too big: 16 cubes before adding driver, vents, bracing.
I modeled one that might work, but cannot link the file for some reason...
13 cubes
15hz
130.3 1st port res
max air speed 24.5
d_c is offline
post #36 of 51 Old 05-31-2013, 11:14 AM
LTD02's Avatar
Liked: 2835
if you haven't already considered it, a large flare on the port will help keep down audible chuffing.
LTD02 is online now
post #37 of 51 Old 05-31-2013, 12:32 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 886 Post(s)
Liked: 1016
d_c is offline
post #38 of 51 Old 05-31-2013, 02:18 PM
lukeamdman's Avatar
Quoted: 1211 Post(s)
Liked: 1483
I'm glad they made it there safely!
The only thing I really had to clean on them was the nasty gasket tape I used on my sealed boxes. It basically turned into this brown sticky liquid type stuff that really made a mess. It took me quite a while to clean all that off the rubber ring on the basket!
lukeamdman is offline
post #39 of 51 Old 06-03-2013, 02:40 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 886 Post(s)
Liked: 1016
Luke, I thought that maybe you were eating handfulls of candy or something when you were loading them up! biggrin.gif
I am going to retro fit the drivers in the enclosures I have and seal up the ports for now while I finish up my bathroom remodel this summer. I'm pretty busy on the lake in the summer wakeboarding and destroying my liver, so my time is limited to be very productive until it gets cold. Besides, I need to hash out a final plan for the enclosures. I hate to rush into things, and I really want this to be perfect for these awesome drivers. (Also gives me time to maybe save for 2 more)
d_c is offline
post #40 of 51 Old 06-04-2013, 01:54 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 886 Post(s)
Liked: 1016
I have one driver fitted to my old enclosure. I cut the 4" ports out so the driver would fit, recut the baffle, patched some holes, primed, new coat of top coat, moved some of the trim over and reattached, plugged the port holes from the inside with an adjustable test-plug which gives an airtight seal. They sound better than what I had for sure. Much deeper, more SPL, and I see what you guys say about cleaner sounding - maybe more laid-back, if that makes any sense? Off to finish the 2nd one and touch up the stain on both. They are roughly 6 cu ft sealed right now with 1800w each.
d_c is offline
post #41 of 51 Old 06-04-2013, 04:03 PM
lukeamdman's Avatar
Liked: 1483
post #42 of 51 Old 06-06-2013, 04:13 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 886 Post(s)
Liked: 1016
Thanks man! I have watched a couple of movies and listened to a ton of music over the last two days. Using my available 1900w per, the WinISD models the Ultras fairly close to the SDX15s down to 15hz, where the SDX drops to nothing. What I hear is very different: the Ultras have like a turbo-boost after 30 or 40hz that is overwhelming as compared to the SDX15s in the vented box. The SDX15s are pretty smooth, but not nearly as loud in the mid-bass. I think I will like the Ultras more vented. Do you guys using sealed Ultras EQ 6-12db down from 30hz and up?
I wonder if the old subs ported out the sides helped smooth out response using the room gain?
I used these test plugs to plug the port holes. They completely seal it, which is pretty cool:
d_c is offline
post #43 of 51 Old 06-06-2013, 05:40 PM
lukeamdman's Avatar
Liked: 1483
Looking good!
And no, I had the opposite problem you have because of my room acoustics. Above 40hz dropped like a rock, but below 40hz was some serious gain down to about 14hz.
Also, my sealed boxes were much smaller than yours. About 4cu.ft after bracing per driver.
post #44 of 51 Old 06-06-2013, 07:30 PM
novice_01's Avatar
novice_01 is offline
post #45 of 51 Old 06-06-2013, 07:55 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 886 Post(s)
Liked: 1016
Originally Posted by lukeamdman View Post
Looking good!
The acoustics blow in this room. I wish there was a cookie-cutter solution. I'm looking toward the mini dsp for help, or even the Onkyo 818, which has decent step eq. I need to update the old Nak anyways and this is as good of an excuse as any.
Originally Posted by novice_01 View Post
Bring beer! Hurry up and design your boxes so we can build them, and then we can build mine, and then we can build another two for you. It's only a day of OT, right?
d_c is offline
post #46 of 51 Old 06-07-2013, 10:24 AM
BassThatHz's Avatar
Quoted: 2317 Post(s)
Liked: 2069
Not I.
I boost up 20db from 20hz on down; and then I have other Pro bins boosting above 40hz as well.
BassThatHz is offline
post #47 of 51 Old 06-12-2013, 11:19 AM - Thread Starter
d_c
d_c's Avatar
Quoted: 886 Post(s)
Liked: 1016
I turned each cabinet 90 degrees so they are back-to-back and the result is great. There is no overwhelming upper end gain, they sound very smooth now. And holy smokes, they are rediculous at war volume.
I'm not sure how to position them for the ported cabs I'm planning, so I have an idea: build a temporary cabinet that I can take apart to change port direction from front to side, and the same with the driver. It will also give me a chance to check port noise before the final build. I have a calibrated umik on the way so I can finally do this right.
d_c is offline
post #48 of 51 Old 06-12-2013, 07:00 PM
lukeamdman's Avatar
Liked: 1483
Yeah man!
Now just imagine doubling the power, and then doubling that entire setup! I think you understand the appeal of the LMSU's now.
post #49 of 51 Old 06-12-2013, 07:31 PM
BassThatHz's Avatar
Liked: 2069
Yeah man!
and then if you took that and doubled it again, and then took that and doubled it again. Only then you could say, with certainty, that you'd have (far) more displacement than me and NotNyt and a few other members, that is... until TheEar showed up tongue.gif
post #50 of 51 Old 06-13-2013, 06:40 AM - Thread Starter
d_c
d_c's Avatar
Quoted: 886 Post(s)
Liked: 1016
Let me run that by my wife, I think she would be ok with that. You think 32 Ultras would be enough? Then the Ear would get 64. It would never end!
d_c is offline
post #51 of 51 Old 06-27-2013, 04:03 PM - Thread Starter
d_c
d_c's Avatar
Quoted: 886 Post(s)
Liked: 1016
I was finally able to set up the MiniDSP 2x4 and CSL UMIK with REW and get it all working together, which was a piece of cake, BTW. Now I have to figure out how to make some measurements and drop the files back into the DSP. I'm setting the LPF on the 4-way XO plug-in to 120 and bypass on the HPF to start. I would like to get the subs to blend nicely over the next few months while I build the new enclosures. I will have an 818 sitting at the front door in 4-7 days too, so I have some serious learning curve ahead of me.
d_c is offline
