DIY sub build using 2 sunfire original drivers(hivi sp10 ) help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 05-23-2013, 07:01 AM - Thread Starter
poolgod's Avatar
hi guys..i got two sunfire architectural subs from a friend with non working plate amps...decided to use the drivers for a stereo pair of subs with a inuke 3000dsp amp...what type of enclosure wud u guys recommend and size..the sunfire enclosures are tiny but i want to get the max out of these drivers..also does anyone kno where i can find the passive radiators incase i want to go that route or any members have some for sale....they will be for both HT and music,,,,,i have acoustic research 312HO as my fronts so i need a sub that will blend well...thanks in advance
poolgod is offline
post #2 of 25 Old 05-23-2013, 12:43 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
the SP10 is a great woofer, very deep extension in a small box. If you want to go vented you will have to build a slot ported enclosure, as the port will need to be very long to reach a low tune in a smallish box. For example a 13.5" W x 24"H x 19"D box, with a slot port that is 12"W x 1.5"H x 38"L will end up as about 2.2ft3 tuned to 23hz, and capable of handling full power from a channel of the NU3000 with a 20hz high pass filter in place.
The port would need to be L shaped in order to reach the 38" length.
PR's would allow a much smaller box for the additional cost. A 16" cube with a pair of CSS APR 12s, each loaded with all of the provided mass discs (900g) would get you a 21hz tune with only a couple db less output below 30hz then the vented enclosure.
http://www.creativesound.ca/details.php?model=APR12
Jay1 is offline
post #3 of 25 Old 05-23-2013, 01:52 PM
steve nn's Avatar
Liked: 433
Neat idea.. Any chance of posting a few pics of the driver?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #4 of 25 Old 05-23-2013, 02:20 PM
Oklahoma Wolf's Avatar
Quoted: 20 Post(s)
The SP10 models ok in my signature build, if the TS parameters are accurate. Not as well as some others, but well enough.
Oklahoma Wolf is offline
post #5 of 25 Old 05-23-2013, 02:30 PM - Thread Starter
poolgod's Avatar
poolgod is offline
post #6 of 25 Old 05-25-2013, 04:18 AM - Thread Starter
poolgod's Avatar
what improvements will the vented give me?...
poolgod is offline
post #7 of 25 Old 05-25-2013, 04:47 AM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
in a properly sized vented enclosure, 6-8db additional spl around the tuning frequency is not uncommmon and more is possible.
sealed box, 1.25 cubic feet, yellow.
ported box, 2 cubic feet, tuned to 27hz with a 4" diameter port that is 20" long, red.
both with no eq and 500 watts.
the ported enclosure would need a 2nd order high pass filter to protect the driver below the tuning frequency, but for the same wattage, you can pick up almost 12db around the tuning frequency. that is huge.
Listen. It's All Good.
LTD02 is offline
post #8 of 25 Old 05-25-2013, 12:18 PM
braveheart123's Avatar
Quoted: 330 Post(s)
Liked: 287
If you want big sonic brawl of movies in the low-end, go vented. Sealed just never cut it for me, unless of course, I went with multiples. You require at least 2 sealed cabs to match the output of one vented sub. Howver, there are exceptions like an LMS Ultra 18 with huge Xmax.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #9 of 25 Old 05-26-2013, 04:09 AM - Thread Starter
poolgod's Avatar
speaking of huge xmax...i have a RE audio xxx 18 d2 here lying around as well...will be my next project after the sunfire twins
poolgod is offline
post #10 of 25 Old 05-27-2013, 06:14 AM
LTD02's Avatar
Liked: 2888
do you plan to run them all in the same system?
LTD02 is offline
post #11 of 25 Old 05-29-2013, 07:44 AM - Thread Starter
poolgod's Avatar
Yeah..
poolgod is offline
post #12 of 25 Old 05-29-2013, 08:40 AM
LTD02's Avatar
Liked: 2888
next to a properly powered re xxx 18, i don't really see much value in the sp10's.
here are two sp10's with 500 watts each in sealed cabs (red) and a single re xxx 18 (yellow) sealed with 2000 watts.
this is a model response and the actual has a kind of largish peak that might need to have some eq applied, but gives a rough idea of what you are working with.
the re xxx is 8-12db higher across the whole bass, so the contribution from the sp10's would be minimal even for smoothing spl unless you were to do something like put the sp10's right next to your seat.
LTD02 is offline
post #13 of 25 Old 05-29-2013, 12:19 PM - Thread Starter
poolgod's Avatar
The sp 10 will be for music..the re for movies...i will run the dsp 3000 mono for the re...stereo for the sunfires...no one wants to buy the re xxx...so i will use it
poolgod is offline
post #14 of 25 Old 05-30-2013, 07:05 PM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
Why not use tte Re XXX for both? Do you think that there is some sort of advantage to using smaller drivers for music? That is simply not the case, it's just that some people mistakenly believe that a pair of 10's will be faster than a pair of 15's or a pair of 18's
Martycool007 is offline
post #15 of 25 Old 08-22-2013, 12:35 PM - Thread Starter
poolgod's Avatar
well my friend started the box for me yesterday...he is a very talented ..i will post some of his work later..it is a dual sealed cabinet each at .7 cu ft....
poolgod is offline
post #16 of 25 Old 08-23-2013, 03:56 PM - Thread Starter
poolgod's Avatar
some of kerrys work
poolgod is offline
post #17 of 25 Old 08-23-2013, 04:00 PM - Thread Starter
poolgod's Avatar
that enclosure using the tang bang full range sounds amazing!
poolgod is offline
post #18 of 25 Old 08-28-2013, 09:15 AM - Thread Starter
poolgod's Avatar
progress so far...enclosure painted..drivers installed..wrapped in grill cloth and sealed with maple...
poolgod is offline
post #19 of 25 Old 08-28-2013, 09:20 AM - Thread Starter
poolgod's Avatar
feet to be installed...tested with NAD 218 thx amp.....gettin a crown xti4000....all i can say is wow....DEEP..powerful... smooth..not boomy BASS!..cant wait to EQ this baby with proper power....considering building another...
poolgod is offline
post #20 of 25 Old 08-28-2013, 09:45 AM
maintrain's Avatar
Liked: 37
Very nice!
maintrain is offline
post #21 of 25 Old 08-28-2013, 10:10 AM
LTD02's Avatar
Liked: 2888
nice work man!
"that enclosure using the tang bang full range sounds amazing!"
I don't doubt it!
that driver appears to do all kinds of things right. off axis would be interesting to see...
http://www.parts-express.com/pe/showdetl.cfm?partnumber=264-893&utm_source=google&utm_medium=cpc&utm_campaign=pla
LTD02 is offline
post #22 of 25 Old 08-28-2013, 10:10 AM - Thread Starter
poolgod's Avatar
Yes..95lbs of nice!
poolgod is offline
post #23 of 25 Old 08-28-2013, 10:15 AM - Thread Starter
poolgod's Avatar
Originally Posted by maintrain View Post
Very nice!
nice work man!
I don't doubt it!
it is amazing..transmission line enclosures..made for near field listening..close your eyes and you are there with every recording..vocals take your breath away
poolgod is offline
post #24 of 25 Old 08-28-2013, 08:38 PM
LTD02's Avatar
Liked: 2888
on the fabric, did you just fold it over at the top and the bottom for that clean look or is there another trick to it to get it to lay so smooth?
LTD02 is offline
post #25 of 25 Old 08-30-2013, 04:41 PM - Thread Starter
poolgod's Avatar
all wrapped lovingly by hand
poolgod is offline
