DIY Unusual Shape Subwoofer Question??? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 34 Old 05-28-2013, 11:25 PM - Thread Starter
RapalloAV's Avatar
Quoted: 1580 Post(s)
Liked: 456
Originally Posted by autox320 View Post
http://www.sonicelectronix.com/cat_i208_10-angled-subwoofer-enclosures.html
sounds like a 10" truck box would do; I mean for hitting the easy button it fits the bill. Like posted before you need a wedge/angled box and done.
box calc says your wanting .58 cuft
But that wont fit the 12" Velodyne sub I have will it?
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
post #32 of 34 Old 05-28-2013, 11:34 PM
autox320's Avatar
Quoted: 42 Post(s)
Liked: 70
maybe just cut the hole for the 12.....you have a jigsaw? to easy better yet make a custom box if able to
"I should really see what dB levels I'm pushing. Long as it can't foam my beer during a movie we are ok "
autox320 is offline
post #33 of 34 Old 05-28-2013, 11:46 PM - Thread Starter
RapalloAV's Avatar
Liked: 456
The driver I have will never fit in this box. The driver is 7" deep. This box is 8 1/2" at the bottom and only 4 5/8" at the top, outside dimensions, my driver just wouldn't make that box. I wish it did that would be easy.
I really think I have to change the driver but to what I just don't know. If I could buy the box pre made like this I would really be happy, but I need to replace the driver I have, but the replacement must work with my Velodyne amp.
Murray Thompson
X Owner RapalloAV
post #34 of 34 Old 05-28-2013, 11:56 PM
autox320's Avatar
Quoted: 42 Post(s)
Liked: 70
I'd say all isn't lost. The driver depth is the magnet which isn't as wide as the basket. Maybe a 1/2" mount ring will make mounting depth difference easy to overcome. Also if looking for a quick fix look for boxes made for a W7 JL Audio subwoofer it has approx 8" mount depth.
autox320 is offline
Velodyne Sc1250 Subcontractor Series Subwoofer Amplifier
