Late to the party THT build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 33 Old 05-27-2013, 08:12 AM - Thread Starter
LexMan's Avatar
Hi all
Just thought I'd share my build with everyone. Great thing about being late to this great subwoofer is the great threads that point out key areas and experiences.
I read and read the plans during lunches prior to cutting anything.
And then finally made some saw dust!
LexMan is offline
post #2 of 33 Old 05-27-2013, 08:17 AM - Thread Starter
LexMan's Avatar
The panel opening cut wasn't bad at all. If I were to do it again I would make just enough cut on each side and finished up with my jig saw.
Cutting panels first is a goos idea. I would also cut the braces first next time.
First panels getting glued!
LexMan is offline
post #3 of 33 Old 05-27-2013, 08:32 AM - Thread Starter
LexMan's Avatar
The rest of my build pix
Routing speaker opening. This part I was most worried about between the speaker slapping the side and attaching the sub without stripping screws or hurricane nuts.
For me, 13 7/8" opening worked perfect. I cut a test opening first and measured what 13 3/4" looked like. Not quite 13 3/4" with the bit I was using so went to 13 7/8".
I used #10 32 2" screws with washer and lock washer. Hurricane nuts note: drill straight, drill slow. Test each hurricane nut with a screw prior to installing. Some are tighter fitting than others. Also because the screws are fine threaded, insert them and go counter clockwise until they "drop" in place with the threads of the nut.
This is what i did so I was comfortable at the final steps. Also I marked a circle around the sub installed on the mount so again the last step I would have the position where all the screws aligned nicely and could be hand tightened. Maybe overkill but read too many complaints about this that worried me.
Coming together
LexMan is offline
post #4 of 33 Old 05-27-2013, 08:40 AM - Thread Starter
LexMan's Avatar
This weekend I am putting the last touches to the access panel.
I have tested the sub and like everyone has stated it is AWESOME! The best way I can describe it is I have been chasing the best subwoofer bass I have listened to. This will date me some but it was in a hatchback at a car audio store using an Orion amp and a 12" JL sub. The raw output was unreal and have been trying to find a way to recreate that in the home.
The THT does this and then some! Not only raw power, but clean accurate bass that has an effortless quality.
My HT is an open design so I need this type of output to achieve my goals. I'll post more as soon as I get the panel back on. I had to glue a small leak and set the gasket tape a little to secure the cabinet.
LexMan is offline
post #5 of 33 Old 05-27-2013, 11:06 AM
Brad Horstkotte's Avatar
Liked: 68
Looking good! I did the THT LPs so I could hide them behind my screen wall, really enjoy them.
Brad Horstkotte is offline
post #6 of 33 Old 05-29-2013, 06:54 AM - Thread Starter
LexMan's Avatar
Thanks Brad!
I read your build quite a few times and was one of the builds that got me interested in a THT. I ended up cleaning up a bit over the weekend and finished sealing the access panel which turned out to be a little more work than I thought.
I will need to find the best location for the sub as the bass output form the sub "lives" all round the walls to about three feet in and then diminshes in output from there. My back row seeting is fine but what should be the ideal seats have the least amount of bass output. Guess I will be crawling around the room this weekend with the sub in the middle of the room. Just hope I find a spot on the front wall behind what will be the screen.
Any tips welcome!
LexMan is offline
post #7 of 33 Old 05-29-2013, 08:43 AM
Michael Mitten's Avatar
Quoted: 189 Post(s)
Liked: 164
Originally Posted by LexMan View Post
Thanks Brad!
Any tips welcome!
Great build. Anxiously waiting to do mine.
The only suggestion for placement I have is to put a sub in the listening position, if possible, and walk around the room. The place it sounds best, that's your spot.
Michael Mitten is offline
post #8 of 33 Old 05-29-2013, 07:24 PM
mynym's Avatar
Quoted: 22 Post(s)
4 years after I built my THT I still haven't got the itch to upgrade. Still loving it. Absolutely the highlight of my home theater.
mynym is offline
post #9 of 33 Old 05-29-2013, 08:32 PM
brian6751's Avatar
Quoted: 886 Post(s)
Liked: 681
great sub. was my intro into DIY.
the bass energy is often stronger along the walls. try what Michael Mitten suggested first. then take some measurements. graph paper. Rat Shack meter and some test tones will do on the cheap. then what do you have as far as EQ options?
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #10 of 33 Old 05-31-2013, 12:28 PM - Thread Starter
LexMan's Avatar
Thanks Michael Mitten. As I was making my first cuts I was like "Holy Crap I'm actually building one!". The build isn't really hard in itself. What can make it a little tricky is the plywood warping on you.
I'm definitely gonna try your suggetsion and see what I find with my Radio Shack SPL Meter this weekend
LexMan is offline
post #11 of 33 Old 05-31-2013, 12:34 PM - Thread Starter
LexMan's Avatar
I do not have a EQ option just yet. I have an old Lexicon DC-1 as my pre-amp at the moment. HAve not upgraded because I have been building my theater for a while and just getting to the part where I get to put stuff back together.
I was also contemplating building two initially and just mught build another in time. Just need to get my theater done first! wink.gif
LexMan is offline
post #12 of 33 Old 06-09-2013, 05:11 AM - Thread Starter
LexMan's Avatar
Ok I put my sub in my seating location (sorry for poor pic)
And surprise, it is a corner! It's actually the other corner in the front so that is where it is residing. Also the rear corner on the same side was equally as good an option. Now I have two sealed Def Tech 15s I can throw in to the mix until I build my second ThT?
Been reading about EQ options and if anyone has suggestions they are welcome.
LexMan is offline
post #13 of 33 Old 06-09-2013, 07:01 AM
brian6751's Avatar
Quoted: 886 Post(s)
Liked: 681
Try the def techs near field.
As for EQ. The minidsp would be a good option. Does your avr EQ the sub at all? MultEQ or above?
Rivers Edge Theater
post #14 of 33 Old 06-09-2013, 07:11 AM - Thread Starter
LexMan's Avatar
Hey brian6751, sorry for the noob question but near field is where?
As far as AV EQ, I still have to upgrade to something with HDMI so no EQ at the moment. Bean trying to get my theater done in our new house since we moved in almost five years ago. It's like having a muscle car sitting in your garage without driving it! I'm finally getting close some I'm quite anxious. Might go with a refurb high end receiver right now while I wait for HDMI 2.0
LexMan is offline
post #15 of 33 Old 06-09-2013, 12:58 PM
brian6751's Avatar
Quoted: 886 Post(s)
Liked: 681
Nearfield would be right beside or behind the seats.
Depending on the rest of your setup, I wouldn't bother with a high end receiver. Just go with something with the channels and inputs you need. Speaker/ sub placement along with room treatments will get you much more than a higher priced avr.
and hdmi 2.0 will bring only 4k which isn't really worth it right now. Will be years before there is 4k content and projectors are cheap enough to justify the cost.
Rivers Edge Theater
post #16 of 33 Old 06-09-2013, 07:40 PM - Thread Starter
LexMan's Avatar
Ah I see. I can put one of them nearfield and the other by the screen wall.
I have acoustic treatments in my theater but want a higher end receiver for:
- audissey EQ - only the high end receiver and pre amps have the better version
- pre outs - I have a separate 7 channel amp for my main speakers
- refurb - I can get a refurbished high end for the same price as a normal priced receiver
I agree 4 k is a ways off, but with HDMI 2.0 will also include Dolby Atmos and DTS equivalent
If not, will wait until material and the HDMI version comes with it.
LexMan is offline
post #17 of 33 Old 06-12-2013, 06:55 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Kinda curious how your other subs will sound with the THT. Let us know when you get a chance to integrate them together. Thanks
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #18 of 33 Old 06-12-2013, 03:03 PM
asarose247's Avatar
Quoted: 698 Post(s)
Liked: 454
great reading, lots of diverse reference input from an active community
I really enjoyed reading your journey and then there's all the fans that chipped in then the threads go on and on
the point being
I just finished my THTLP and took advantage of all the info I could stand
pictures at: williamtomkiel.imgur.com
some over kill but there was no hurry.
my build was at te BFM site.
now for some REW.
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is offline
post #19 of 33 Old 06-16-2013, 05:07 AM - Thread Starter
LexMan's Avatar
I will definitely update everyone when I do. I am pushing to finish my theater and figuring out REW.
LexMan is offline
post #20 of 33 Old 06-16-2013, 05:11 AM - Thread Starter
LexMan's Avatar
the point being
now for some REW.
I could not have had the courage to do this build and much of what I have done in my theater without this community.
I see you have an onkyo 818, do you EQ your subs with anything else or just the Audyessy? I ask as that's the receiver I am looking to get.
LexMan is offline
post #21 of 33 Old 06-16-2013, 10:00 AM
Quoted: 978 Post(s)
Liked: 506
Please do. I heard that mixing sealed subs into the chain didn't have a positive outcome. Right now I have a THT and that sucker rocks my theater! It vibrates the seats so no need for buttkickers. I love bass so I wouldn't mind adding some flatpacks if they would integrate well with the THT.
post #22 of 33 Old 06-16-2013, 02:27 PM
Bill Fitzmaurice's Avatar
Liked: 4656
IMO that makes as much sense as adding sails to a cigarette boat. rolleyes.gif
There's so much difference in the sensitivity of the two formats that the sealed subs will be struggling long before the THT begins to break a sweat.
Bill Fitzmaurice is offline
post #23 of 33 Old 06-16-2013, 02:40 PM
Quoted: 978 Post(s)
Liked: 506
True, but not sub 20Hz.
post #24 of 33 Old 06-18-2013, 09:52 PM
asarose247's Avatar
Quoted: 698 Post(s)
Liked: 454
MY 818 in my living room runs my Infinity cascade 15 sub., where I have to deal with 5000 ft# due openings to dining rm/ kitchen
I tried it both ways: First with the Infinity RABOS PEQ and then With Audessy and vice vrsa.
It sounds like the RABOS PEQ first created better overall sound (CO at 80 hz), but I want to run some REW.
My thtlp just installed in the mancave today and going thru some A"deep bass" scenes.
That amp is an Onkyo 270 so no XT 32 but I do have a 1124P that I want to put in the loop. but so fr
WOW.
If I could swing it, I'd get a second 818 but that could amount to massive overkill in 900 ft3.
but for the right price I just might . . .
post #25 of 33 Old 07-04-2013, 06:05 AM - Thread Starter
LexMan's Avatar
Decided to have a part two to this adventure
Just received my second Dayton sub and plate amp + 8 10-32 2" screws with lock washers
Stay tuned! Also EQ ideas suggestions welcome
LexMan is offline
post #26 of 33 Old 07-04-2013, 11:11 AM
Liked: 68
Atta boy =)
For EQ, Behringer Feedback Destroyer or MiniDSP are two good options
post #27 of 33 Old 07-04-2013, 04:55 PM - Thread Starter
LexMan's Avatar
Lol thanks Brad. Which do you use BFd or MiniDP?
LexMan is offline
post #28 of 33 Old 07-04-2013, 05:52 PM
Liked: 68
I use the BFD, works well and cheap (eBay) - and I like the rack form factor
post #29 of 33 Old 07-05-2013, 06:02 AM
diaz's Avatar
So can the BFD do parametric EQing?
diaz is offline
post #30 of 33 Old 07-05-2013, 11:27 AM
Liked: 68
Yup
