If you could buy one tool for DIY speakers, what would it be? - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #1 of 33 Old 05-31-2013, 07:40 AM - Thread Starter
WagBoss's Avatar
If you were to buy one tool for DIY speakers, what would you buy? Assume the general size of each piece of wood is cut for the box. What tool would you buy?
WagBoss is offline
post #2 of 33 Old 05-31-2013, 07:42 AM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
What are you using as an edge guide for the circular saw? If you don't have one, either making or buying would be my first step.
If you're good to go there, a good router and bits are invaluable.
Gorilla83 is offline
post #3 of 33 Old 05-31-2013, 07:44 AM
JohnDean's Avatar
Quoted: 470 Post(s)
Liked: 207
Router. If accessories still count in your question then I'd get a circle jig and spiral upcut bit. You can do quite a lot with only this.
JohnDean is offline
post #4 of 33 Old 05-31-2013, 08:00 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
You could build an entire box with driver cutouts using a jigsaw. It wouldn't be very pretty though...
Jay1 is offline
post #5 of 33 Old 05-31-2013, 09:08 AM
pauleyc's Avatar
Quoted: 16 Post(s)
Liked: 24
A good drill/driver and then buy flat packs!
wvu80 likes this.
pauleyc is offline
post #6 of 33 Old 05-31-2013, 09:24 AM
robotbunny's Avatar
Router with plunge and fixed base. 1/4" up spiral bit, 1/2" round over bit, flush trim bit 1/2" x 2". A very close second would be the jigsaw, but you'd still need a drill to do driver cutouts. The router and those three bits you can do most.
Tedd likes this.
robotbunny is offline
post #7 of 33 Old 05-31-2013, 09:26 AM
bass addict's Avatar
Quoted: 441 Post(s)
Liked: 507
Tedd and NODES like this.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #8 of 33 Old 05-31-2013, 09:44 AM - Thread Starter
WagBoss's Avatar
Originally Posted by bass addict View Post
haha good one, and just sit on it for clamping.
WagBoss is offline
post #9 of 33 Old 05-31-2013, 11:52 AM
mtg90's Avatar
Quoted: 490 Post(s)
Liked: 968
Does this count:
http://www.craftsman.com/bolt-on/dap-120000000297215
You could pretty much build your whole box with that one tool, everything you'd need besides clamps and glue.
mtg90 is offline
post #10 of 33 Old 05-31-2013, 12:18 PM
Colm's Avatar
Liked: 94
Frankly, if you are limited to one tool, you should buy a flat pack.
The most useful tool in my experience is a 1 1/2 HP router with 1/4" and 1/2" collets. A plunge base has its uses but is not necessary for most speaker building. If you just need to start a cut in the middle of a panel, you can ease the bit in at an angle. If you really have to do a straight plunge once in a while, you can just loosen the clamp on a fixed based, lower the bit, and retighen the clamp. A circle jig has its uses, but is also unnecessary. You can do the same thing with nothing but a piece of 1/4" plywood scrap with a pivot hole in the right place screwed to the based. Use a router with a straight edge and clamps, and you can true up an edge or even cut a sheet of plywood.
Of course you need router bits. The obvious one is a decent straight bit. I use 1/2" shank bits whenever I can. My all purpose bit is a 1/2" end cutting straight shear cutting bit. A 1/4" bit won't take the abuse a 1/2" bit will. I only use a 1/4" bit when I need a 1/4" slot. Spiral bits have their place, but are not necessary, and will break more easily than straight bits. Round over bits are necessary only if you are going to round over your edges. A flush trim bit slightly larger than the thickness of the panel to be trimmed may be useful. 2" is way too long for most purposes.
Save the money on the plunge base and circle jig and buy yourself a good drill and bits, too.
Colm is offline
post #11 of 33 Old 05-31-2013, 12:22 PM
Quoted: 441 Post(s)
Liked: 507
I wouldn't recommend what you are referring to on the router. A good router with a dual base isn't much more than a fixed base. Trying to use a fixed base like a plunge router is asking for trouble. Guys with lots of experience can get away with "cheating" but I wouldn't recommend a first time DIY'er try this method.
post #12 of 33 Old 05-31-2013, 12:50 PM
Colm's Avatar
Liked: 94
Nonsense. Of course, you need to know what you are doing with any tool.
It is hardly cheating. The first method I described is what everyone who used a router before plunge bases became common did, and it is still common. And the second method is hardly ever used because it is almost never necessary.
...I wouldn't recommend a first time DIY'er try this method.
Fair enough. We all have our own comfort levels. If you are not comfortable, use a plunge base.
FWIW I would recommend against using glue. You might glue you hand to your face. biggrin.gif
NODES likes this.
Colm is offline
post #13 of 33 Old 05-31-2013, 12:56 PM
Colm's Avatar
Liked: 94
Originally Posted by mtg90 View Post
...clamps...
"You can never have too many clamps."
Norm, New Yankee Workshop
Tedd likes this.
Colm is offline
post #14 of 33 Old 05-31-2013, 01:03 PM - Thread Starter
WagBoss's Avatar
The most useful tool in my experience is a 1 1/2 HP router with 1/4" and 1/2" collets. A plunge base has its uses but is not necessary for most speaker building. If you just need to start a cut in the middle of a panel, you can ease the bit in at an angle. If you really have to do a straight plunge once in a while, you can just loosen the clamp on a fixed based, lower the bit, and retighen the clamp. A circle jig has its uses, but is also unnecessary. You can do the same thing with nothing but a piece of 1/4' plywood scrap with a pivot hole in the right place screwed to the based. Use a router with a straight edge and clamps, and you can true up an edge or even cut a sheet of plywood.
This is just a hypothetical for fun question :P I have tools.
WagBoss is offline
post #15 of 33 Old 05-31-2013, 01:17 PM
Quoted: 441 Post(s)
Liked: 507
And car wheels used to be made from stone, and people read by candle lights, and washed their clothes in the river and............... wink.gif
I'm perfectly comfortable using my tablesaw without a riving knife or push stick; but that doesn't mean I should.
post #16 of 33 Old 05-31-2013, 01:28 PM
Colm's Avatar
Liked: 94
And car wheels used to be made from stone...
Sounds like you are the one who has been sniffing glue...
Colm is offline
post #17 of 33 Old 05-31-2013, 01:33 PM
Quoted: 441 Post(s)
Liked: 507
post #18 of 33 Old 05-31-2013, 02:02 PM
dtsdig's Avatar
Quoted: 911 Post(s)
Liked: 1037
My vote is for a good router and quality bits. I have only had a router (Bosch plunge/fixed kit) since Christmas last year and I've found it to be my go-to tool for the sub build I am working on. I absolutely love my router especially for the fact that I can correct the terrible cuts made by my terrible circular saw and edge guide. I agree that the circle jig is not necessary, but I use one anyway; the Jasper.
dtsdig is online now
post #19 of 33 Old 05-31-2013, 09:33 PM
loopaddiction's Avatar
CNC.
Tedd and uniquepattern like this.
loopaddiction is offline
post #20 of 33 Old 05-31-2013, 10:25 PM
steve nn's Avatar
Liked: 433
Black adder likes this.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #21 of 33 Old 06-01-2013, 05:07 PM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
A good measurement system. Woodwork can easily be farmed out to a variety of sources.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #22 of 33 Old 06-02-2013, 02:59 AM
yelnatsch517's Avatar
Liked: 24
Originally Posted by loopaddiction View Post
CNC.
I think this wins.
homeskizzle and uniquepattern like this.
yelnatsch517 is offline
post #23 of 33 Old 06-02-2013, 07:28 AM
pitviper33's Avatar
Quoted: 267 Post(s)
Liked: 117
Single tool for building speakers? And it can be anything? How about a buddy that's an expert wood finisher? Making functional speakers is easy. Making pretty speakers is hard.
pitviper33 is offline
post #24 of 33 Old 06-02-2013, 08:22 AM
cogeng182's Avatar
Well I DO have a buddy that is kind of a tool....
cogeng182 is offline
post #25 of 33 Old 06-02-2013, 11:54 AM
steve nn's Avatar
Liked: 433
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #26 of 33 Old 01-29-2016, 07:38 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Festool track saw. Cordless Brad nailer.
N8DOGG likes this.
Mfusick is offline
post #27 of 33 Old 01-31-2016, 06:06 AM
thesamarai's Avatar
Quoted: 67 Post(s)
Liked: 45
Nail gun
thesamarai is offline
post #28 of 33 Old 01-31-2016, 07:20 AM
wyattroa's Avatar
Quoted: 166 Post(s)
Liked: 117
www.AVSFORUM.www <-------this was the best tool I used when making mine.
ORIF, NODES and uniquepattern like this.
Sub build http://www.avsforum.com/forum/155-di...et-r-done.html
Center - JBL LC2
Mains - JBL L820
Surrounds - JBL L820
Sub - Dual UXL'18 enclosures,iNuke6000dsp
wyattroa is offline
post #29 of 33 Old 01-31-2016, 10:44 PM
Quoted: 12 Post(s)
Liked: 7
A 5 gallon bucket to stand on...
specd is offline
post #30 of 33 Old 02-01-2016, 01:25 AM
Manic1!'s Avatar
Quoted: 198 Post(s)
Liked: 92
Membership to your local makerspace because they have all the tools.
Manic1! is offline
