Dual Othorn build - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 36Likes
post #241 of 268 Old 01-25-2015, 09:51 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
Originally Posted by redliner140 View Post
Hey Luke, do you mind sending me the file to the Gjallarhorn and the Othorn please? Thx
srad750c@gmail.com
email ricci u can find his email address on data-bass.com
cookieattk is offline
post #242 of 268 Old 01-27-2015, 05:23 PM
redliner140's Avatar
Quoted: 28 Post(s)
Thanks Luke
redliner140 is offline
post #243 of 268 Old 01-27-2015, 05:25 PM
Quoted: 28 Post(s)
Thanks, but Luke hooked me up.
post #244 of 268 Old 09-24-2015, 07:42 AM
jdaddieo's Avatar
Quoted: 13 Post(s)
Liked: 25
Originally Posted by Gorilla83 View Post
How are these bad boys coming? I'm definitely interesting in building either two of these or G-horns at some point. I've found a local source for good, reasonably priced BB so I can begin to get more serious. I'm almost thinking it would be wise to keep some of my sealed 18s for the real low stuff and add in 2 of the O's to kill the mid-upper range.<br><br>
How does one get a hold of the detailed plans?
Hey Gorilla83 Where are you in DE? I'm in New Castle and Russel Plywood carries baltic birch in all thicknesses with the 5' X 5' sheet being standard but 4 X 8's are available. They do deliver in tri-state area but call them for requirements @1-800 -373-1004. Their main warehouse is in Reading, PA and have the satellite warehouse in New Castle
jdaddieo is offline
post #245 of 268 Old 09-25-2015, 06:36 AM
Liked: 0
Plans
Hey, is anybody in this thread able to share the plans to build Gjallarhorn and Othorn with me? I have e-mailed Ricci and also messaged him on 2 other forums to no avail. He must get a lot of messages and e-mails! My e-mail is bradford.andy@gmail if anyone can help. Thanks!
Andy Bradford is offline
post #246 of 268 Old 09-25-2015, 06:50 AM
chrapladm's Avatar
Quoted: 822 Post(s)
Liked: 286
Ricci has stated already that HE is not giving the plans out anymore. The Ghorn's driver isnt available and he has given the Othorn plans out to plenty of people. SO maybe someone else can give you them but Ricci is not doing so anymore.
chrapladm is online now
post #247 of 268 Old 09-25-2015, 03:23 PM - Thread Starter
lukeamdman's Avatar
Quoted: 1071 Post(s)
Liked: 1187
You want Ghorn V1 or V2 plans?
lukeamdman is offline
post #248 of 268 Old 09-25-2015, 05:17 PM
blah450's Avatar
Quoted: 138 Post(s)
Liked: 169
Luke...I sent him the GV2 plans, but did not have Othorn plans. Would you mind swinging those my way when you get a moment? Thank you, sir.
blah450 is offline
post #249 of 268 Old 09-26-2015, 12:26 PM
stegen's Avatar
Quoted: 93 Post(s)
Liked: 84
Anybody have the cad files for the othorn?
stegen is online now
post #250 of 268 Old 10-07-2015, 08:33 AM - Thread Starter
lukeamdman's Avatar
Liked: 1187
Here's the impedance of the 21-IPAL loaded in the Othorn. I measured this with a pair of Fluke meters so I could capture volts and amperage at the same time.
I started with 1v of output from the amp but that was getting annoying to listen to, so I switched to .5v for the remainder of the measurements.
post #251 of 268 Old 10-08-2015, 07:14 PM
Stereodude's Avatar
Quoted: 3084 Post(s)
Liked: 2236
I better go check the thread on the forum at DB and see what that lead to.
Stereodude is offline
post #252 of 268 Old 10-10-2015, 03:46 PM - Thread Starter
lukeamdman's Avatar
Liked: 1187
There were some questions about the actual resistance of the load being presented to the amplifier during music playback. The 21-IPAL driver has a DCR of 0.7ohms, which is obviously unusually low.
The first track I chose was around 2.1ohm during the lowest part of the track around 33hz. I then chose another track that opens with 6-7 seconds of 27.5hz. The track is the "low and slow" version of "Earth" by Bass Launch. Here's what the SpecLab of the beginning of the track looks like:
Here's the 6 second loop of the track I created to measure the voltage and amperage with:
This track presented a 1.2ohm load to the amp.
Using a Fluke 117, which measures RMS voltage, I then measured how much voltage I could get from the SP2-12000 under that load.
I measured 86.5v at the threshold of clipping, which produced 131.1db at the LP from a single Othorn (at 27.5hz).
I pushed a little further to 88v which produced 132.0db and clip lights on the amp.
That much power to any single driver can become catastrophic really quick, so I limited these "bursts" of the Bass Launch track to about 2 seconds.
post #253 of 268 Old 10-10-2015, 06:14 PM
Stereodude's Avatar
Liked: 2236
I noticed no one at DB could be bothered to do the math because they're all too busy trying to write snarky posts to one another, but that's just over 6.2kW (86.5^2/1.2).
lukeamdman likes this.
post #254 of 268 Old 10-10-2015, 06:44 PM
chrapladm's Avatar
Quoted: 822 Post(s)
Liked: 286
Well most people at the DB forum know the math and use volts to describe power. I know majority use watts here but after simulating a LOT of designs I use volts now also. BUT ya the thread is a bit all over the place.
post #255 of 268 Old 10-12-2015, 08:47 AM - Thread Starter
lukeamdman's Avatar
Liked: 1187
Yesterday I did the same test just with both channels driven this time.
I was able to hit the same 86.5v without clipping and registered 139.0db.
I then bumped the volume by .5db and registered 91.3v and 139.3db...? Also, no clipping with this?
I then bumped the volume by another .5db and registered 91.3v briefly and it then went back down to 86.5v. The SPL briefly hit 139.6db but went back down to 139db. I assume there were clip lights but I only ran the test at this volume once since after this I could smell a little bit of voice coil from the subs if I got right up next to them.
It doesn't appear that that 2ch vs. 1ch has any impact at all on the output. Considering it is two independent amp modules in a single chassis, I guess that makes sense.
post #256 of 268 Old 03-19-2016, 09:13 AM
Liked: 2
great work luke, this project looks amazing i cant wait to build 4 of my own. if you could send me the plans to jar.w@hotmail.co.uk it would be much appreciated.
Jared White is offline
post #257 of 268 Old 03-19-2016, 09:19 AM - Thread Starter
lukeamdman's Avatar
Liked: 1187
Sent.
post #258 of 268 Old 03-19-2016, 09:32 AM - Thread Starter
lukeamdman's Avatar
Liked: 1187
And dang, I'm coming up on 3 years running the Othorns and they're still may favorite 25-120hz bass.
post #259 of 268 Old 03-19-2016, 10:38 AM
Michael Mitten's Avatar
Quoted: 189 Post(s)
Liked: 164
Just played this. Sure did shake the house. Parts even tickled my nose. LOL It's on my demo list now.
Michael Mitten is offline
post #260 of 268 Old 03-21-2016, 03:21 AM
Liked: 2
thanks luke cant wait to start the build
post #261 of 268 Old 03-27-2016, 05:26 AM
Liked: 1
Hi Luke,
I must say, your Othorns came out very nice! Do you have a lot of experience with woodwork?
I mostly use Polyurethane paint on my cabs, but the Duratex looks good (You use Duratex rigth?)
Something i have to try out
I currently have four Cubo 18" loaded with Royal Turbomax 1500s.
I need more SPL under 45 hertz, and here the Cubos are a little weak.
looking for other designs the Othorn got my attention, extension below 30Hz and more SPL than my Cubo over 40Hz... Seems to be a good upgrade and also pair up good with two Xtro above 80Hz.
Sooo, could you please send me the plans for the Othorn V2?
My email is: "sgjorstad@cokecce.com"
Ricci.
Thanks to you, people like me can build powerful and better cabs than the OEM
Good luck with the PaleHorn, looking forward to see some measurements.
Thanks, Simen.
Cubo 18", Xtro, itech 4000
Simen Gjørstad is offline
post #262 of 268 Old 03-27-2016, 04:01 PM - Thread Starter
lukeamdman's Avatar
Liked: 1187
Originally Posted by Simen Gjørstad View Post
Hi Luke,
Ricci.
Thanks, Simen.
Sent.
When I started this hobby in 2011 is really when I started woodworking as well. I learned as I went and acquired tools along the way.
post #263 of 268 Old 05-06-2016, 03:52 PM - Thread Starter
lukeamdman's Avatar
Liked: 1187
post #264 of 268 Old 05-06-2016, 05:35 PM
bossdog304's Avatar
Quoted: 55 Post(s)
Liked: 57
Next time I'll try and get some driver excursion for the Othorns. I've avoided it thus far because getting it means I have to be in close proximity!
So that's how you pay for all these things! Rattle change out of unsuspecting enthusiasts pockets.
bossdog304 is online now
post #265 of 268 Old 05-06-2016, 08:45 PM
WereWolf84's Avatar
Quoted: 224 Post(s)
Liked: 85
@WereWolf84
https://youtu.be/MaiOXeX-U_I
Wow, that's some serious tactile feel at your MLP although Othorns placed at front wall makes me really want to build dual Othorns
WereWolf84 is offline
post #266 of 268 Old 08-30-2016, 05:32 PM
Liked: 0
Plans
Hey luke. I'm super new here but was wondering if I could get the plans for the v2 Othorns. I think they may be the most perfect sub for me I have seen based on specs and measured performance. Here is my email: biglep2015@ gmail.com
I would very greatly appreciate man.
BIGlep is offline
post #267 of 268 Old 08-30-2016, 05:46 PM - Thread Starter
lukeamdman's Avatar
Liked: 1187
Sent.
post #268 of 268 Old 08-30-2016, 06:21 PM
Quoted: 26 Post(s)
Liked: 5
@WereWolf84
Love this!
m_power is offline
