amp help behringer ep2000 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 06-02-2013, 05:33 PM - Thread Starter
flexinator's Avatar
You'll never believe it. I'm a huge jerk. After this whole saga... i decided to use some new wires inside the box to connect the subs together (since they are wired in series). And boom. they are now hitting huge. I can feel the ground vibrate 2 floors up. I knew that they weren't huge subs, but i knew they would be louder than what i was getting. I do want to thank everyone for all the help. I learned alot about how to troubleshoot... but in the end its always something simple.
now its on to figuring out what kind of dimmer for my led rope lights won't make them flicker...
flexinator is offline
Old 06-02-2013, 07:57 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 440
Good to hear you got it figured out. 99% of the time the biggest issues stem from the smallest problems.
I really like Smarthome dimmers. They work great on my stage, sofit, and riser rope lighting. Dim at multiple settings with no flicker. Only minor setback is the switches flow enough current even when off that the lights will never completely dim. Not really an issue for me but YMMV.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
Old 06-02-2013, 08:01 PM
Mrkazador's Avatar
Quoted: 258 Post(s)
Liked: 386
So what was wrong with the old speaker wire? Were they wired incorrectly?
Mrkazador is online now
Old 06-02-2013, 08:21 PM - Thread Starter
flexinator's Avatar
No it was wired correctly, I even checked the impedance(which was fine, so not a short)
I suspect that the end of it was corroded or something, the connecting wire didn't look to be copper. I re-wired it with fresh 12ga.
That box kicked for a few years in my car then lived in the basement for a few years...
Old 06-03-2013, 08:37 AM - Thread Starter
flexinator's Avatar
In case you wanted to see the faulty wire... here's a nice pic. I want to mention, when I originally bought the box, this wire was part of the original setup. It isn't a very nice wire, and looking at it now, I can't believe I never replaced it.
Denon Avr3312ci Receiver
