The Great Waveguide Shootout!!! - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #181 of 194 Old 09-18-2013, 06:29 PM
tuxedocivic's Avatar
Quoted: 1807 Post(s)
Liked: 1642
I would expect a waveguide to have less diffraction than a diffraction modeler suggests. Very odd.
tuxedocivic is offline
post #182 of 194 Old 09-18-2013, 10:30 PM
rahula7's Avatar
Originally Posted by mtg90 View Post
Yeah but switched early on from a baffle that rotates and mic stays put to a mic that rotates while the baffle stays put. That way I did not have to glue in the fiberglass waveguides which don't have mounting holes. If I hang the mic it will always point strait down while it rotates instead of always pointing at the center of the baffle.
I think that confirms it... it must be the wood strip on which the mic is mounted. That is why the dip is at the same frequency at all angles. If it was from the baffle, then the distance to the baffle would change with angle, producing different time delays at different angles.
rahula7 is offline
post #183 of 194 Old 09-19-2013, 11:25 AM
noah katz's Avatar
Quoted: 821 Post(s)
Liked: 279
The SEOS doesn't have a particularly large end radius.
I is curious ha something with high directivity is so sensiive o his, but Geddes makes a big deal over it.
Noah
noah katz is offline
post #184 of 194 Old 09-19-2013, 11:58 AM
johnbomb's Avatar
I looked again at your setup in the first post. Maybe put a bunch of OC 703 rigid fiberglass or foam on the wood crossbar as well as the posts, which should knock out any reflections.
Also, measure a waveguide at 0 degrees first with the mic holding jig, then a measurement with the mic just hanging from its cable at 0 degrees with the wooden mic jig rotated completely out of the way. You could also do one with the jig set to 0 degrees with fiberglass/foam. Compare all three and see what you get.
johnbomb is offline
post #185 of 194 Old 10-17-2013, 08:34 PM - Thread Starter
mtg90's Avatar
Quoted: 344 Post(s)
Liked: 623
This thread is long overdue for an update...
Well it has been determined that the wooden mic support jig is at fault for the ragged response while mounted on the baffle.
It was almost three weeks ago Pitviper33 (another Matt smile.gif) came over for a few hours during the evening and we measured the response with the mic mounted in the jig vs. the jig moved away and the mic on a normal mic stand/boom. The mic stand measurement was free of the lumpiness exhibited with the wooded jig so the wooded jig must have been at fault. We then tried all sorts of different amounts and styles of damping material to knock out the reflection in almost every position or combination possible. Nothing worked to completely eliminate that reflection, not even coating the whole wooden jig with full 3-1/2" thick R-13 batts of recycled denim insulation!!!
Matt might have some pictures of our feeble attempts.
Here is a measurement comparing waveguide free air, waveguide in baffle with mic in stand, waveguide on baffle with mic in jig. Spaced 5db apart:
So at this time I am going back to the first idea which was to have the baffle rotate and the mic remain in a constant position which will allow me to use the mic stand which I know has no detrimental effects on the response. Matt did suggest an excellent way to setup the baffle so that I do not need to glue in the fiberglass waveguides to keep them from falling out and that is to measure my 0 with the baffle angled at 45 degrees on way then I can move the baffle in the opposite direction so that 45 degree measurement angle will have the baffle flat and at 90 degrees the baffle will be in the opposite 45 degree position.
The real problem now becomes how much time is left to take outdoor measurements. With my trip to Erich's next week I don't think I am going to get a chance to do much more work on it this season. frown.gif
Back when I started this I thought I could knock this out in a week or two, look how that turned out rolleyes.gif
So unless I get everything out sometime this next week or Chicago has some really nice weather this November/December I think this project might go into hibernation till spring rolls around.
mtg90 is offline
post #186 of 194 Old 10-17-2013, 08:46 PM
LTD02's Avatar
Quoted: 2170 Post(s)
Liked: 2387
could the whole thing be salvaged by mounting a triangle shape to the jig arm so that it doesn't reflect?
Listen. It's All Good.
LTD02 is offline
post #187 of 194 Old 10-17-2013, 08:52 PM
LTD02's Avatar
Liked: 2387
something like this cut into strips and attached to the jig?
if the problem is something else, then just ignore me. :-)
LTD02 is offline
post #188 of 194 Old 10-18-2013, 09:08 AM
Ricci's Avatar
Quoted: 152 Post(s)
Liked: 411
Yep...I always think the same thing. That's just how it goes.
Ricci is offline
post #189 of 194 Old 10-18-2013, 09:48 AM
rahula7's Avatar
That's great! At least you what the problem is. We will be waiting come spring smile.gif
rahula7 is offline
post #190 of 194 Old 10-19-2013, 07:25 AM
pitviper33's Avatar
Quoted: 267 Post(s)
Liked: 116
I do have a picture!
I've been pretty swamped this summer/fall, so I haven't kept up with threads all that well. I should have posted this weeks ago.
We tried at least five different setups of absorbing material on that rig, and somehow we still never got a clean measurement. I don't have pictures of all of them. But the good news is that I think we settled on a method that should work when you next have time to test. The tilting table +45 to -45 should let you use the boom stand without worry of waveguides falling out.
Glad to hear you're heading down to Eric's. I'm sure with the two of you guys in one place, lots of interesting speaker things will happen! Let me know when you're back and find a reasonably warm day. I'd love to come over and help again for the real test!
pitviper33 is offline
post #191 of 194 Old 10-26-2014, 08:01 AM
Eyleron's Avatar
Quoted: 225 Post(s)
Liked: 115
Originally Posted by pitviper33 View Post
<div class="quote-container" data-huddler-embed="/t/1475674/the-great-waveguide-shootout/180#post_23849303" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>mtg90</strong> <a href="/t/1475674/the-great-waveguide-shootout/180#post_23849303"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
This thread is long overdue for an update...<br><br>
Well it has been determined that the wooden mic support jig is at fault for the ragged response while mounted on the baffle.<br><br>
It was almost three weeks ago Pitviper33 (another Matt <img alt="smile.gif" class="bbcode_smiley" src="http://files.avsforum.com/images/smilies/smile.gif">) came over for a few hours during the evening and we measured the response with the mic mounted in the jig vs. the jig moved away and the mic on a normal mic stand/boom. The mic stand measurement was free of the lumpiness exhibited with the wooded jig so the wooded jig must have been at fault. We then tried all sorts of different amounts and styles of damping material to knock out the reflection in almost every position or combination possible. Nothing worked to completely eliminate that reflection, not even coating the whole wooden jig with full 3-1/2" thick R-13 batts of recycled denim insulation!!!<br><br>
Matt might have some pictures of our feeble attempts.</div>
</div>
I do have a picture!<br><a class="H-lightbox-open" href="http://www.avsforum.com/content/type/61/id/295640/"><img alt="" class="lightbox-enabled" data-id="295640" data-type="61" src="http://www.avsforum.com/content/type/61/id/295640/width/200/height/400/flags/LL" style="; width: 200px; height: 150px"></a><br>
I've been pretty swamped this summer/fall, so I haven't kept up with threads all that well. I should have posted this weeks ago.<br><br>
We tried at least five different setups of absorbing material on that rig, and somehow we still never got a clean measurement. I don't have pictures of all of them. But the good news is that I think we settled on a method that should work when you next have time to test. The tilting table +45 to -45 should let you use the boom stand without worry of waveguides falling out.<br><br>
Did the tests get resumed or moved to another thread?
Eyleron is offline
post #192 of 194 Old 10-27-2014, 09:17 AM
pitviper33's Avatar
Quoted: 267 Post(s)
Liked: 116
This was really Matt's (@mtg90) project. I just lived close to him, so I was helping out. I've now moved away, so I'm not going to be able to help in person anymore. I have no idea whether he's watching this thread. If I can figure out how to "mention" him in this post, I will to draw his attention.
He'll have to give the official word, but I believe that testing has not resumed. I spoke to him a couple weeks ago, and it sounded like he'd been kept busy by other projects and never got to it over the summer. It's already getting cold again in his neck of the woods, and I don't blame him at all for choosing not to do this kind of testing in the winter!
Last edited by pitviper33; 10-27-2014 at 09:20 AM. Reason: Trying to "tag" or "mention" mtg90.
post #193 of 194 Old 06-20-2015, 08:59 AM
Defo's Avatar
-snip
How did you get directivity so low with the SEOS-12 mounted on baffle?
Do you have a picture of it mounted on the baffle?
In regards to this measurement of yours:
Defo is offline
post #194 of 194 Old 06-21-2015, 03:36 PM - Thread Starter
mtg90's Avatar
Quoted: 344 Post(s)
Liked: 623
That is the EOS-6 waveguide, and I believe the extension of directivity control you are seeing is in part due to the diffraction off the speaker cabinet.
I believe this is the cabinet I used for that test:
mtg90 is offline
