The Great Waveguide Shootout!!! - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1 of 195 Old 06-03-2013, 07:15 PM - Thread Starter
mtg90's Avatar
Quoted: 496 Post(s)
Liked: 974
The measurements have started! See next post for index.
This will be a purely objective look at how the waveguides perform, Frequency Response, SPL, Off Axis Polar Response and Distortion. Due to the amount of waveguides and measurements needed it would likely be all but impossible to take all of them in one day so care will be taken to make sure the testing setup is properly configured (distances, angles, drive levels) each time.
Waveguides to be included in testing
SEOS-6, 8, 10, 12, 15,18 and 24
H290c,
QSC,
Dayton H512,
EOS-10, EOS-9?, EOS-8, EOS-6,
Denovo DW-854B, DW-774s, DW-62s, DW-654s, DW-7ES
And a few others.
Threaded waveguides will be tested with the DNA-150 along with some of the other small ones. Then most of the small and mid sized waveguides will be measured with the DNA-205 (comparable to the B&C DE10). Finally many of the mid and larger 1" waveguide will be testing using the DNA-360 (comparable to the B&C DE250). The SEOS-24 will be tested using the BMS 4594 1.4" coax.
The measurements will be done using REW (I am most familiar and comfortable with it and find it does everything I want it to) Microphone will be the Dayton UMM-6, amp will be a Audio source AMP-100, drive level will be set using a 60hz sine wave.
Baffle setup:
maxcooper, eXa and Sibuna like this.
mtg90 is offline
post #2 of 195 Old 06-03-2013, 07:15 PM - Thread Starter
mtg90's Avatar
Quoted: 496 Post(s)
Liked: 974
Index of measurements.
Using the DNA-150 CD:
DW-62S,
DW-774S,
Smaller round unnamed waveguide,
DW-654S,
DW-7ES,
EOS-6,
Using the DNA-205 (comparable to DE10):
Measurements to come soon.
Using the DNA-360 (comparable to DE250):
mtg90 is offline
post #3 of 195 Old 06-03-2013, 07:15 PM - Thread Starter
mtg90's Avatar
Quoted: 496 Post(s)
Liked: 974
Reserved
mtg90 is offline
post #4 of 195 Old 06-03-2013, 08:47 PM
lukeamdman's Avatar
Quoted: 1229 Post(s)
Liked: 1516
Awesome! You mentioned this as an idea before and I'm really glad you're making it happen!
lukeamdman is offline
post #5 of 195 Old 06-03-2013, 08:53 PM
NWCgrad's Avatar
Quoted: 1272 Post(s)
Liked: 1311
Nice, should prove to be valuable to the diy community.
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
post #6 of 195 Old 06-03-2013, 09:24 PM
Eternal Velocity's Avatar
Quoted: 33 Post(s)
Liked: 63
This sounds really cool.
After the initial round of measurements, I'd be really interested in hearing if some extensional mode damping might affect the measured results.
Eternal Velocity is offline
post #7 of 195 Old 06-03-2013, 11:27 PM
mhutchins's Avatar
Quoted: 99 Post(s)
Liked: 121
Wow, Matt!
I can't believe the scope of this undertaking! We all owe you a huge debt of gratitude. Thank you so much for this and all your other contributions to the cause. wink.gif
Mike
mhutchins is offline
post #8 of 195 Old 06-04-2013, 12:15 AM
notnyt's Avatar
Quoted: 2791 Post(s)
Liked: 2575
Originally Posted by mhutchins View Post
Wow, Matt!
Mike
+1
nice work
notnyt is offline
post #9 of 195 Old 06-04-2013, 01:05 AM
popalock's Avatar
Quoted: 1315 Post(s)
Liked: 1814
Awesome Matt.
I'll be following along for sure.
popalock is offline
post #10 of 195 Old 06-04-2013, 04:11 AM
countryWV's Avatar
Quoted: 413 Post(s)
Liked: 593
If you are interested in trying out the 4550 with the bigger waveguides let me know and I'll send it.
I would like to see how much it is limited by the Seos 12.
Your a hard working man Matt
Thanks for your time.
Chris W
Chris
countryWV is offline
post #11 of 195 Old 06-04-2013, 04:11 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
This is a great thing that you are doing for our community, Matt! When do you plan on getting started?
Do you already have the Seos waveguides? I am just curious to know if you will have to order the Seos-18 and Seos-24 and wait on them to be shipped to you from Poland?
Martycool007 is offline
post #12 of 195 Old 06-04-2013, 04:57 AM
Ivan Beaver's Avatar
Quoted: 16 Post(s)
Liked: 59
Just remember that the same horn/waveguid can have different polar patterns when different drivers are used. THis can be VERY radical-or totally non existant-depending on the particular driver and horn combination.
It is REAL easy to read too much into a measurement of a single driver-UNLESS htat is the driver/horn combo that is actually going to be used.
I first becasue aware of this decades ago when I tried 2 different drivers (same manufacturer) on a single horn. ONe driver was VERY narrow in its coverage and the other "filled out" the horn the way it was supposed to be.
HOWEVER-when I used a different horn/type/coverage etc (same drivers) both drivers had the same coverage.
It all comes down to how well the horn./driver interaction/angles of exit and so forth "work together".
I remember hearing about a comparison back in the 80's in which Manufacturers A was saying their drivers were better than manufacturer B and they had the data to prove it. Yet manufacturer B saide theirs were better and THEY had the data to prove it.
HOWEVER the variable was that while the different drivers were being used-the horn they were placed on was made by the particular manufacturer. So each manufacturers driver perfromed better on THEIR horn-but not as good on the other manufacturers horn.
Just something to keep in mind.
Danley Sound Labs
Physics-not fads
Ivan Beaver is offline
post #13 of 195 Old 06-04-2013, 05:15 AM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
Umm....SUBSCRIBED for this feast of waveguide goodness!
Gorilla83 is offline
post #14 of 195 Old 06-04-2013, 05:36 AM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
looks good.
Listen. It's All Good.
LTD02 is offline
post #15 of 195 Old 06-04-2013, 06:01 AM
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
Sibuna is offline
post #16 of 195 Old 06-04-2013, 06:09 AM
tsloms's Avatar
Quoted: 55 Post(s)
Liked: 61
Matt, if you'd like to test it I could offer up a BMS 4594 CD on an XR1464 horn.
This should be a fun comparo!
tsloms is offline
post #17 of 195 Old 06-04-2013, 06:12 AM
cogeng182's Avatar
cogeng182 is offline
post #18 of 195 Old 06-04-2013, 06:38 AM
tuxedocivic's Avatar
Quoted: 2201 Post(s)
Liked: 2075
Right on !
My youtube channel: Impulse Audio
tuxedocivic is online now
post #19 of 195 Old 06-04-2013, 07:26 AM
pnw
pnw's Avatar
Quoted: 52 Post(s)
Liked: 78
I'll volunteer an 18Sound ND-1460A plus XT-1464. Can also send their 1.4"-2" adapter if it would be helpful (1460 becomes a 2060).
pnw is offline
post #20 of 195 Old 06-04-2013, 07:29 AM
Quoted: 280 Post(s)
Liked: 181
One horn that I have always been curious about is Dave Harris' Eliptrack-400 horn that is used in some Klipsch based builds such as the Cornscalla. This horn goes for almost the same as the Seos24, I believe something between $450 and $500 per pair. I never see these horns mentioned but the guys over at the Klipsch forums say they are top-notch.
post #21 of 195 Old 06-04-2013, 07:33 AM
Kimeran's Avatar
Quoted: 34 Post(s)
Liked: 132
Are you going to include your synergy horn in this test?
Trying to enjoy the simple things in life.
Steam: madbrayniak
Kimeran is offline
post #22 of 195 Old 06-04-2013, 08:20 AM
beastaudio's Avatar
Quoted: 4149 Post(s)
Liked: 3510
Sub'd dude!!!! Great thread!!
beastaudio is online now
post #23 of 195 Old 06-04-2013, 08:53 AM
Mike Garrett's Avatar
Quoted: 7065 Post(s)
Liked: 4772
Looking forward to the results of this thread. smile.gif Thanks Matt
mjgarrett100@gmail.com
Mike Garrett is online now
post #24 of 195 Old 06-04-2013, 09:00 AM - Thread Starter
mtg90's Avatar
Quoted: 496 Post(s)
Liked: 974
Thanks guys, but I am going to try and get through the waveguides I have before starting anymore. That said after I finish with the current round I'll likely take you up on those offers, see if there are any other waveguide or CD's someone would like to volunteer to see tested. I would not test another CD on all the waveguides unless there is a large amount of support for it due to the time it would take. I'll likely test it only on a select few waveguides.
No not going to include that one, not only is it too big and heavy to use with the same turntable but I am trying to convert them to an active/passive crossover and that is not quite done yet. I will have new measurements of them whenever I get that done but it is rather low priority.
Max Phan likes this.
mtg90 is offline
post #25 of 195 Old 06-04-2013, 09:20 AM
lennon_68's Avatar
Very cool! Sounds like there will be at least a little overlap with what augerpro was working on back in 2009. It will be interesting to cross reference the two sets of measurements smile.gif
http://www.avsforum.com/t/1148945/driver-testing-invite
https://sites.google.com/site/drivervault/driver-measurements/horns-and-waveguides
lennon_68 is offline
post #26 of 195 Old 06-04-2013, 10:14 AM
Max Phan's Avatar
Any builds with the Denovo DW-654S waveguide out there?
Max Phan is offline
post #27 of 195 Old 06-04-2013, 10:57 AM - Thread Starter
mtg90's Avatar
Quoted: 496 Post(s)
Liked: 974
mtg90 is offline
post #28 of 195 Old 06-04-2013, 11:38 AM
ChopShop1's Avatar
Quoted: 326 Post(s)
Liked: 325
Sweet! A very nice service to the members here Matt. You keep doing more and more to help in the DIY arena!
ChopShop1 is online now
post #29 of 195 Old 06-04-2013, 04:33 PM
Quoted: 995 Post(s)
Liked: 525
Wow. Impressive effort.
Greatly looking forward to reading more.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #30 of 195 Old 06-04-2013, 05:12 PM
MBentz's Avatar
Quoted: 25 Post(s)
Liked: 43
Ditto the importance of the matching between compression driver and horn.... it can affect distortion too.
Also, will distortion be normalized to spl? ie, eq'd flat? REW doesn't do that automatically....
-Mike Bentz
~It's all about compromise~
MBentz is offline
