Outdoor Amps for Smartphones/Tablets? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 06-05-2013, 11:48 AM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Ok, so it's summer. There's going to parties and cookouts and kis pool party and such.
I don't want to drag my amp/preamp from the basement to the backyard each time i want some music.
So I need an amp that I can hook up my smartphone/tablet and just let it rip.
What do you guys use for outdoor amps?
Something that is cheap, 50-100w, and can withstand abuse from little kids and drunken adults would be ideal.
smokarz is offline
post #2 of 17 Old 06-05-2013, 12:16 PM
benunc's Avatar
I have this amp I used in my bedroom years ago. It's sitting around unused now but I'll probably try it outside this summer for scenarios similar to yours. Not sure it'll get loud enough but we'll see. It's definitely cheap, simple, small, and light wink.gif . Looks like Pyle has some on amazon with more power for maybe double the price.
benunc is offline
post #3 of 17 Old 06-05-2013, 12:51 PM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Thanks, but I am afraid that's not going to cut it. The max output you can expect from that type of amp is maybe 10w before distortion.
I have one driving a pair of speakers on my desktop set up.
I guess I need a REAL amp.
smokarz is offline
post #4 of 17 Old 06-05-2013, 01:25 PM
benunc's Avatar
Yeah, I remember distortion getting pretty bad when turning up music in the bedroom so definitely won't be able to crank it outside. I have houses 30 or so feet on both sides so won't be playing too loud anyways; actually, my logitech speaker dock probably plays as loud as I want to go outside. Maybe you can find something cheap on craigslist and and keep it in on the deck in something reasonably weatherproof?? Of if you don't already own speakers that you have your heart set on using, buy some powered speakers that you can plug the phone directly into.
benunc is offline
post #5 of 17 Old 06-05-2013, 02:51 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Check guitar center for any used pro amps. Theres also these kits http://www.parts-express.com/pe/showdetl.cfm?partnumber=320-303
Mrkazador is offline
post #6 of 17 Old 06-05-2013, 02:56 PM
maxcooper's Avatar
Quoted: 13 Post(s)
The Dayton dta-100a might be a good choice. It's small, light and easy to hook up. I have one that I use in a bedroom system, and occasionally on bike rides (with battery power).
maxcooper is offline
post #7 of 17 Old 06-05-2013, 03:00 PM
maxcooper's Avatar
Quoted: 13 Post(s)
A receiver from goodwill or a pawn shop would also be good. (If htib hasn't destroyed that market.)
Anyone on here have and old receiver they'd like to get rid of in smokarz's area? smile.gif
-Max
post #8 of 17 Old 06-05-2013, 03:13 PM
Manic1!'s Avatar
Quoted: 172 Post(s)
Liked: 73
http://www.musiciansfriend.com/pro-audio/behringer-eurolive-b205d-active-pa-monitor-speaker
5,5 inch speaker with a 150 watt amp and 3 channel mixer built in, I use one for out door events for background music and speeches with over 150 people. It also mounts on a mic stand and I have used it on a UPS battery back up for over 3 hours.
Manic1! is offline
post #9 of 17 Old 06-05-2013, 06:03 PM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Thanks for the suggestions guys.
Maybe I'll look on CL for something cheap.
I was also looking at Guitar Center for a used Behrignher, maybe an EP1500.
I have some spare speakers, so not looking to spend more on powered speakers.
smokarz is offline
post #10 of 17 Old 06-05-2013, 06:14 PM
t3steve's Avatar
I am using a Daton dta100. It's fastened to the underside of a small patio table. It's protected from spills that way. Works great
t3steve is offline
post #11 of 17 Old 06-06-2013, 06:00 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
The Emotiva mini-X a-100 is on sale right now, its a compact amp with plenty of power.
http://shop.emotiva.com/collections/amplifiers/products/a100
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #12 of 17 Old 06-06-2013, 06:59 AM
scardeal's Avatar
I'm planning a "boombox" build with the Dayton DTA-100A as the amp. I'm undecided on the exact specs, but it's either going to be a modified version of Paul Carmody's "sprite" or a boomboxification of Jed Kunz's Lineup F4. The sprite is the cheaper and easier build, but I think the Lineup F4 would wind up sounding better.
Lineup series- http://www.htguide.com/forum/showthread.php?27583-Lineup-Series-Build-Thread-(F4-D4-D44-R4-R44)
Sprite - https://sites.google.com/site/undefinition/sprite
Either will wind up being easier and nicer sounding than pulling out a receiver, speaker wire, and the crap HTIB cube speakers that I used last time.
scardeal is offline
post #13 of 17 Old 06-08-2013, 09:16 AM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Anyone got experience with the Pioneer A-20 amp?
Looks pretty decent for under $150
smokarz is offline
post #14 of 17 Old 06-08-2013, 01:56 PM
pioneertop's Avatar
Quoted: 28 Post(s)
Liked: 176
where did you see this for that grate price
loves...home theather/music/football:)
pioneertop is offline
post #15 of 17 Old 06-08-2013, 01:58 PM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
On Pioneer website. Look under their refurb section.
smokarz is offline
post #16 of 17 Old 06-08-2013, 09:59 PM
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
I use an IPR-1600 on what ever speakers I have handy.. They run fine the headphone out on my iPhone.
Ran all day in 100+ degrees today, pushing my L710s (4ohms)
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
And a bunch of DIY speakers and subs.
Coming soon: Dirac Room Correction
Stumbo is offline
post #17 of 17 Old 06-09-2013, 10:27 PM
zhillsguy's Avatar
I built one with the DTA-100A, bought one a couple of years ago (maybe 3) when they had "seconds" or something to that effect for $50 at PE. Based the design on the Denovo Mini Elliptical w/the Aura buyouts designed by bwaslo, sadly the Auras are nla:
http://www.diysoundgroup.com/compression-drivers/dna-10.html
Pleased with the amp, definitely recommended unless you really need PA volume levels. I made the box out of 1/2" "Birch" ply (from HD) with both end chambers ported and a separate sealed chamber in the center for the amp and crossover housing. Designed for durability, simplicity, the brain-dead (my college-aged son and friends), and inebriated (me)....simple plug and play, plug in the power cord in the back and music device in the front where the amp access is. Installed a 1"- 24VDC fan in back (powered by DTA power supply), draws in air over the amp and through the center chamber. I keep a 12' power cord from Monoprice tied to the carrying handle so an extension cord is typically not needed.
maxcooper likes this.
zhillsguy is offline
