jbl n26 2's driver replacements ? - AVS Forum | Home Theater Discussions And Reviews
Old 06-07-2013, 12:17 AM - Thread Starter
davece's Avatar
my boss just gave me a set of theese , what happens is the woofer will go in and out. figured i knew what was wrong and i was right.
took them apart and the tinsel leads are loosing connection if u push on them the speaker comes back on and sounds fine.
for now i added a piece of wire from the connector directly to the tinsel leads and they have been working fine. though thats really kinda rigged.but hey the price was right
but i was wondering is there a suitable replacement driver i can get for theese so i dont have to worry about it ? any suggestions
davece is offline
Old 06-07-2013, 09:01 AM
Looneybomber's Avatar
Liked: 25
Depending on how it's broke, you might be able to solder it for a more permanent fix.
YID DIY
Looneybomber is offline
Old 06-07-2013, 03:14 PM - Thread Starter
davece's Avatar
well the tinsel lead is still soldered to the terminal connector what happens is the wire sort of breaks connection in the middle of the tinsel lead , if the speaker stops playing and i use my finger to push on the tinsel lead it will start playing again
what i did is take some stiff strand copper wire and wraped it round the middle of the tinsel lead , then connected it to the terminal
do u think if i put some solder on the tinsel lead itself were i think its losing connection would work?, quess i could just try it since i really dont have anything to lose
davece is offline
Old 06-09-2013, 11:19 PM - Thread Starter
davece's Avatar
thanks i ende dup just tinning the tinsel lead with solder speakers work perfect
im surprised for these lil speakers they have pretty big sound
CraigerSS likes this.
davece is offline
Old 08-08-2013, 02:23 PM - Thread Starter
davece's Avatar
ok so now i really blew one up, had a gig last week and used the jbls for monitors somehow one channel had to much power and i fried the woofer in one of them
can anyone recommend suitable replacement woofers for thees
davece is offline
