Is this a good router? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 06-12-2013, 07:39 AM - Thread Starter
WagBoss's Avatar
WagBoss is offline
post #2 of 23 Old 06-12-2013, 07:46 AM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
That looks like a copy of the Bosch 1617, heh.
Anyone here used one?
Gorilla83 is offline
post #3 of 23 Old 06-12-2013, 07:49 AM - Thread Starter
WagBoss's Avatar
yeah, and the 1617 is $300.00 in canada. This one has a digital display too to automatically change speed based on bit or something.
what exactly is the difference between a plunge router and a fixed base?
Would a plunged router be fine for basically just cutting baffles and rounding edges?
WagBoss is offline
post #4 of 23 Old 06-12-2013, 08:02 AM - Thread Starter
WagBoss's Avatar
WagBoss is offline
post #5 of 23 Old 06-12-2013, 08:04 AM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
A plunge router allows you to "plunge" (vertical movement of the bit) into a solid surface and rapidly change the depth of a cut. This is very useful for cutting holes/baffles for speakers. For edges and trim work a fixed base will work fine.
http://www.homedepot.com/webapp/catalog/servlet/ContentView?pn=Routers&storeId=10051&langId=-1&catalogId=10053
post #6 of 23 Old 06-12-2013, 08:07 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Can a fixed based router also do baffles and driver cut outs, or is a plunge based router best for that purpose? I would imagine that a fixed based router would work fine for that as I think all you would have to do is set the depth, am I correct on that assumption?
Martycool007 is offline
post #7 of 23 Old 06-12-2013, 08:10 AM - Thread Starter
WagBoss's Avatar
Yeah so which one would be better to get, like can't you just set the plunge router all the way down and it's virtually identical to a fixed router? It says fixed is better for edging, but why is that, just because of the weight?
it seems like the fixed router i linked doesn't have variable speed, which would be pretty bad for a 3/4" roundover if it's 25000 rpm.
So should I buy the plunge router 99.99 regular 200?
from my understanding you can do anything with a plunge router, some stuff might be a little more challenging though. You can' t do "plunging" with a fixed based router. So if you only can have 1 router it's better to have a plunge router.
WagBoss is offline
post #8 of 23 Old 06-12-2013, 08:26 AM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
Your best bet is to get a set with interchangeable bases. If you have to choose one only I would get the plunge as you will be able to do most the work with that.
A plunge base is what you want/need for baffle cutouts or any case where you're plunging a new hole in the middle of a board. Generally change the depth with a fixed setup requires you to unlock the base which is not something I'd do with a moving bit IMO. Also, with my fixed base, the bit does not retract up past the surface fully meaning that it could not start a board without a hole. You will need to make multiple passes at increasing depths to perform a driver cutout.
post #9 of 23 Old 06-12-2013, 08:33 AM
JohnDean's Avatar
Quoted: 430 Post(s)
Liked: 183
If you only want 1 base, go with the plunge. You could always set it down to the depth you want just like a fixed base. It comes with both 1/4 and 1/2' collets which is nice but it doesn't come with a case, if that matters to you.
I'm not familiar with Mastercraft brand but you can always try it and return it if you decide it's not up to par.
JohnDean is offline
post #10 of 23 Old 06-12-2013, 08:55 AM - Thread Starter
WagBoss's Avatar
mastercraft is a canadian tire only brand, it's fairly high regarded, especially for hand tools, as they offer lifetime warranty without proof of purchase.
but yeah I need to get a new router because the one I have now only takes 1/4" collets and I'm getting a 3/4" roundover that is a 1/2" collet. The router I have now is junk though.
WagBoss is offline
post #11 of 23 Old 06-12-2013, 04:07 PM
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
I have a Porter Cable and love it, especially since a lot of after-market accessories support them.
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #12 of 23 Old 06-12-2013, 07:59 PM
JohnDean's Avatar
Quoted: 430 Post(s)
Liked: 183
I'd recommend 1/2" shank whenever possible.
JohnDean is offline
post #13 of 23 Old 06-12-2013, 08:03 PM
lukeamdman's Avatar
Quoted: 1079 Post(s)
Liked: 1200
lukeamdman is offline
post #14 of 23 Old 06-12-2013, 10:12 PM
Colm's Avatar
Liked: 94
Is this a good router/ a good deal?
Well, it is good enough for Sears to sell a version under the Craftsman name. My experience with house branded power tools sold by big companies is that they are generally good quality, if built for lighter duty. But I always find something lacking in them that makes me buy one of the major brands like Porter Cable, DeWalt, Bosch, or even Makita or Ryobi. If you are only going to use the router to build a few boxes, Mastercraft is probably fine. If you are planning on using the router for a lifetime of projects, I would recommend spending the extra money for a router from one of the companies named. FWIW most of my tools are Porter Cable.
Everything else is a bit more work simply because it is clumsier and heavier than a fixed based. You just set the depth and use it like a fixed base.
Not true. Just about everything folks use a plunge base for can be done with a fixed based. You just have to learn the technique.
It is really a matter of preference. I worked for years without a plunge base. I have one now but hardly ever use it.
Colm is offline
post #15 of 23 Old 06-13-2013, 06:06 AM
Bill Fitzmaurice's Avatar
Liked: 4631
Originally Posted by Colm View Post
If you are planning on using the router for a lifetime of projects, I would recommend spending the extra money for a router from one of the companies named..
+1, buy once, cry once. A well made tool will last a lifetime. As for plunge versus fixed, a plunge will work as a fixed, a fixed won't plunge, so why not get something that doesn't have built in limitations? You may never need to plunge, but better to have the ability and not use it than the other way around.
Bill Fitzmaurice is online now
post #16 of 23 Old 06-14-2013, 09:04 AM
Spec4's Avatar
Liked: 24
I've got a Bosch 1617 with both the fixed and plunge base, have not used the plunge yet, but it's nice to know it's there whenever I need it. Also I've wondered if drilling a hole in the workpiece as a starting point and using a fixed base would be useful in case someone didn't have a plunge? I've used this technique with my jigsaw quite often and it's worked well.
Spec4 is offline
post #17 of 23 Old 06-14-2013, 01:12 PM
Colm's Avatar
Liked: 94
Originally Posted by Spec4 View Post
...I've wondered if drilling a hole in the workpiece as a starting point and using a fixed base would be useful...
Yep, that is one way to do it.
Colm is offline
post #18 of 23 Old 06-14-2013, 01:27 PM
filtor1's Avatar
Quoted: 71 Post(s)
Liked: 73
I can attest to the quality Porter Cable 891. I bought the 893PK and have been very happy for the 7 years I have used it.
filtor1 is online now
post #19 of 23 Old 06-15-2013, 04:12 PM
koturban's Avatar
Quoted: 225 Post(s)
Liked: 124
Each have their advantages and uses. I prefer using a fixed base and drilling a starting hole. The advantage of the fixed base is better control of depth adjustments. After each pass, it's much easier to lower the depth by twiddling a knob instead of fighting a spring.
Plunge bases are a pain if you want to use it in a router table.
For your choice of router, I notice in the reviews that the bit size is limited to 1 1/4". If all you're going to do is cut baffles and do round-overs, it won't be a problem, but keep in mind what bits you might be using.
The digital speed is a gimmick. The best routers on the market don't have it.
Lastly, 1/2" chucks are better. The bits are more stable and make smoother job. You can get a 1/2" to 1/4" collett but you can't go the other way with a 1/4" chuck.
koturban is offline
post #20 of 23 Old 06-15-2013, 04:24 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
You're limiting yourself with a fixed base...also, using a fixed base for tasks designed for a plunge router, isn't very safe or smart.
Face2 is offline
post #21 of 23 Old 06-15-2013, 05:17 PM
Colm's Avatar
Liked: 94
Funny, I never found myself limited in what I could do when I only had a plunge base. Sometimes I had to make a jig to do what I wanted. But I didn't find anything I wanted to do that I couldn't. I got a plunge base because the price was right at the time and I thought it would make some things faster. And it did in certain cases, but those were few and far between.
...using a fixed base for tasks designed for a plunge router, isn't very safe or smart.
Tools are designed to accomplish tasks. Some tools make it easier to accomplish certain tasks than others. You pick which one to use based on a number of factors, including the training and skill of the operator. What you can do safely may very well be different from what another can do safely. If you feel safer using a plunge router for a particular task, by all means do so. But just because you don't think it can be done safely with a fixed based router doesn't mean others cannot do it safely.
Colm is offline
post #22 of 23 Old 06-15-2013, 05:27 PM
Colm's Avatar
Liked: 94
Originally Posted by koturban View Post
...the bit size is limited to 1 1/4".
Supposedly there is an accessory base that will accommodate larger bits. Whether one can actually get it seems to be questionable.
Colm is offline
post #23 of 23 Old 06-15-2013, 06:01 PM
koturban's Avatar
Quoted: 225 Post(s)
Liked: 124
Routers like Bosch, PC, DeWalt, et al, have interchangeable bases readily available. As Bill said: "Buy once, cry once."
koturban is offline
