Crown xls 1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 06-13-2013, 06:05 PM - Thread Starter
htgeek82's Avatar
Hey guys, long time lurker first time poster. Looking at doing a dual DIY setup of 2 ultimate 15s. Did some research. Looking at getting 2 xls 1000 to power each sub. How are these amps?
htgeek82 is offline
post #2 of 20 Old 06-13-2013, 06:34 PM
Scall's Avatar
That's the exact setup that I'm looking at. I have not used the amps so I can't comment on how they perform.
http://www.avsforum.com/t/1476895/two-ultimax-12s-vs-two-ultimax-15s
Scall is offline
post #3 of 20 Old 06-13-2013, 06:42 PM - Thread Starter
htgeek82's Avatar
Ok cool. You mentioned you have 2 of these amps already? You haven't tried them yet? Essentially I want to know if they are reliable and out put all the power properly and if they have any limitations or anything. I was reading about some amps and after a certain frequency they lose power or something like that.
htgeek82 is offline
post #4 of 20 Old 06-13-2013, 07:18 PM
Scall's Avatar
I don't have them in my possession yet. Hopefully they'll come in soon.
Scall is offline
post #5 of 20 Old 06-13-2013, 08:11 PM - Thread Starter
htgeek82's Avatar
I see. Cool. Once you get them be sure to post some reviews.
htgeek82 is offline
post #6 of 20 Old 06-13-2013, 09:12 PM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
I have an XLS1000 and used it for a year. It is a fantastic amp with bags of clean power. HPF is a lil higher @ 50Hz, which practically renders it useless unless it is powering sealed subs or assisted by outboard dsp if used for a ported sub.
FWIW, it offers stronger chest slam than iNuke at equal output. I used it in bridged mono.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #7 of 20 Old 06-13-2013, 09:20 PM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
stronger chest slam at equal output...
JWagstaff is offline
post #8 of 20 Old 06-13-2013, 09:24 PM
whitey019's Avatar
Quoted: 90 Post(s)
Liked: 55
I use a XLS1000 with a 15" DIY Ultimax and it is awesome. Not quite as refined as my SVS SB13-Ultra, but it really rocks the house.
See Posts #47 & 56
http://www.avsforum.com/t/1460745/ultimax-15-deal-of-the-day/0_100
whitey019 is offline
post #9 of 20 Old 06-13-2013, 09:24 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
"FWIW, it offers stronger chest slam than iNuke at equal output."
Listen. It's All Good.
LTD02 is offline
post #10 of 20 Old 06-13-2013, 10:14 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5235
Its a solid amp for the money...runs quiet, cool, and plenty of power on tap.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #11 of 20 Old 06-13-2013, 11:04 PM
Quoted: 311 Post(s)
Liked: 273
stronger in 25-35hz region
post #12 of 20 Old 06-13-2013, 11:10 PM
Quoted: 311 Post(s)
Liked: 273
I set the peak limiter at 1100 watts on iNuke 6000 dsp and also set crown xls1000 in bridged mono which is 1100 watts. So with equal output, crown had stronger 25-35hz impact than iNuke.
Crown xls1000 has been tested by somebody to over achieve the stated specs. I read a review on amazon probably a year or so ago.
post #13 of 20 Old 06-14-2013, 04:34 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Is that 50hz high pass filter on the XLS-1000 able to be defeated? If not, then I would guess this to be a very poor sub amp.
Martycool007 is offline
post #14 of 20 Old 06-14-2013, 04:59 AM
apnea's Avatar
Yes, its defeated very easily using a menu on the front panel (no dip switches). I have one and I'm a big fan: mine runs a 2 ohm load for hours without the fans running hard.
apnea is offline
post #15 of 20 Old 06-14-2013, 09:23 AM
Oliver Deplace's Avatar
Liked: 33
That seems quite odd.
Oh, and BTW, the 50Hz HPF is for the tops, not the bins.
Oliver Deplace is offline
post #16 of 20 Old 06-14-2013, 12:16 PM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
I have two XLS1000 (both) for sale for 300 plus shipping. I put in quit running fans. Anyone interested PM me.
bsoko2 is offline
post #17 of 20 Old 06-14-2013, 12:56 PM
04rex's Avatar
Quoted: 117 Post(s)
Liked: 26
$300 each or together?
04rex is offline
post #18 of 20 Old 06-14-2013, 01:07 PM
Point Source
beastaudio's Avatar
Quoted: 3507 Post(s)
Liked: 2831
IMO I would suggest looking to spend just shade more and going for the xls1500 or higher. The xls1000 has a weaker power supply and components. Bumping up to the 1500 gives you a little more power, and better build quality. Not to say the xls1000 is bad, just moving up to the xls1500 or more is well worth the extra coin. I have experience with both the 1500 and 2000 and They are awesome little amps. The blue LED display can be a bit bright, but just go get some 3m window tint from Lowes or HD and the problem is fixed smile.gif
FWIW the 50hz HPF is something that neither you nor the second poster would be concerned about with using them for sub duty. This statement:
"HPF is a lil higher @ 50Hz, which practically renders it useless unless it is powering sealed subs or assisted by outboard dsp if used for a ported sub."
is not accurate. The XLS series is perfectly capable of running any type of sub, or mains speaker for that matter. The 50hz being a "lil" higher at 50hz is meaningless, since it is entirely selectable and defeatable.
Scll, where are you in NC? If you want to hear an xls1500 we can arrange a meet-up. I am in Asheville.
beastaudio is online now
post #19 of 20 Old 06-14-2013, 01:40 PM
Scall's Avatar
I'm near Boone. Do you think that the 1500 will be too much for the 15" Ultimax?
Scall is offline
post #20 of 20 Old 06-14-2013, 03:10 PM
Quoted: 311 Post(s)
Liked: 273
Sorry if I my statement conveyed opposite meaning when I said 50Hz HPF is a lil higher. What I actually meant was that the lowest HPF that can be set on XLS 1000 is 50Hz. I have this amp and I was using it on a DIY mid bass module setting the HPF at 50Hz. Of course one can defeat the HPF. It is just that if somebody has a ported sub tuned to anything lower than 50Hz, he will have to use an external DSP to keep the driver from bottoming out if you use this amp all barriers open.
Here is the link to the review I was talking about, though this guy tested it at 8 ohms but still one can deduce the performance at 4 ohms bridged mono;
Good amp, power is true to advertised specs
http://www.amazon.com/Crown-XLS1000-Power-Amplifier/product-reviews/B003HZPKSM
