pre wired ceiling 5 speaker system - AVS Forum | Home Theater Discussions And Reviews
Old 06-17-2013, 11:10 AM - Thread Starter
nu0b's Avatar
Problem i need help for pls:
(4) four wire conductor wires in an adjoining closet to fee the 5 speakers in the bedroom ceiling ( house i bought was wired but nothing labeled but all allegedly working per prior home owner
1 four wire conducted combined supplies the center channel speaker.
i assumed the other were for the front and rear but when i try the red and black or white and blue individually, thinking i would get one of the four speakers left, i got no sound. but when i combined the four wire speaker into two red/white and black/blue i would get sound out of both front or both rear. so i am confused. i hope this explanation is satisfactory for the problem, again any help greatly appreciated.
nu0b
nu0b is offline
Old 06-17-2013, 11:57 AM
BassThatHz's Avatar
Quoted: 2048 Post(s)
Liked: 1581
That's because the two fronts are connected in series, as are the back two.
You'd need 8 conductors to have them independent, not just 4.
BassThatHz is offline
Old 06-17-2013, 05:04 PM
Mr.Tim's Avatar
Quoted: 277 Post(s)
Liked: 182
Four 4-conductor cables would be a total of 16 conductors.
I think you just didn't try the right combination. If there are red, black, white and blue, possible combos are red-black, red-blue, red-white, black-blue, black-white and white-blue. Since there are 4 conductors running to a speaker that presumably requires two, two conductors aren't used.
Can you tell by looking at the end of the conductors which ones were likely to have been used before?
Tim
Mr.Tim is offline
