"Compact" Offset horn for DCS205 - help choose please :) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-20-2013, 08:11 AM - Thread Starter
diaz's Avatar
Over the last week my friend has asked me for suggestions for a subwoofer. Since then he's agreed to build a horn, as long as the footprint is small, but compromises on the fact that it might be a tall format like the THT low profile.. something like 10x15x40 dimensions for example would work. He wants at least one of the dimensions not to exceed 10" by too far.. like 15x15x40 he would consider. That is worlds of improvement over the initial coffee stained napkin sketch he showed me with the dimensions of 10x11x8.. lol..
He has two DCS205-4, and a 100watt plate amp. He is actually considering two towers as long as they are matching in size - OR a single wider tower to accomodate both speakers. He just wants to know what would be best in his living room. I will try to attach a pic.
What horns do you suggest? I was looking at BFM's website, the autotube looks good, not sure if I can parallel load 8's in there. It would be ideal if it could be a bit slimmer and taller though. There is not really a limit on the height, he is willing to compromise most on height and width, but wants a slimmer build... I said it might be a close call for a horn.. so he'll go a bit wider if he needs to.
What models do you suggest? Is there a tube I have overlooked in the tower format? Something compatible with the DCS-205-4?
In red are teh locations of the placements he would agree with. The entrance is split level and lower than the Listening Position. Stairs go to basement. I think one dual sub at the left would work best, but you guys have rew experience behind you biggrin.gif
EDIT: The Table Tuba Long style would work dimension-wise (pushing limits @15" depth) but if it can accomodate the two DCS205 with a bit more width he would go for it.
diaz is offline
post #2 of 3 Old 06-20-2013, 10:09 AM
Bill Fitzmaurice's Avatar
Liked: 4667
It can, but he'd be better off with two 1x8. You can't smooth room modes with only one sub.
Bill Fitzmaurice is offline
post #3 of 3 Old 06-20-2013, 10:39 AM - Thread Starter
diaz's Avatar
Ok thanks - Edit: I think I'll design something to his specs.. he won't settle for the TT, and I can't suggest teh autotuba since it doesn't extend down low enough for HT applications..
Anyways, thanks again for the help guys, I'll post a thread with the design as soon as I draw it up and go through a dozen sketches lol
diaz is offline
