Question regarding wiring up 2 dual 2Ohm subs in their own enclosures for a final 2 Ohm load - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-20-2013, 02:47 PM - Thread Starter
04rex's Avatar
Quoted: 138 Post(s)
Hey Guys, quick question. I know how to wire it all up, but it seems that it might be a bit messy connecting the 2. is there a device that would take the 2 pairs of speakers wires to 1 set of wires instead of just twisting all the speaker wires together?
FAMILY ROOM - Totem Tribe II LCR, JL Audio E-112, Anthem MRX 300, Apple TV Gen 3, WD HDTV, Panasonic 55" Plasma
BASEMENT THEATRE - Paradigm Studio 100 v.5 L/R, CC-690 v.5 C, Studio 10 v.5 x4 Surround Side and Backs, 4x DIY 15" Ultimax Subwoofers in 3.0 Cu Ft sealed boxes, Cerwin Vega CV-5000 for Subs, Anthem MRX 720, Outlaw Audio 7700, HTPC, Apple TV Gen 4, X-Box One, Harmony Ultimate Remote, Ben-Q W1070, 92" screen
04rex is offline
post #2 of 7 Old 06-20-2013, 03:06 PM
Bill Fitzmaurice's Avatar
Liked: 5687
Two 2 ohm drivers may be parallel wired for 1 ohm, series wired for 4 ohms. Those are the only options.
Bill Fitzmaurice is offline
post #3 of 7 Old 06-20-2013, 03:09 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5972 Post(s)
Liked: 5036
Bill, in the title he mentions "two dual 2ohm drivers". One driver with its VC's in series will be 4ohm so two in parallel would be 2ohm final.
Scott Simonian is offline
post #4 of 7 Old 06-20-2013, 03:19 PM
Mrkazador's Avatar
Quoted: 264 Post(s)
Liked: 390
Mrkazador is offline
post #5 of 7 Old 06-20-2013, 03:24 PM - Thread Starter
04rex's Avatar
Quoted: 138 Post(s)
Hey guys, thanks for the replies, but i think you misread my question. I KNOW how to wire them into 4 ohms. To do that however, I need to connect both sets of wires to a third set that would go to the amp. Instead of connecting the 3 sets, is there a box or something that would connect all 3 together for a cleaner look possibly?? Might be a stupid question.
04rex is offline
post #6 of 7 Old 06-20-2013, 03:53 PM
Dank1209's Avatar
Rex. If u really wanted to be fancy . U could put spade connectors on the wires.and use a terminal block. Mounted inside. Parts express will have them.but a lot of extra work and money.I think most everyone would agree. just twist them together. use a wire nut or solder them .and electrical tape.
Dank1209 is offline
post #7 of 7 Old 06-21-2013, 04:45 PM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
Solder, crimp the three wires together or join the two driver pairs at the enclosure terninals.
Make the connection solid and permanent. Anything with a screw terminal can vibrate free over time, so I use ring/banjo crimp lugs, an additional lock nut and a bit of nail polish to seal them. Even easier, use speakons.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
