Mini F8 Project - Derived from lilmike's F20 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-21-2013, 10:57 PM - Thread Starter
diaz's Avatar
With much help from people here, and especially lilmike, I have come up with a design that I will implement in a pair for a friend. I am sure you can see the similarity with lilmike's F20 smile.gif Build will be in this thread. Speaker used for the build is the Dayton DCS205-4. It can also be build wider and dual loaded with DCS205-4's.
Corner loaded it should give me something decent in the 30hz region. Design ended up a bit shorter to fit in the box, which took about 1db away according to hornresp.
Overall the box adds up to just under 8cubic feet, dimensions approximate to 49"x17"x16" - However the width of the cab is pretty liberal, you can go down to about 13" wide without losing too much.. Or as much as 21" wide and get a slight bump in bass extention..
Here is my design progress so far:
0.5 Pi response and sketchup:
MiniF8.txt 0k .txt file
Cheers!
File Type: txt MiniF8.txt (401 Bytes, 60 views)
diaz is offline
post #2 of 11 Old 06-22-2013, 02:16 PM - Thread Starter
diaz's Avatar
Ok, here it is refolded to use the entire volume of the enclosure... a few db here and there, no big changes - but a big difference in simplicity / ease of build. The previous horn is in grey, the newly refolded one is in black on hornresp pic.
diaz is offline
post #3 of 11 Old 06-22-2013, 07:21 PM
chrapladm's Avatar
Quoted: 827 Post(s)
Liked: 287
diaz likes this.
chrapladm is offline
post #4 of 11 Old 06-23-2013, 10:37 AM
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
Looks like a nice little horn! Easy to build, too! Keep us up to date.
diaz likes this.
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
And a bunch of DIY speakers and subs.
Coming soon: Dirac Room Correction
Stumbo is offline
post #5 of 11 Old 06-23-2013, 12:10 PM - Thread Starter
diaz's Avatar
Thanks guys!
diaz is offline
post #6 of 11 Old 06-24-2013, 09:23 PM - Thread Starter
diaz's Avatar
Ok, so after showing the plans to the guy, we had a discussion and this is the result:
3 tiny cubic feet!! This is pretty small, and the output should still be pretty smooth for an 8" speaker. Hope he likes it, and I am very curious of what will end up happening here.. Im going to get REW, just dont know what to do for a mic?
diaz is offline
post #7 of 11 Old 06-26-2013, 02:46 PM
BeerParty's Avatar
Is the simulation of refold still using the 16" width? So the cab will end up being 23.6" x 15" x 16"?
Chris
--Despair, Inc. "Regret"
My AviaTrix TM Build
BeerParty is offline
post #8 of 11 Old 07-02-2013, 08:26 PM - Thread Starter
diaz's Avatar
Ok, so after further discussion, this is the final result and measurements. Was not easy to fold, but its done. Build will be this or next week.
diaz is offline
post #9 of 11 Old 07-03-2013, 07:25 AM - Thread Starter
diaz's Avatar
Just a question for people who have built horns.. can I get away with not using the 25 1/16 pannel? It would help tremendously in the cutsheet..
diaz is offline
post #10 of 11 Old 07-03-2013, 11:38 AM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Only if you fix the rest of the flare.
Looks like it can be done, but that means a refold.
lilmike is offline
post #11 of 11 Old 07-17-2013, 09:36 PM - Thread Starter
diaz's Avatar
Ok, here's the fixed refold, looks pretty good now. This is going to be cut in the following weeks.
diaz is offline
