Thinking of doing a Dayton 18" build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 33 Old 08-20-2013, 02:15 PM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1555
Originally Posted by Silock View Post
I'll probably start with one sub, but eventually get a second, because my room is pretty large (80' x 40' roughly), and place them in opposing corners (FR and RL seem to be the best places), powered by my Behringer EP-2500.
Your theater is 3200sqft, WHAT?
Your house must be 20,000sq ft on 20 acres I'm guessing.
That sounds like a barn, rather than a room. Let me guess, the ceiling is more than 10ft as well wink.gif
If you sit directly on the subwoofers... you might be able to reach 5db. LOL wink.gif
You're gonna need 16 Dayton's in that room, and 8 EP2500's, minimum.
BassThatHz is offline
post #32 of 33 Old 08-28-2013, 10:00 AM - Thread Starter
Silock's Avatar
So, I've been contemplating this a lot, and something that keeps popping into my head is just using a Sonotube.
The Sonotube calc software says the sub will work fine in a downward firing config.
My options locally for Sonotubes are either 20" or 24" diameter. 20" would have to be over 5' tall, but 24" would be just over 3, which is much better. Now, the real question is the port. With a 24" Sonotube, a 10" port's velocity with 1000w is maxed at 16.5 m/s. However, that requires that the enclosure be larger than modeled by WinISD (11.2 cu ft vs 9.3 "ideal"). Would I be able to add acoustafill to reduce the volume and keep the port?
An 8" port means the sub wouldn't need to be as tall, but port velocity rises to 25 m/s.
Silock is offline
post #33 of 33 Old 08-28-2013, 10:03 AM - Thread Starter
Silock's Avatar
The actual viewing area is much smaller than that. I just included the total dimensions of the room because there's no way to enclose the theater. As long as it's plainly audible in the viewing area, that's all I care about.
Silock is offline
Behringer Europower Ep2500 Amplifier
