Can I stick a capacitor on my speakers. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 06-28-2013, 10:00 AM - Thread Starter
BeeMan458's Avatar
Liked: 813
Like a car, can one attach a monster capacitor to their speakers?
Image provided as an example.
The idea, bolt something like the above capacitor onto the back of the speaker and wire everything up per normal or would I just make a tremendous spark and fry a really nice speaker system.
BeeMan458 is offline
post #2 of 15 Old 06-28-2013, 10:07 AM
nater1's Avatar
In car audio, the cap goes between the battery and the amp. Not wired as I understand you are proposing
nater1 is offline
post #3 of 15 Old 06-28-2013, 10:12 AM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1555
If I recall correctly capacitors only work well with DC. (i.e. car power); not 120v AC or speaker music.
Besides, cap's only supply a few seconds of power at most, usually just enough to smooth the AC ripple of DC rails etc etc
You're best off to just buy a better set of speakers/amps.
BassThatHz is offline
post #4 of 15 Old 06-28-2013, 10:25 AM
Louquid's Avatar
Liked: 38
Yeah, a capacitor between your amp and speaker won't really do much good. You'd just be adding capacitive inductance where it isn't needed.
The capacitor doesn't work really the same for AC signals as with DC. They really can only provide a quick burst of power to help compensate for current dips in DC voltage.
Louquid is offline
post #5 of 15 Old 06-28-2013, 10:28 AM - Thread Starter
BeeMan458's Avatar
Liked: 813
Yes, I was suggesting between the AVR and the speaker. I've never done anything more with a car's audio then replace the battery, the speakers or the receiver.
Can one wire their AVR according to what you suggest. The point being, are AVR manufactures robbing us poor consumers of performance, due to them putting little itty-bitty capacitors in the AVR box?
Thanks! In real terms, I'm looking to an Emotiva, XPA-5 as a solution. My OP is just a curiosity question.
post #6 of 15 Old 06-28-2013, 11:01 AM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
If wired like that, the capacitor is simply a high-pass filter, acting as a crossover and actually reducing your bass response.
Not exactly. The wall socket provides lots of voltage and current already. Car systems are limited by the battery voltage, so the amplifier current requirements are higher, and the large "stiffening caps" mitigate the peak demands somewhat.
In a grossly oversimplified analysis, a 1000 watt amp in a car wants 83.33 amps at 12 volts to reach full power. A 1000 watt amp in a home setting only draws 8.33 amps at 120 volts. Since the supply voltage is much higher for home and pro gear, the instantaneous current demands are much smaller.
Also - keep in mind that putting a 12-volt rated capacitor across 120 volt mains should cause a nice explosion.
That's a nice amp.
lilmike is offline
post #7 of 15 Old 06-28-2013, 12:38 PM - Thread Starter
BeeMan458's Avatar
Liked: 813
Note: crossing the streams is bad.
Thanks for the explanation.
post #8 of 15 Old 06-28-2013, 02:42 PM
BassThatHz's Avatar
Liked: 1555
post #9 of 15 Old 06-28-2013, 09:36 PM
MarkHotchkiss's Avatar
Liked: 85
Hi BeeMan,
Keep in mind that that particular capacitor is not meant to improve audio performance - it is meant to solve a specific problem (and it also looks cool). The problem, due to battery capacity or inadequate gauge wire, is the car's lights flickering from the draw of the amp. Of course, that problem can adversely affect audio performance, so in that case solving the problem does indeed improve performance. But it's wholly inappropriate for an AVR.
If you look over the reviews, how it looks and the lights flickering are the only two reasons anybody buys these things.
MarkHotchkiss is offline
post #10 of 15 Old 06-29-2013, 11:08 PM - Thread Starter
BeeMan458's Avatar
Liked: 813
Thanks for the reply.
post #11 of 15 Old 07-01-2013, 12:59 PM
hoffdano's Avatar
I am appalled that you think you would benefit from a capacitor between the amplifier and the speaker, but you have no idea whatsoever such a thing would do for the sound.
Even in car audio capacitors are used to store electricity (power) for those times when the battery and alternator are not enough. They are hooked up on the power input side of the amplifier. They are never used on the output side of an amplifier. (that excludes the small capacitors used in a speaker's crossover network).
The big capacitors inside the AVR are part of the power supply circuit and used to smooth the DC power. If you buy a good AVR, you can assume the power supply capacitors are properly sized for the current needed by the amplifier.
hoffdano is offline
post #12 of 15 Old 07-01-2013, 01:47 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I'm not appalled because with some box/driver combinations a large series capacitor will add several dB response, which can work kinda cool if its right before the bass roll off.
http://lautsprechershop.de/index_hifi_en.htm?http://lautsprechershop.de/hifi/aka_tief_c_en.htm
"Subwoofer tuning with capacitor in series"
This author finds a ca. 6 dB benefit in some cases, which agrees with some of my findings.
It works with some box/driver combinations and is null with others.
The same thing can happen with midrange drivers and tweeters and result in undesired peaks.
I've seen these in commercial speakers. I'm sure they are completely intentional. I haven't seen any lately but the Acoustic Research AR-LST was one such speaker if memory serves.
Back in the days before +/- power supplies people would get completely blindsided by this effect because the big cap was there to block DC and was outside the feedback loop - about 4,700 or 6,800 uF. . The original Acoustic Research AR3 would pull this stunt.
arnyk is offline
post #13 of 15 Old 12-21-2014, 02:05 PM
LSBrewer's Avatar
Liked: 0
The capacitor shown in the photo is basicly for power regulation and removing ripple from the 12 volt supply.
Period.
LSBrewer is offline
post #14 of 15 Old 12-21-2014, 02:50 PM
PorkchopExpr3ss's Avatar
Quoted: 68 Post(s)
Liked: 35
we could really use that proton pack now......
PorkchopExpr3ss is offline
post #15 of 15 Old 12-21-2014, 02:59 PM
Bill Fitzmaurice's Avatar
Liked: 4631
Did you happen to check the date on the post that you replied to?
Bill Fitzmaurice is offline
