DIY Monitor Advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-01-2013, 05:49 PM - Thread Starter
rlhaudio's Avatar
Quoted: 310 Post(s)
Liked: 96
I was thinking of building some DIY speakers. The speakers are 60% movies, 40% music. I was thinking of maybe the Eaton S 7 or, Seas Iduun 2, or the (Jim Holtz) Statement Monitors. Anyone have experience with comparing any of these speaker kits or building them? I considered buying used B&W 805D or similar monitors but building your own is much less expensive and more satisfying. Room size is roughly 14ft wide, 18ft deep, 8 ft. ceilings in a basement. I plan on building a 7 ch. Surround system with a 15” sub when finished. Any questions or comments?
Marantz 7702mk2, Panasonic 8000 w/ 130" AT Screen HTPC w/30 tb
DIY QSC SC-2150 L,C,R (10) QSC SR-8101 sides, rears & atmos/dst-x
DIY (4) Fusion Tempest
DIY (2) UM 15 "Sub's (4) SI 18's (2) PA460 mbm
(3) 15" Celestion woofers (1) Crown XLS 1002
rlhaudio is online now
post #2 of 11 Old 07-01-2013, 06:30 PM
Mrkazador's Avatar
Quoted: 263 Post(s)
Liked: 390
Have you looked at diysoundgroup.com ? They have some nice speaker kits.
Mrkazador is offline
post #3 of 11 Old 07-01-2013, 07:14 PM - Thread Starter
rlhaudio's Avatar
Quoted: 310 Post(s)
Liked: 96
I already built QSC 2150 but those things are huge tanks and very loud, I was hoping for something more detailed in the mids and highs. Im not worried about bass. I have 2 15" subwoofers for that. Also something easier on the eyes, I may leave a pair of these speakers exposed.
post #4 of 11 Old 07-01-2013, 07:32 PM
Looneybomber's Avatar
Small 2-way bookshelfs work great as near field monitors. If accurate vocals and highs is a priority, Jed has a design on htguide.com that uses the fountek ribbon tweeter and tang and W4-1337 mid, but without the woofer like the statement monitor has. If small, nearfield use isn't required, go with statement monitors.
YID DIY
Looneybomber is offline
post #5 of 11 Old 07-01-2013, 07:47 PM - Thread Starter
rlhaudio's Avatar
Quoted: 310 Post(s)
Liked: 96
Thanks, I'll check that out...
post #6 of 11 Old 07-02-2013, 04:09 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
I think those Statement monitors are going to be hard to beat. The main question is, do you have the ability/skill/knowledge to construct a crossover? Do you have measurement equipment? If not, then I would go for a proven design that someone else has already built. That way you can just clone it.
If you know a thing or two about building crossovers, and if you are interested in a totally new design, then that would be awesome! You could always go active, but even that requires quite a bit of crossover skill in order to do it right,
Have you decided on a budget for the drivers? I like the Fountek neo3.0cd that is used in the Statements, or if you want to step it up a notch, you could go with a high end tweeter and mid-range drivers from the likes of ScanSpeak, or some other high end component manufacture.
I am looking forward to seeing your ideas and concepts come to life!
Martycool007 is offline
post #7 of 11 Old 07-02-2013, 07:34 PM - Thread Starter
rlhaudio's Avatar
Quoted: 310 Post(s)
Liked: 96
I do not have the skill or knowledge to build a crossover from scratch. When I built the QSC 2150 I purchased the assembled crossover, Ill do the same thing if I build the statements. Once I see it built im pretty good at reverse engineering. Honestly I have been eyeing the statements for over a year. The ONLY reason I built the QSC 2150 was because I could buy all the parts OEM. All I had to do was build a box and plug and play. I recently found out I could buy a built statement crossover and drivers from Meniscus. Had I known this earlier I would have built the statements instead of the QSC. It looks like I'll be building some statement monitors and maybe even the statements in the near future. Once I learn alittle more about crossover design I'll attempt a build from scratch.. smile.gif
post #8 of 11 Old 07-03-2013, 06:53 AM
mobeer4don's Avatar
Quoted: 137 Post(s)
Liked: 131
Why bother with learning crossover design when Curt has already done the work? One of the best parts about a kit (or proven design) is it allows you to focus time and energy on building/finishing the cabinet instead of geeking out on the crossovers.
mobeer4don is online now
post #9 of 11 Old 07-03-2013, 09:57 AM
Some people like to build an engine themselfs and have an auto body shop do the body work. Others like to drop in a crate engine and do their own body work. It's all a hobby and learning more about something is never a bad thing.
YID DIY
post #10 of 11 Old 07-04-2013, 05:49 AM
Quoted: 280 Post(s)
Liked: 181
For me, I actually get some self satisfaction out of knowing that I was the one who built this speaker, by myself. To me, that is what makes this hobby so fun, which is knowing that I am using my smarts/brain-power to completely bring a speaker to life, with only having help in the design process. That is super fun!
post #11 of 11 Old 07-14-2013, 05:51 PM - Thread Starter
rlhaudio's Avatar
Quoted: 310 Post(s)
Liked: 96
I'm interested in knowing how and why the speaker works. I started building my first computer when the 486 pc's were introduced. I wanted to upgrade my ram and reinstall windows. At that time it was a few hundred dollars. I said the hell with that, a friend helped me at first and I took off from there. It was ridiculous what they were asking to install a stick of ram. I just cannot justify the cost of some these speaker. Im willing to spend $1,000 or more for a pair of speakers provided they perform like a commercial pair costing $4,000 or more. and if something breaks down the road, Ill know how to repair it vs. paying some tech hundreds for a few dollars in actual repair costs. I already built a DIY 15" PE sub which was really easy, now im looking for more. biggrin.gif
