Indoor/outdoor speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-02-2013, 06:54 AM - Thread Starter
Krbass's Avatar
Hey guys, I'm looking for some speaker suggestions. I want to build some speakers that will be good for music on a porch in the summer and in the winter can be used inside on a pc for music and gaming. I have a 100 dollar budget and a ton of mdf just laying around. Maybe a bookshelf type speaker would be best, I do t want them to be too large. Thanks for the help.
Krbass is offline
post #2 of 6 Old 07-02-2013, 10:03 AM
scardeal's Avatar
Is it something that could get wet? 'Cause that may make a difference...
If you plan on lugging something outside when you go outside, I'd suggest something like the Sprite boombox.
https://sites.google.com/site/undefinition/sprite
If I was not so hard-headed, I'd have been building that instead of the one I'm making based off of a pair of 1-way bookshelves.
scardeal is offline
post #3 of 6 Old 07-02-2013, 07:10 PM - Thread Starter
Krbass's Avatar
They would be mounted outside all summer and moved inside in the winter. They should be in a place rain can not reach.
I definitely want separate speakers. Cool design though.
Krbass is offline
post #4 of 6 Old 07-03-2013, 04:41 AM
nater1's Avatar
Mdf and water does not mix well. A cheap pair of monoprice outdoor speakers that you can leave outside would be better for the patio, then build something for inside.
nater1 is offline
post #5 of 6 Old 07-03-2013, 05:26 AM
scardeal's Avatar
That was what I was thinking as well. Would painting it with duratex make a difference?
scardeal is offline
post #6 of 6 Old 07-03-2013, 07:30 AM
nater1's Avatar
It might help, but its a budget buster for his budget
nater1 is offline
