Will this work? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-02-2013, 12:13 PM - Thread Starter
Beovox's Avatar
Thinking of buying this to replace the 8" Beovox 3702 woofer.
Will it work?
8" Replacement Speaker Woofer Part # W-8PC-4
Aluminum Frame
Poly Mica Cone, Rubber Surround, Gold Binding Posts, Vented, Bumped Backplate
Hole cut-out: 7"
Depth: 3-11/16"
Voice Coil: 1-1/2"
Magnet: 30 oz
Impedance: 4 ohms, Re: 3.7 ohms
Power: 165 watts RMS, 330 watts max
Response: 25-2800 Hz
Sensitivity: 91 dB, 1 watt, 1 meter
Le: .90 mH, Fs: 45 Hz, Vas: 1.77 cu. ft., Qms: 4.2, Qes: .72, Qts: .62, Xmax: 4mm
with this....
Beovox 3700 type 6233:
Height (inches): 19,75
Width (inches): 9,9
Depth (inches): 9,9
Weight: 8,5kg
Impedance (ohms): 4
RMS load (W): 40
Music load (W): 75
Frequency response (Hz): 40-20
Harmonic distortion (%): 1
sensitivity (W): 3
Cabinet volume (Litres): 20
Dispersion (degrees angle): 120
Bass unit: 20cm
Mid-range unit: -
Treble unit: 38mm dome
Crossovers ((Hz): 2K
Beovox is offline
post #2 of 5 Old 07-02-2013, 01:14 PM
Mrkazador's Avatar
Quoted: 254 Post(s)
Liked: 381
You can't swap any driver in there without doing some measurements. The best replacement would be the exact same woofer. Is the woofer damaged beyond repair?
Mrkazador is online now
post #3 of 5 Old 07-02-2013, 02:26 PM
Colm's Avatar
Liked: 94
Originally Posted by Beovox View Post
Will it work?
Yeah, it will work. Whether it will be an improvement is the question. Why do you want to replace the woofer?
Colm is offline
post #4 of 5 Old 07-02-2013, 03:04 PM - Thread Starter
Beovox's Avatar
Thinking about just cutting of the wires from the old one, and use them on the new without changing the electronics first, it won't explode right? I guess the ohms are the most important?
The old woofer is blown or something.
Beovox is offline
post #5 of 5 Old 07-02-2013, 06:13 PM
Awenta's Avatar
Define or something.
You may end up downgrading the woofer and still have it be something.
Sent from my SCH-I535 using Tapatalk 4 Beta
Awenta is offline
